Question about Dometic Rooftop RV Air Conditioner
Duo-Therm model 59146 does not cool
Duo-Therm model 59146 heats ok, but the compressor stops after roughly 60 seconds when in cool mode. Potential problem?
3 Suggested Answers
  • 534 Answers
SOURCE: my dometic duo therm brisk air RV a/c unit is not cooling the RV
clicking sound could be thermal overload on the compressor. If the compressor has gone out the unit will not cool the clicking sound is possibly the compressor trying to reset but if the compressor has "gone to ground" (winding burnt out) you will need to have the compressor replaced. Good luck on your repairs hope this helped some
Dave
Posted on Oct 27, 2009
  • 674 Answers
SOURCE: when set to cool and thermostat turned down all it
Check to make sure the compressor and condenser fan are working. If the are you may need to have the charged. If not you need to find out why.
Posted on May 02, 2010
Ac compressor runs but will not cool
check thermostat, replace capacitors amp compressor to be sure its running if not relay module issue.
Aug 08, 2015 | Dometic 651815 Duo Therm 13,500 BTU...
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
When set to cool and thermostat turned down all it does is blows hot air Duo-Therm model # 59146-331
May 02, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm Fan Blows, No cool air. Worked yesterday, not today?
most likely compressor running could be capacitor, breaker,relay,or compressor it self start by checking power to unit
Aug 22, 2009 | Heating & Cooling
Duo Therm compressor tries to start and kicks out
I don't think these little units have a start capacitor but what I would do is check that the on/off switch wires to make sure they aren't loose. Also check the wires to the compressor for loose wires as well. It is possible that these are the first signs that the compressor is about to fail. They also can act up some when they haven't been used for awhile and then you try and start them up. Try running the unit for a few hours without asking it to cycle. It might just be a sticky valve.
Apr 13, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
115 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
