Question about Garden
Need operating instructions for Garden Treasures® Pressurized Biological Filter with UV Light - Lowes 60028 - Manufacturer PF1600UV
3 Suggested Answers
SOURCE: Missing a owners manual for a Garden Treasures biological filter
I have the manual, and I can scan it as PDF, but dunno how to send it to you.  I guess this site won't want us to post email. The Canister is very easy to use, just DO NOT remove the metal tension seal ring.  To prep it, you first have to remove the 4+1 top screws; remove the top part (be careful do not pry the clear plastic cover off, that should stay intact); plug the UV in its socket and carefully insert the UV light into the center chamber; reassemble the top with 4+1 screws; attach the two cone-shape nozzles to the "In" and "Out" of the canister, if you use 3/8" tubing for the pump, then no need to cut the nozzles, if you use 1/2" tubing, then cut the 3/8" section off, likewise for the 3/4" tubing, make sure the In and Out should have the same flow to balance the pressure inside the canister; turn the handle to "Work" plug the tube from the pump into "In" and connect the "Out" with the tube return to the pond or water fall; Turn on the water pump and plug in the UV light (use GFCI), wait 30 secs, and you should see the flow from the return tubing. Note:  use a 650+ gph bump at least; DO NOT submerge the canister in the water; put the canister on an even surface; cover the canister against rain and moisture.  My 800-gallon "green" pond clears up in 7-days. Good luck!
M
Posted on May 21, 2009
SOURCE: need replacement pump with light
I have the same fountain and same problem. You need a 10 watt 12v halogen bulb. Just wiggle the tube cover off and pull the bulb out. You can buy replacement bulbs at Lowes or 10 for $7.00 on ebay.
Posted on May 05, 2010
Which is the better radio uv - 3r dsp or the uv - 5r
the uv-5r have more powre on transmit and more chanals to program uv-3 (99) AND UV-5 (128chanels)
Jun 24, 2013 | Baofeng UV-3R Plus 136-174/400-470MHz...
DOES TROY BUILT PONY MODEL # 394358 HAVE A OIL FILTER 17.5 HR 42" CUT
Your owner's manual indicates to change the oil and replace the oil fitler on page 19 as part of the regular maintenance schedule. Whether or not your exact engine application does indeed have the filter is the engine manufacturer's option. Here is your manual.
http://www.troybilt.com/wcpics/TroyBiltUS/en_US/wwcm/769-03502.pdf
Apr 22, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
WHY DOES THE FISHMATE FILTER HAVE 2 POWER LEADS
One lead is for the pump/filter the other is for the UV sterilizer.
Mar 22, 2011 | Fish Mate Pressurized Filter with UVC and...
How do you reset the filter reminder warning light?
Filter Replacement
Filter Replacement Indicator:
Your Defender® is equipped with a Filter Replacement Indicator located on the front
panel. Anytime this red indicator flashes, it is recommended that you call your authorized
FILTERQUEEN® Distributor to order a replacement filter. Anytime this red indicator stops
flashing and remains solidly illuminated, it is recommended that you change your filter. To
receive full benefit from your Defender® and to extend your warranty, it is strongly
recommended that you follow the filter replacement schedule suggested above. Under higher
pollution levels, your filters will need to be replaced more frequently.
The Filter Replacement Indicator is operated by filter time in use and is controlled by an
onboard timer. After 11 months of time in use of your Medi-Filter® Cartridge, the Filter
Replacement Indicator will begin to flash. It will continue to flash until the you reach 12
months of time in use, at which time the Filter Replacement Indicator will stop flashing
and remain solidly illuminated.
After replacement of your Medi-Filter® Cartridge, you must reset the Filter
Replacement Indicator's timer. When the timer has been properly reset, the Filter
Replacement Indicator will turn off.
Resetting the Filter Replacement Indicator Timer:
After replacement of your Medi-Filter® Cartridge per the instructions found on page 7, the
Filter Replacement Indicator's timer can be reset by performing the following sequence of
steps:
1 Plug unit into outlet.
2 Press power On/Off switch to the On ("I") position.
3 Allow unit to start running at low speed.
4 PRESS and HOLD both the Up and Down arrow buttons until the Filter
Replacement Indicator starts to blink.
5 Release both the Up and Down arrow buttons.
6 While the Filter Replacement Indicator is still flashing*, again PRESS and
HOLD both the Up and Down arrow buttons until the Filter Replacement
Indicator turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will
turn off and not flash again for 11 months. If the Filter Replacement Indicator remains
on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when
the buttons are pressed the second time. The Filter Replacement Indicator will continue
to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Note: Under higher pollution levels, your filters will need to be replaced more frequently.
Note: To order replacement filters, call your authorized FILTERQUEEN® Distributor, or call
1-440-846-7800 for the Distributor nearest you.
http://www.filterqueen.com/pdf/defender.pdf
Mar 02, 2011 | Filter Queen Defender Air Purifier
Where can I find the transformer for the fish mate 2000 pressurized uv 9w auto clean?
I have a Fish Mate 2000, water got in to the top where the light bulb & electronics are, replace the light bulb, but the Transformer is all rusted looking, can the electronics be replaced? thank Jean
gkracky@bellsouth.net
Aug 28, 2010 | Fish Mate Pond Filter Compact
I am looking for instructions to a simona collection gazebo I purchased at menards, help.
I am looking for instructions to a Garden Treasures Living 10ft x 12ft steel Gazebo Model #S-1210GZ item #126382. Thanks for your help.
Aug 15, 2010 | Garden
Need replacement pump with light
Jun 20, 2009 | Garden
M
Apr 12, 2009 | Garden
Parts for Garden Treasures 2 tier fountain
You can find replacement parts on amazon. click here Amazon com tier fountain parts and search for your part. Hope this was helpful. cheers
Apr 05, 2009 | Garden
Garden Logo
181 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
