Question about Hotpoint WMA46 Front Load Washer
Hotpoint wma46 door lock
Hi, have just read your post on fixya from last yeay when you changed the door seal on your hotpoint wma46 and the door wouldnt lock, i have just changed the door seal on mine and have the same problem with the lock, could you tell me what you did to fix it please?
thanks sean
    President:
  • 1,462 Answers
Make sure door seal is fitted correctly to the cabinet. you may find that all that is required is to push the door harder than usual till the seal beds in
Posted on Sep 07, 2008
Hi door latch as broken off, does anyone know the correct part number? cheers steve
If you look up Hotpoint-Spares.co.uk and select your machine model and you can purchase it on line or ring them up on 01489 782492 they are very helpful. Hotpoint Spares co uk For all your hotpoint spares and accessories
May 11, 2014 | Hotpoint WMA46 Front Load Washer
Washing machine model Hotpoint WMA46 - G wash 3kg load. When on the spin cycle, the machine started rocking violently, such as with a very unbalanced load. I grabbed the front of the machine and leaned...
I think probably the problem was caused an out of balance load.
which would cause the problem you have experienced.
The door catch can be replaced, but it means taking the door apart to replace it, and you may possibly have to replace the door lock as well.
I think it is worth repairing, but you may possibly have to get an enginner to do it for you.
Jan 08, 2011 | Hotpoint WMA46 Front Load Washer
Hotpoint WMA46 door problem
From the symptons you describe, it could be a broken or weak spring in the door handle, which ca be fixed relatively inxpensively, that is where i would start, you can purchase one directly from hotpoint, or possibly a local repairer. if that does not cure the problem, then the odds are it will be a faulty programme module.
Hope this helps.
Jan 13, 2010 | Hotpoint WMA46 Front Load Washer
How to change a door seal on a hotpoint wma58
Firstly remove band holding front of seal then remove the screws from the door lock and push lock through.
Remove kick plate from bottom of machine &take out 2 screws holding front of machine.
Remove soap drawer &take out screws behind it then bring facia forward & slide to right to remove. Take care at this stage not to disturb wiring on cicuit board. An extra pair of hands would be helpfull to hold it.
Remove screws holding front as you did at bottom then lift and remove front panel.
Seal is now easily accessed.
Post back if any further assistance needed.
Thankyou for using Fixya.
Jan 26, 2009 | Hotpoint WMA58 Front Load Washer
WMA46 Door Seal
turn off at mains
remove clamp that holds door seal to cabinet. peel door seal off cabinet.
remove worktop
undo clamp that holds seal to tub. pull seal away from tub.
to refit
lubricate slot in seal that goes on tub rim with washing up fluid
starting at top, fit groove in seal onto rim and work your way round in both directions pushing seal on to tub rim - requires patience and you amy not suceed first time round.
refit inner clamp
fit seal rond cabinet -0 this part is easy
refit outer clamp.
test for leaks on rinse as the water level is higher
Sep 07, 2008 | Hotpoint WMA46 Front Load Washer
Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
Aug 25, 2008 | Hotpoint WMA46 Front Load Washer
WMA46 stopped woking power off mid cycle
hi there the problem you have sounds like the motor has shorted out causing the pcb to blow, sadly this is a costly repair and is usualy not worth repairing as you will need a new motor and pcb
murdozzz
Dec 09, 2007 | Hotpoint WMA46 Front Load Washer
DOOR WILL NOT LOCK
assuming that you didfi not unwire ther door lock, the problem is probably just that the door seal just needs bedding in and you should be able to start by closing more firmly and pushing in till the door lock catches. did you properly seat the door boot on the cabinet?
Apr 07, 2007 | Hotpoint WMA46 Front Load Washer
Hotpoint WMA46 Front Load Washer Logo
212 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
