Question about Frigidaire ATF6000ES Front Load Washer
Washing machine error code on Frigidaire ATF6000E
I keep getting an error code on the washer. The code showing is E20. Do you happen to know what "E20" means?
Thank you larkinator.. that totally fixed the problem as far as i can see right now, I am letting it "wash" a load of nothing. it was a bunch of BS how they hid the filter... I had to literally take apart my whole machine. :-) but its fixed, THANKS!!!!!
Posted on May 28, 2008
  • 3 Answers
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Posted on Apr 07, 2008
Start by taking the top off so you can remove the front, pretty straight foward. the clog will be in the fexible boot attached to the pump. this will have to be removed to get the filter out, BE CAREFUL!! there are extemely SHARP edges in there!
Posted on Aug 19, 2008
  • 770 Answers
Here is a list of theFridg. 6000 fault codes i dont see a E20 are you sure of the model#
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E52 Bad signal from tacho generator. Refer to test (8)
E56 Highmotor current. Refer to test (9)
E57 High current on inverter. Refer to test (9)
E58 High current on motor phase. Refer to test (9)
E59 No tacho signal for 3 seconds. Refer to test (10)
E5A High temperature on heat sink. Test first if bad replace
speed control board.
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E75 Water temperature sensor circuit. Refer to test (12)
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
Posted on Apr 01, 2008
6ya staff
SOURCE:
Error code E20
The E20 error code is usually something clogging the pump system.
Umplugg the machine. In the back you can access the drain hose. Pull the clamp with pliers and then the larger clamp to the tub. Pull the pump with a screwdriver there will be a black rubber still attached to the pump. Watch how you pull this there is indexing to the way the pump is mounted take a pictutre and mark the pump. Look inside the hose and see if there is something cloging it.
I’m happy to help further over the phone at https://www.6ya.com/expert/james_da451a4ec470352a
Apr 21, 2014 | Frigidaire Affinity ATF7000E Front Load...
How can I fix E20 error on washer
COULD BE EITHER? U HAVE TO CHECK THE HOUSE DRAIN AND THE HOSES AND WATER PUMP FOR OBSTRUCTIONS
Feb 16, 2014 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
My washing maching is reading E20 and it is not washing. it seems to stop after a few minutes of washing and then it will read E20 and just continuosly beep
Hello.
Frigidaire front-loading washing machines have an electronic control panel where the wash cycle and any other wash options are selected, and the wash cycle is initiated and stopped, if necessary. The control panel also has indicator lights that show the washer status and will display an error code if there are issues with the washer. The "E20" error code indicates a possible pump problem.
Blocked Pump
One of the primary reasons why there may be an "E20" error code on a Frigidaire front-loading washing machine is if there is something blocking the pump. Disconnect the washing machine from the power and release the clips on each side to remove the front access panel. Set a container under the pump drain, which is located on the lower right side of the washing machine. Open the pump drain plug and allow it to drain. Clean out any debris that might be causing the obstruction, then close the drain plug. Close the access panel and restore power to the washer.
Drain Hose
If the drain hose is blocked or crimped, the water may not pump out fast enough, causing the pump error to appear on the display. Straighten out the drain hose in the rear of the washing machine and move it away from the washer if it's trapped between the wall and the washing machine.
Oversudsing
If too much detergent--or the wrong kind of detergent--is used in the washing machine, too many suds may result. This can overwhelm the drain and pump system, resulting in the error. Use only high efficiency (HE) laundry detergent with Frigidaire washing machines and follow specific instructions on the laundry container for the recommended amount of detergent. Run a drain cycle if there are excess suds in the washer to clear out the system.
Pressure Switch or Control Boar
The pressure switch may not be communicating properly with the control board, which can cause the E20 error to occur. The other possibility for the E20 error code is if the control board has failed entirely. Try to reset the washing machine by pressing "Stop/Cancel" and disconnecting the washing machine power cord. Wait 30 seconds, then restore power. Make a new cycle selection and press "Start" to see if the error code returns. If it does, turn off the washing machine and contact Frigidaire for repair.
Thanks.
Nov 08, 2011 | GE Energy Star WCVH6260F Front Load Washer
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump.
Please post back for any further assistance.
Daniel
Jul 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Error Code E20
e20 is a draining issue.check your filter is clean.if this is ok suspect a bloackage in the waste hose or faulty or jammed drain pump impellor
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Error codes
I suggest you snake out the drain into which the machine waste hose goes, the standpipe that is. The drain could be blocked somewhere causing pressure problems which is conveyed to the machine. Be sure to replace the machine exit hose at about 3 feet from ground level, and dont shove it too much into the standpipe. Do not block up the point where the machine hose goes into the standpipe, it shouldn't be air tight.
Dec 28, 2007 | Frigidaire FTF530FS Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
1,902 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
