Question about Dremel 231A Shaper/Router Table
NEED DRIVE BELT FOR DREMEL BELT/DISC SANDER
NEED REPLACEMENT DRIVE BELT FOR DREMEL BELT/DISC SANDER
3 Suggested Answers
cloe2594
  • 29 Answers
SOURCE: Dremel belt/disc sander
see the manual
Posted on Nov 06, 2008
SD Tech
  • 14553 Answers
SOURCE: I need spares for my Dremel 6000 sander
Most likely you will find them on EBAY---search there for Dremel.
Posted on Nov 04, 2012
Removing the disc sander on an erbauer erb050bts to replace the belt
The drive belt is a toothed rubber belt, which will be 'thrown off' if there is too much resistance to rotation (pressing too hard, or sanding belt not correctly aligned and rubbing against the side).
To access this, it is not necessary to remove the sanding disc.
Remove the two allen bolts on the top which hold the disc belt assembly (NOT the one that clamps the belt drive disc). The whole assembly lifts off, giving access to the drive belt. It is a bit fiddly, but it can be hooked back on the pulleys and the bolts refitted. Good luck!
Dec 11, 2012 | Tools & Hardware - Others
Replace drive belt Bosch pbs7a
NEED A AUTO REPAIR SHOP TO RESET IT ONLY THERE COMPUTER CAN DO IT OK
Nov 14, 2012 | Bosch Belt Sander Drive Belt For Pbs 7a,...
Nov 04, 2012 | Dremel 6000 Contour Sander
Belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Mar 18, 2009 | Black & Decker Tools & Hardware - Others
BROKEN RUBBER BELT FOR BELT SANDER
Maybe you can use a linked belt to replace it. Check the width of the old drive belt, and give these folks a call: Lee Valley
Nov 14, 2008 | Tools & Hardware - Others
Dremel 231A Shaper/Router Table Logo
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
