Question about Nintendo Wii Fit for Wii
Wii board says to step off it...but i'm not on it
  • 5 Answers
It is not low batterieswii board says to step off it...but i'm not on it - 2_bing.gif and is not line-of-sight "stuff" in the way.
Bluetooth2_bing.gif is RF not IF; does not need line-of sight.
The problem is in the sensors in the feet of the board.
Pick the board up, click "A"; set the board back down and it starts to work.
BUT;
It misses footsteps during the exercise; SO, bad sensors. Crappy design is the problem. Some break sooner, some break later. Not an overweight user issue either.
Posted on May 15, 2010
My wii fit was working perfectly fine when i purchased it, then about a month or so later the wi fit game didnt recognise the balance board, so when it said please turn the power button on and i did, it no...
When you power on the wii fit board, does the light flash continuously? If so, you will need to sync your board with your wii again. You can get instructions on how to do so here: http://www.nintendo.com/consumer/systems/wii/en_na/ts/balanceBoard.jsp
Mar 22, 2011 | Nintendo Wii Fit - Balance Board + Game...
Wii fit board keeps saying get off and press A to initialize game but no one on the board. Have tried new wii fit disk but same. Other ski game works with the board
You get off press a wait for it to say step on and then get on. If it keeps saying it after you get off, take out the batteries and get a new battery pack, don't step on it at all until it loads.
Jan 26, 2010 | Nintendo Wii Fit for Wii
My wii fit board's power LED flashs for seconds then goes off and it keep asking me to switch it on before stepping on
The wii fit board acts the same way as the wii controller. You have to sync the wii fit board to the console.
Dec 14, 2009 | Nintendo Wii Console
Please step off press A - constantly repeated - why???????????
If the Wii Balance Board fails to operate, or operates incorrectly, follow the steps below before seeking
assistance.
A. Check the batteries.
B. Check to be sure there is nothing pressing against the bottom.
C. If you are using it on soft carpet, put the foot extensions on.
1. The Wii Balance Board does not respond.
• Make sure the power is turned on. The blue Power LED should be lit if the Power Button has been
pressed. (The Power Button faces away from the TV.)
• Make sure the board has been placed correctly (see page 6).
• Make sure the batteries have been inserted correctly and are not been depleted.
• Make sure the game you are playing is compatible with the Wii Balance Board.
• Review the synchronization procedure on pages 7-8 and make sure this has been done correctly.
This procedure must be done for each Wii Balance Board compatible game.
• If, after verifying the steps above, the Wii Balance Board does not work, try the following:
1. Turn off the power of the Wii console with the POWER Button on the front of the console.
2. Unplug the power cord from the wall outlet for a few seconds, then plug it back in again.
3. Turn on the power of the Wii console.
4. Repeat the steps in this Operations Manual for setting up the board.
If the Wii Balance Board still does not work, follow the information at the bottom of this page.
2. Control of the Wii Balance Board is inconsistent or seems incorrect.
• Review the Instruction booklet for the game you are playing to make sure you are performing the
correct actions for that game.
• Try using the Wii Balance Board foot extensions if you are using the board on carpet (see page 10).
• Make sure there are no people or other objects between you and the Sensor Bar.
• Avoid interference from other devices. If communication seems to be affected by other devices
(wireless LAN, microwave ovens, cordless devices, computers) move to another location if possible,
or turn off the interfering device.
If the Wii Balance Board still does not work, follow the information below.
If the Wii Balance Board still does not work, an operational check procedure is available
in the Options Menu of the game you are playing. See the Instruction booklet included
with the Game Disc for more information. If your Wii Balance Board does not operate
correctly after all of the above steps, visit support.nintendo.com for assistance and
additional troubleshooting and repair options or call 1-800-255-3700.
Jul 19, 2009 | Nintendo Wii Fit for Wii
Wii board not letting you step on
You will need a new Wii board unfortunately. The Wii board is not designed to be jumped on, nor an excessive amount of weight be placed on it, as it damages the springs inside the board.
If it is a new board, the chances are it is faulty. Take it back to the store you purchased it from and get it replaced.
Jan 15, 2009 | Nintendo Wii Console
"Step Off Me and Press A" message while not on wii board
When you get this message, lift the board off the ground, press A, and wait until you get to the confirmation screen before placing the board back on the ground. You may have to try a few times to get the timing right. I have no idea why it thinks someone is on the board, but this workaround has solved the problem for us. Good luck.
Jan 04, 2009 | Nintendo Wii Fit for Wii
Wii freezing
to format your memory following these steps...
  1. Access the Wii System Settings screen
  2. Click on the left blue arrow twice to reach the Wii System Settings 3 menu options.
  3. Select "Format Wii System Memory."
Dec 08, 2008 | Nintendo Wii Console
Wii Fit Board asks me to step off and press A all the time
This is really very frustrating when you face such kind of problems. You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Dec 04, 2008 | Nintendo Wii Console
Power
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Sep 09, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Fit for Wii Logo
281 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
