Question about HP Pavilion dv8000t Notebook
Our HP Pavillion dv8000 just recently started having problem with keyboard. No Virus. Caps Lock light will not go on (frozen) and "s" key does not work. Sometimes the keyboard properly- sometimes it freezes with the above described problem??? Any suggestions.
I had this same issue with my DV8000 though the main issue with my keyboard was that the computer seemed to think the space bar was being held down and several keys did not work. I opened up the laptop and disconnected the keyboard internally (Note: there are 2 ribbon cables. One for the keyboard and the other for the top funtion keys ie: Power, media controls etc only disconnect the keyboard cable) and installed a usb keyboard to ensure the issue was the keyboard and not the keyboard bios on the motherboard. Once I found this solved the keyboard issue I now have a keyboard on order. Try Amazon or Ebay. I found the keyboard new for $15 as opposed to $70 from HP.
I am still working on correcting an issue with the sound. (Sound stopped working completely)
Posted on Aug 02, 2010
  • 86 Answers
Clean the keyboard wiith a compressed air can, if that doesn't do the trick try a usb keyboard, if the external keyboard works well then you need to replace the laptops keyboard.
Posted on May 13, 2010
Caps lock light does not show
You can use the accessibility features of Windows to audibly notify you when you've pressed the Caps Lock key. Follow these steps:
Click on Start >> Click Control Panel.
Click Ease Of Access >> Select "Change how your keyboard works" from Ease of Access Center.
Check the Box for Turn on Toggle Keys.
Click Apply. Click OK.
The ToggleKeys feature, when turned on, will beep whenever the Caps Lock, Num Lock, or Scroll Lock keys are pressed.
hope this helps
Jul 29, 2012 | HP Compaq 6735s Notebook
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
How do you unlock the CAPS lock
To unlock the caps lock on your keyboard, please click on the caps lock key again.
Check for few iluminating lights on your keyboard as well, as few of the models does have that.
If the Caps lock is ON the lights normally illuminate and If you click on the caps lock key again, the lights go off.
Feb 07, 2010 | Gateway 2520915 Keyboard
Keys on my hp pavillion dv4 (bronze) are very difficult to read. Is it feasible to replace the keys?
Not the key caps -- the part that has the writing on it. But it is feasible to replace the entire keyboard with a new one. If you have use the keyboard enough to wear the writing off, then you have JUST about used up all the life that keyboard has to offer!!!
Jan 07, 2010 | HP Computers & Internet
Sometimes the keys that have white and blue writing on them will only respond blue. How do i get them to respond as white instead of blue keys?
You have a FNC key on your keyboard. Since it is a laptop, your keyboard can not have all the keys that a normal keyboard has. This is handled by making some keys perform two or more functions. Thus, the alternate key use if the blue keys (function key is depressed). You will pribably find that there is a light labeled as FNC where you see your caps lock, num lock etc.. it sounds to me that you have your keyboard in alternate function mode so that the keys are performing the alternate functions (probably the numeric keys if it is a normal configuration..).
Thanks!
Stan Skaggs
Oct 19, 2009 | HP Pavillion G50-111NR Notebook
Keyboard locks into all CAPS
Just a thought...one time I had a button that kept stiking itself with out me touching it...I removed the keys aroud it, only to find a tooth pick had found its way into my keyboard. Everytime I would hit any of the keys around it, it would also hit that button too. Dont know if this is your problem but worth a look!!
Sep 18, 2009 | HP D8597A Keyboard
HP Pavillion DV8000 Factory Restore
HP.Support.drivers put your model number in the search box, choose drivers - software. All the files that are compatible with your computer are there for the downloading and all is free.
Sep 09, 2009 | HP Pavilion dv8000z Notebook
Meaning of indicator lights on wireless receiver
I concur 2/3's with yooperbud.
1 = System is connected and working
A = Cap locks On= Cap lock is on. Off = Cap lock is off.
F = Function Key usage. On = I'm going to use the alternative fuctions of the F keys as programmed in the Keyboard settings. Off = Your using the standard features of the F keys.
Dec 31, 2008 | Microsoft Wireless Optical Mouse USB...
Keyboard stuck in upper case
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Mar 05, 2008 | Acer NSK8458AN Keyboard
HP Pavilion dv8000t Notebook Logo
343 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
