Question about Teac SRL50 Clock Radio
LED display of my Teac SR-L50 has gone completely, just a random string of characters. Any ideas? I can't see a reset button.
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: intermittant failure LED display of my TEAC SR-L50 Clock Radio
Offhand, the failure of the 2 segments would seem to be intermittent (granted affected by humidity). Technically, I would suspect a case of cold solder. They could be replaced or if you know somebody who could solder, then it is a matter of re-heating the joints and adding a dab of soldering lead.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 21, 2008
Samsung American fridge freezer SR-S2028CSS keeps beeping and randomly turning the fast freeze on and off.
quite possibly it needs some freon added to the system and only service people can do this
Jan 06, 2016 | Samsung Refrigerators
Alt code 9791
Some software won't let you type those characters directly.
You can run "Character Map" to find the desired characters, type the codes into the "Characters to copy:" pane, click the Copy button, paste them to a line within your document, and copy/paste from that string as needed. The System character set has those characters.. they're not shown, but the Alt key combinations display the characters needed.
I was able to paste the character in this post, but I got the message "Please use English characters only" so I had to remove it before I could post.
Dec 08, 2013 | Computers & Internet
How to set clock on the teac sr-l100 just bought at yard sale, no info book. thanks d
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps!
To set the alarm on the TEAC SLR 100:
Be sure the radio is set to off or standby.
Hold down the BUTTON for the alarm you wish to set (#1 or #2) until the TIME ON THE DISPLAY begins flashing. Use the TUNER/CLOCKSET DIAL to change the display to the time you wish the alarm to go off. pRESS THE ALARM BUTTON BRIEFLY TO RETURN TO NORMAL OPERATION.
May 28, 2011 | Teac SRL50 Clock Radio
Lighting has gone in the display panel can this be replaced ?
yes, almost all display panels are backlit by LEDs. cud be the LEDs or the supply to LED. should not cost much.
Mar 14, 2010 | Teac CD-X9 Shelf System
In the programs I have made when I use the Request enter a integer, I always have to press the alpha button before entering a # in the field when running the program, is their a way to program a request...
The syntax of the command is as follows
:Request Message, VarName
where Message is a character string containing the message that will be displayed as a prompt, and VarName is the name of the string variable where the input will be stored.
If you want to input a numerical value you must convert it from character string to a numerical value (I know, it is like splitting hair but string 123456 is not the same as number 123456)
You convert from string to numerical value with the expr() command.
Exemple:
:Request "Value of a? ", s
:expr(s) --> a
That should do it.
Hope it helps.
Oct 15, 2009 | Texas Instruments TI-89 Calculator
Intermittant failure LED display of my TEAC SR-L50 Clock Radio
Nov 21, 2008 | Teac SRL50 Clock Radio
TEAC SRL100 Set clock
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps! Ted
May 26, 2008 | Teac SRL50 Clock Radio
Unlock codes for TEAC PL-D2000
Comments:
To set Region code to 0 on a Teac PL-D2000 DVD System to enable play of any region
Ensure TV monitor is on so and set to display DVD.
1. Turn system completely off.
2. Turn on system.
3. Open tray.
4. Using remote press and hold the return button.
5. While holding the RETURN button, press and hold the DISPLAY button.
6. You will see something like this displayed on screen: VER 1006 TE 3210
7. Release DISPLAY and RETURN buttons simultaneously.
8. Press the ANGLE button. You will see WRITING REGION ID displayed.
You can now play DVDs from any region.
Dec 28, 2007 | Teac PLD2000 System
Right clock time
Hold the memory button on the remote control, wait for the written "SYNC ON" on display and then press the track forward (one on the right with the double arrow).
Now normally set the clock.
Dec 02, 2007 | Teac SRL200i/B Clock Radio
Teac SRL50 Clock Radio Logo
60 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
