Question about Jensen PS2180 Car Audio Amplifier
AMP KEEPS BLOWING - Jensen PS2180 Car Audio Amplifier
  • 94 Answers
Most likely a bad ground connection, clean up where the ground is connected to the vehicle, check the power wire connections too, if that doesn't help route the ground wire to either the chassis or the battery to get a lot better connection, also possibly if you have the amp on full gain (max power) it may be getting a surge from your vehicle which means turn to down a little or get a capacitor.
Posted on Jun 07, 2010
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
30 amp starter fuse keeps blowing on 98 cherokee
you may have a short (verify the integrity of the insulation of the positive wire from that fuse going to the rear window defroster, check the relay & switch.) try to replace the relay.
Oct 03, 2015 | Cars & Trucks
Sony receiver keeps blowing 5 amp fuses
You have shorted output transistors in the amp that need to be replaced.
Feb 14, 2013 | Sony STR-DE425 Receiver
Behringer super x pro.the fuse keeps blowing on the ac inlet(t200 MA).a replacement unit works fine in the system.
When a fuse keeps blowing suspect an overload in either the power supply section or main amp part.
Look for burnt or damaged parts first.
The suspects in the power section are: transformer, diodes, rectifier, voltage stablizer, regulator.
In the Amp Section anything on the heat sink.
Jan 12, 2010 | Audio Players & Recorders
Engine management fuse keeps blowing
My car stopped running without any warning, its a 2005 ford focus, 2.0 and the 20 amp fuse for the engine management keeps blowing, it's number 9 in the panel and I have replaced it twice, both times it blew again, any tips? Also the odometer reads ------ and that's it.
Jan 09, 2010 | 2001 Ford Focus
The fuse keeps blowing in my amp, changed the fuse several times but just keeps blowing!!!
You have an overload in either the power supply section or Main amp section. Culprits in the power supply are the transformer, the Large Capacitors, rectifier, voltage regulator.
In the Main amp anything on the heat sink.
Look carefully for burnt or damaged parts. If there's more than one fuse, follow the path of the one that is blowing it might lead you to the suspect.
Dec 15, 2009 | Alesis RA-150 Amplifier
2009 e250 keeps blowing 10 amp parking fuse then
if it keeps blowing the fuse you have a short in the wiring
Sep 11, 2009 | 2009 Ford Econoline Cargo
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Jensen PS2180 Car Audio Amplifier Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
