Question about Canon Office Equipment & Supplies
Canon2018 canon ir2018 full mechanism diagram for easy to replace upper fixing roll of my canon ir2018 copier
  • 1,219 Answers
Send the e-mail, and ill send it to you.
But shortly:
Remove left door on copier.( Remove plastic cover left from the door ( 3 screws ), disconnect the wires if you have duplex, unscrew the screw on black plastic tape, with pliers pull up the metal pin wich acts as upper hinge.)
When you removed the door, from left side beaneth the fixing assy you will see smal black cover with one screw, remove it so that you can disconnect the connector of fixing film assy, from the right side of fixing assy, remove the cover ( that is the cover wich is long and covers the door locking mechanism - two screws ) Disconnect the 3 conectors. Unscrew the scres that holds fixing assy left side and right side.
Pull towards the fixing assy.
Dismantle it how you see it, but you need to remove the green handle, and remove the axis that have on both side plastic pressure realese pins.
Pls. rate
Posted on May 14, 2010
  • ecsnader Jan 05, 2011
    if you may please send me the schematic specially the location of the fixing film sensor
    thank you.
    here is my email: ecsnader@hotmail.com
  • Hov-UNICOMP Jun 27, 2011
    Hello.
    Could You send me the manual please?
    hovhannes.baburyan@unicomp.am
The canon Copier Brand iR2018 on the screen indicates a System Error E805, when machine is switched on.
Canon iR2018 Error Codes
This weblink states:
Code
E805-0000
Description
Fan failure
The fan is faulty.
Remedy
- Check the fan connector. - Replace the fan. - Replace the DC controller PCB.
Feb 16, 2018 | Canon Office Equipment & Supplies
Canon ir2018 error e808 how to clear
To clear the E808 code unplug the machine for about 10 minutes. If the thermistors are bad the code will appear but will not reset until the fixing film assembly is replaced. If you have tried to repair this machine, make sure you have not left the connector unplugged.
Jul 30, 2014 | Canon Office Equipment & Supplies
Canon IR2018 service manual.pdf
hello friend, you can find the canon iR2018 service manual in below link:
Canon iR2018 service manual:
http://goo.gl/Ckm4yf
thanks
Oct 31, 2012 | Canon Office Equipment & Supplies
Canon ir2018 copier error messages E000 and E003
hi that errors indicate there is temperature failure in the fixing unit maybe caused by AC energy fluctuations . . . verify energy supply is correct . try to connect the machine in another Ac outlet. if problem persist maybe the fixing heater is malfunctioning
Jun 14, 2012 | Canon Office Equipment & Supplies
Where do i find the fixing film?of the ir2018 canon printer. what does it look like and how do i replace it? mukopaje@live.com
hi,
please do following
m good with laser printers but when it comes to copiers. ... I have a Canon IR2018 MFD copier. It started giving me the e007 error. I know this has somthing to do with the fixing film. ... Does anyone have a service manual or a technical diagram of a canon ir2018 copier.....that would help alot. ...
www.copytechnet.com/.../canon/41455-canon-ir2018-fixing-film-replacement.html - Cached iR2018 fuser replacement... Repost for mnamono‎ - 7 posts - 27 Oct 2010
IR 2018‎ - 9 posts - 20 Apr 2010
More results from copytechnet.com »
May 30, 2011 | Office Equipment & Supplies
Canon copier IR2018, error808
E808-0000 Fixing drive circuit failure
Main Cause/Symptom:
- The heater does not turn on.
- A fixing drive motor failure was
detected.
Countermeasure:
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 07, 2011 | Canon Office Equipment & Supplies
Cannon ir2018 system error E007
E007 is fixing film problem. Worn-out fixing film.
Sep 28, 2010 | Canon iR 2016i Black and White Copier
Canon copier iR2018 showing 'system error E007'
your problem in the fixing unit replace the upper fuser roll
Mar 30, 2010 | Canon iR 2016i Black and White Copier
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
217 people viewed this question
old marine
old marine
