Question about Microsoft Windows XP Home Edition
It doesn't boot up right.
I have a Windows XP and when I boot it up it does just fine until I get past the boot screen right before the logon screen. The monitor turns to a greenish-grey color; I have already tried to start with the last known good configuration too. I don't know what to do. Please help!
    President:
  • 1,070 Answers
Dear Friend,Make sure the VGA cable is properly connected(also ensure Driver Properly Re-installed).Overly green color means the Red gun is turning off. This could be a cable issue or a component failing within the monitor. You can try and move the cable around and see if it improves.OR It might be with bad picture tube, but it's most likely a bad solder connection. It may probably turns out that the board connector pins are poorly soldered to the printed circuit board. As the unit warms up, stuff expands and the connection "heals" temporarily.
Hope this make you a Conclusion.... Thanks for Contacting FixYa
Posted on May 13, 2010
Disable omnipass at boot
Go tocontrol panel. Select "User Accounts" and disable the logon. Install SP3 because there are many patches on it to stop bugs.
Dec 11, 2013 | Computers & Internet
Tip
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Installed win 7 but want restore to xp
To reinstall win XP from usb flash drive you need WIndows XP cd, 1 gb flash drive and Novicorp WinToFlash. Download WinToFlash to your computer and follow instructions to transfer Windows XP from cd to flash drive, After that boot your notebook from usb device and select "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon" then install win xp normally, but format C partition. After first start of your notebook boot again from flash drive in "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon". Now windows is starting, go to start/my computer right click on it and go to properties in this windows go to advanced tab and there go to startup and recovery, click on settings, in new window go to edit tab and in new window change the line "multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP" /noexecute=optin /fastdetect" after windows XP write the type of your XP Professional, Home Edition, or Media Center. Now you can remove usb flash drive and boot normally from hdd.
Nov 12, 2012 | Advent 4211c Notebook
I set my admin account to limited user and i cant open it anymore..please help to retrieve this user account.thank you..
i assume you are using Windows XP.
try log off and login as "Administrator", if you remember the password. Try blank password first. if it doesn't show in the list, press Ctrl-Alt-Del twice and type it in.
if no joy, you can download this iso, burn it onto CDR as disk image, not data.
restart and boot from this CD, then you have the chance to change/reset/blank any user's password. but take care not to do other thing. follow the author's instructions.
good luck!
Aug 08, 2011 | Microsoft Windows XP Professional
Radeon X1300 card displays blank screen at logon
Boot the system in safe mode. Go to device manager and under display adapters , right click on the onbaord graphics adapter and disable the same. It worked on one of the systems i troubleshot for the same problem.
Thanks for using Fixya
Proton
Aug 28, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
9600GT Vista 64 bit Screen gets No Signal after logon
Make sure that you uninstall the drivers that don't work.Then go to this web site download and install new drivers.
http://www.zdnetasia.com/downloads/pc/swinfo/0,39043052,50002410r-39555174s,00.htm
Mar 07, 2009 | Computers & Internet
Logon
Go into your BIOS
Set the 1st Boot device preference to CD
Insert your windows XP disk
Boot from CD
Run XP Repair
You do this at your own risk. I am in no way accountable for damage to your computer.
Give me a message if you need further assistance
Blazamane
Jan 07, 2009 | Computers & Internet
I have windows Xp running on my desktop. Had no issues starting it up and working on it until a couple of days ago when suddenly it won't let me get past the initial logon screen, where it prompts me for a...
At the logon screen, click advanced options, you might have three options here.
User name
password
and a third one, Is there a dropdown option here, if so see is there an option to "log on to this PC"
have a look and let me know
Aug 29, 2008 | Computers & Internet
Problem with Video on HP Pavilon Laptop
are you sure your using the right ati driver ?
Try downloading the one for you laptop on the hp website
or
try downloading the ones from here
http://omegadrivers.net/ati.php
Feb 25, 2008 | ATI Mobility RADEON Graphic Card
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
