Question about RTO Atwood Water Heater - 6 Gal LP
One of the aluminum pipes from the stat to lighter broke. Where can I buy this part
  • Mike Butler
    Mike Butler May 14, 2010
    Sorry, description has me confused a little, could you please explain/describe what part(s) your talking about, so I/we can be sure? Thanks.
  • avaautotech May 14, 2010
    Sorry about that. My helper didn't explain very well. I was looking for the pilot tube replacement kit. The aluminum lines cracked at the fittings and was leaking propane. Found the kit locally and all is well. Sorry and thanks Tony
  • RTO Master
  • 6,674 Answers
Yah, pretty common occurrence once they get a few years on them. Really have to watch for a little corrosion right where it breaks, is a good sign, it's getting pretty thin, and should be changed. Of course you have the owners bumping it quite often when manually lighting as well. Thanks for getting back.
Posted on May 14, 2010
How to remove broken off hot water tank drain nipple
You can purchase an ease out tool from Home Depot or Lowe's, It fits inside the broken pipe and when you rotate it counter clockwise it tightens inside the pipe and removes the nipple. (Be sure to check the inside pipe diameter first)
Mar 21, 2013 | Water Heaters
I have a G6A88E water heater in my rv it runs great except behind the front on the bottom on the right as you are looking at it there is a 1 1\2 about pipe that is leaking is there any way to fix this
From description it Sounds like your bottom hook-up for water line coming in.(cold inlet) Depending on what type of connection you have on water line, it may just need tightening, if not it may require a new fitting installed, or the actual 1/2" NPT nipple going in to tanks is faulty. They use plastic, or galvanized pipe nipples usually, but in some cases you may find a check valve there. Either way, you'll have to determine exactly where it's leaking first. Depending on age of tank, it may even be the piece of aluminum welded to tank where 1/2" pipe nipple is installed. I've has 2 this year that rotted right through that and caused a leak, and had to replace the tanks. Let's hope yours just needs tightening, or a fitting replaced. Make sure you use good pipe dope when changing that nipple if necessary. Many use Teflon tape as well on threads, but I've had better luck with pipe dope.
Oct 31, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a forty gallon electic rheem water heater with a pipe going in the bottom and one in the top which wone is the cold water inlet the bottom????
The one with the pipe going to the bottom is the cold...cold water goes in on the bottom and the hot comes off of the top...hot water is lighter then cold water and rises to the top...
heatman101
Oct 11, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My Rv water heater will not stay lit for longer than 2 minutes. There is no sticker with the product name on it. The model # is G6A-4E, it uses a GAS LIGHTER direct spark ignitor to lite. I have cleaned...
If your water heater dies, here's a quick way to find out if it is the Thermal Cutoff. First, MAKE SURE there are no obstructions in the flue tube. Then turn off the water heater's electric mode and turn on the gas mode. With the exterior access door open and looking at center of the water tank you'll see a black foam-covered area with 4 wires running to it. Look for the area marked T-STAT with two brown wires running to it. One of the wires will have a piece of clear tubing over it that covers a large diode- this diode is the Thermal Cutoff. (Mine didn't look burned or in any way defective, so a visual inspection won't tell you if it's bad or not.)
Remove the diode from the T-STAT terminal lug then disconnect the other end of the diode from the brown wire connector. Now connect the brown wire (without the diode attached) directly to the T-STAT terminal lug. Give it a few seconds and the water heater should turn on in gas operation mode. If it does, that means the Thermal Cutoff is bad and you'll need to get a new one from Atwood. Leave the wire hooked up, turn on the electrical mode to supplement gas mode (if you want) and you'll have hot water till you get the new Thermal Cutoff.
If the water heater doesn't turn on after a minute or so chances are it's not the Thermal Cutoff and you'll have to look elsewhere for your problem.
May 03, 2010 | RTO Suburban Rv Water Heater Dsi Gas Valve...
WHAT IS THE PURPOSE OF THE AQUA STAT?
The purpose of an aquastat is to measure the temperature of the water flowing in the piping and regulate the control valve.
Mar 12, 2010 | Grundfos RCP-96 Recirculation Pump for...
Kenmore Water heater, Model # 153.339462, Pilot lights, burner burns for approx. 10 - 15 minutes then both go out. after which it is more difficult to light the pilot, and it goes out again in less time...
The thermocouple is the copper one the other is the gas supply to the burner check your flue pipe for restrictions see if a flame from a lighter sucks up the flue from the top hood you may need a new gas control valve
Nov 04, 2009 | Water Heaters
I have a richmond tankless water heater and its been shutting down and showing a code c7 or c8
1/overheat stat 2/ fan 3/diaphrapm valve 4/ micro switch check area around fan very small hose pipe for pinhole best of luck
Oct 30, 2009 | Rheem Tankless Hot Water Heater...
4 time red light flashing
check overheat stat or fan check small hose pipe at fan area for pihole best of luck
Oct 11, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
RTO Atwood Water Heater - 6 Gal LP Logo
42 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
