Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
The brush won't spin
Made a clunky sound then stopped spinning
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Replace the belt for the brushes
Posted on May 13, 2010
2 Suggested Answers
  • 5370 Answers
SOURCE: the spinning brushes mechanism won't spin.
With the machine switched off, press the re-set switch on the side of the head, making sure you push the button in as far as you can. When you switch the machine back on and lower it into the vacuuming position, the brush bar should start turning. --------The brushes don't spin if the unit is placed upright. First off check that you haven't pressed the button that turns the brush on and off.-- But if that is turned ON.Then the other possibility can be clogged brush with dirt. take a look at the brush bar to see how much hair and debris is caught in there. If there is very little then you probably don't have much to worry about and you can press the brush reset bar on the side of the vacuums head and your problem with they Dyson brush not turning can be fixed. Also check the be belt and the motor.If belt is got loose, then motor will spin but brush will not spin, due to loose or worn out belt.If belt is intact, but motor is not spinning, then its weak motor issue.If motor is the issue, then to replace and repair the motor.Please click the link below:---- http://dysonmedic.co.uk/dyson-dc24-brush-bar-motor/ ------------- The operating instruction for dc-24 and dc-25 are near to same.So if you require disassembly instructions.Please click this link below and see the video.This will help, for disassembly:--- http://www.videojug.com/film/loss-of-suction-dyson-dc25 ---------------- This should help, thanks.Helpmech.
Posted on May 13, 2011
I have used my dyson dc39 perhaps a dozen times tops and the brush bar won't stay spinning. I've stood it upright and turned it off, clicked the brush power button. Spins then stop-makes pop sound.
If it's like my DC-07, the brush shouldn't spin if it's upright, and also won't spin if you don't have the clutch for the brush fully engaged. Make sure that the back of the unit is tilted off of the fully upright position, and check that the brush clutch is all the way engaged - there may seem to be a middle setting, but that isn't really where you want to be. Hoping that helps.
Sep 13, 2015 | Dyson Vacuums
Brush won`t spin on brand new vacuum
Hi! Many of our vacuums include a brushroll shut-off feature that needs to be activated in order for the brushes to spin. The brushroll shut-off pedal is usually located on the right side of the cleaner on the hood. Your instruction manual will show you exactly where your brushroll shut off pedal/button is located if your vacuum has this feature. Also, on many models the brushes will not spin when locked in the upright position. The handle must be reclined for the brushes to spin. Hope this helps!
Jun 13, 2014 | Hoover Vacuums
Troubleshooting
Hi Janet. Thank you for asking this question. Your vacuum wasn't designed with a brush on/off switch so having the brush continually spin is normal for your vacuum.
Jun 29, 2013 | Bissell 3576 CleanView II Bagless Upright...
Dyson DC41 brush won't spin
You need to check the belt hooked to the side of the brush (sometimes hidden by plastic)
Jun 26, 2012 | Dyson Bagless Upright Vacuum DC41 Animal
Brushes don't spin
I'm sorry to hear you're having difficulty with the motorised brush head on your DC31 Animal. If the head won't seem to work correctly after you've checked for any obstructions, I'd encourage you to get in touch with us directly as we'd appreciate the opportunity to provide further assistance.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). Please have the machine to hand when you call, as one of our advisors may be able to resolve the issue with some troubleshooting over the phone.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 11, 2012 | Dyson DC31 Animal Bagless Handheld...
Brush inside main head doesn't spin, and stops spinning immediately after prompting it to spin. seems like the motor stop turning brush, however when i open main head and cover suction hole for a...
Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Brushes not spinning
Sounds like the belt has been stretched. Check the belt and see if the tension is ok. You should be able to view the belt after removing the sole plate. If the belt is loose you need to replace it.
Sep 09, 2009 | Bissell 3920 Bagless Upright Vacuum
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 37602 roller stopped spinning
If the roller brush as stopped spinneng .and the brush motor still works the brush belt as broken,
you must replace the brush belt, t
Sep 05, 2007 | Bissell 37603 Upright Vacuum
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
202 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
