Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
The stand by red light keeps switching on and off resulting in no
When i switch my tv on the red light is initially clicking on but flashes then clicks back off it continually does this and i am receiving no picture
    Novelist:
    Champion:
  • 203 Answers
Most of the time this problem is caused by the power supply in the set. Capacitors on the circuit board wear out. Usually the ones rated at 10 or 16 volts. You can see a physical bulge of the defective components in most cases. The way to repair this is to either replace the bad parts or the circuit board itself. If you take this to a repair shop the cost should be less than half the cost of a replacement tv or 125-295 u.s. dollars. If you have test equipment and solder/desoldering equipment you can repair it for 20 dollars or less. The only way to be sure that this is the problem is to have someone disassemble the set and check it. But this has been only a very educated guess. Good luck, Russmann.
Posted on May 13, 2010
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
When you turn the tv on the red light on the front(stand by/timer)flashes and the tv starts to come on and then it turns off.
Do you mean the screen turns on briefly or the stand by light just keeps blinking. If the tv turns off after switching on then it probably means a protection circuit fault. Also please provide me the number of times it blinks before it pauses. Awaiting your resposnse.
Regards,
Sai.
Aug 19, 2008 | Sony Televison & Video
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
Plug in and red light flashes and makes a click sound
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 30, 2013 | JVC AV-32850 TV
Panasonic viera th-p54s20a.....tv was on, then switched off,power switch red light flashes on and off, then stops,then repeats flashing on and off
hi the blinking or flashing of stand by light indicator that means their is a error detected by processor which result to switch on/off the tv unit. now since you can not determined the error blinking light.what you need is to open the back cover then first look at the power supply if their is bulged capacitor which cause low voltage the tendency turn on/off the unit.replace with same rating much better to use panasonic brand capacitor you can found at www.digikey.com. now if the problem is not with in power supply try to disconnect the inverter board which supply the back light their might be a shorted transistor or the back light itself has problem which cause auto matic shut down. good luck hope it will help you.
Jul 11, 2011 | Panasonic Televison & Video
Hisense TL2020 - Won't come on.
Lay unit flat on table, remove stand and rear cover. When you remove back, you will see a power supply board in the middle of the set.There are (3)1000mfd @25 volt electroltics and (1)220mfd @16 volt electrltyic that have to be replaced to return to normal operation. This is not something to try if you are a novice as you must observe polarity when installing these caps. But this repair WILL return set to normal operation.
Jul 30, 2009 | Hisense TL1700 17 in. LCD Television
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
TV will not switch on from stand-by mode
keep pressing the channel up button and switch on the tv( plug it to the power). then release the channel button and press power on.
it should work.
Mar 29, 2009 | Panasonic Televison & Video
Tv wont turn on
i have a nlc-3204bc funai hd ready, the stand by light keeps flashing red on and on, can not switch it on
Feb 17, 2008 | Televison & Video
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
119 people viewed this question
Jerry Greenberg
Jerry Greenberg
