Question about NAD C272 Amplifier
Speakers a & b are on at all times.
I can't find a way to toggle between speaker sets. The remote for the preamp has buttons for speaker A and Speaker B but it has no effect on the power amp.
    Champion:
  • 211 Answers
Your right, the remote will not switch the speakers.
There's no remote input on the power amp, so there's no possibility to switch between A and B speakers.
regards,
Gerard
Posted on May 13, 2010
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
I can't get sound out of my amplifier and I haven't changed anything. What could be the problem?
Start by choosing FM on a known frequency with a station broadcasting and volume is turned down to a NORMAL listening level. Next, make sure speaker selector isn't the wrong position (make sure "SPEAKERS OFF/A/B/A+B is set to A [or B to match the speaker terminal connections]), check to be sure "Mute" function is not activated by pressing the MUTE button on the remote to toggle it between on & off, Make sure headphones are disconnected. Make sure "PROTECT" is not displayed on the front as this indicates a shorted speaker wire - shut off and repair the shorted wire(s).
If you get sound on FM, but have an issue with another external component (CD, DVD, Phono, etc.) check the cables between the component and the input panel on the rear of the STR-DE595.
I hope this helps & good luck!
Sep 13, 2011 | Sony STR-DE595 5-Channel Amplifier
What is speaker A low imp . how to use speaker B.thank.
The Low Impedance setting is for when you have even one speaker with <8-ohms nominal impedance so you can use bot speaker pairs together. You still need to have an effective total (parallel) impedance of 4-ohms minimum or there may be problems like blowing up the amps.
Press and hold the SPEAKERS A or B button until LOW IMP lights or goes out, as required.
Press either button to toggle that speaker pair on or off.
It's in the manual page 14, 22 and 25.
Jul 03, 2011 | Technics SA-DX940
I have a Pioneer vsx519V receiver, I have connected two Boston cs226 speakers via the Front Speaker Terminals, I cannot get any sound at all - not even from the tuner (integrated) which shows that it is...
Check to make sure your the 'Speaker' switch is toggled to ON. Press the 'Speaker' button on the front panel. Or on the remote, press 'Receiver' button on the top left area then the 'Speaker' button on the bottom right area.
Oct 08, 2010 | Pioneer VSX519VK A/V Receiver
Yamaha m70 amp and c70 pre-amp right speaker stopped working
First, lets's determine if it's the amp or the preamp...
Swap the Left and Right channel cables between preamp and the amp with each other.
Did it stay on the right? = amp problem.
Now on the left? Preamp or source.
Plug any Line Level device (CD?) directly into the amp inputs. Work now? Preamp problem.
ALL sources? Preamp - toggle all controls, especially a Tape Monitor to possibly wipe of any built-up oxides in them.
May 31, 2010 | Audio Players & Recorders
How do i hook up a B4.250.2 Amp to a home sterio?
Hello umbaftroml,
Here's a link to the owners manual: Scroll down to the B4.250.2 and right click "Download Manual".
http://www.lightningaudio.com/scripts/latech.cfg/php.exe/enduser/std_adp.php?p_sid=572kxbvj&p_lva=&p_faqid=154&p_created=1235512138&p_sp=cF9zcmNoPSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9OTEmcF9wYWdlPTE*&p_li=
You'll need some source of 12V DC power which is not available on your home stereo. A 12V battery or DC power supply will work OK. You'll also need to wire in a toggle switch to "trigger" the amp to turn on. Just put the toggle switch inline with a diode for isolation between the power wire and the "remote" terminal on the amp. Flip the toggle on when you need to use the amp.
The speaker connections and source connections are all shown on page 6 of the manual and would in any case, be the same as if you were installing the amp in a vehicle. Be aware that most home stereo speakers are 8 ohms, whereas speakers and subs designed for vehicles are usually 4 ohm or sometimes even 2 ohm. This will not be a problem. you shoud be able to drive 8 ohm speakers, they just won't be as loud because the amp will not produce it's full power into an 8 ohm load. Plug your RCA's into your home stereo's preamp outputs, or if there are no preamp outputs, use the speaker level inputs on the lower edge of the amp.
Hope this helps.
Apr 13, 2009 | Lightning Audio B4.250.2 Car Amp
Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
Jan 23, 2009 | Philips HTS3544/37 Theater System
No output, speakers dead. my system worked until I reached for the remote. I touched a button that lost all output.It is the same dvd, or radio, the radio shows tuned, I have tried everything I know no go....
If your receiver has A and B channel speaker selectors you may want to toggle through the two and see if the sound comes back. That could easily have been pressed from the remote. If not try hooking up only one speaker at a time. If there is a short, or blown speaker the amp will usually shut its audio off so it doesn't damage anything internal. Hope this is helpful.
Nov 23, 2008 | Onkyo HT-S780 System
Help for AVR - 688
check the following1-no headphone jack is inserted.
2-check power cord firmly connected.3-if you have any doubt in remote change the battery with fresh new one4-unplug the system from power and replug it.5-check your volume level maybe it is in low level.-setup your speaker again.6-check speaker cables disconnection-7 -check that mute button not pressed.
Jul 12, 2008 | Denon Audio Players & Recorders
NAD C272 Amplifier Logo
83 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
