Question about Pentair Minimax NT Heater
Err message on mininax NT, basically says contact Pentair. What is the common error for this?
  • 22 Answers
Call pentair
Posted on May 14, 2010
Tip
ERR code
When a heater is showing the ERR in the display panel, this is what Pentair classifies as a "hard lock out". Basically, there is something wrong with the heater and needs to be serviced. There is no way to reset this code, since there is a malfunction within the heater itself.
on Jul 09, 2009 | Pentair Minimax NT Heater
Getting ERR message on my Pentair Minimax
make sure filters are clean then check to see if voltage on both sides of pressure switch if so check to see if voltage to ignitor if so ohm out ignitor should be about 78 ohm at 70 degrees if ok then see if safety circuit is ok then check to see if 24 volts to the gas valve brown wire and yellow wire
Jul 26, 2014 | Pentair Minimax NT Heater
Pressure SW LED lite and ERR error code with service LED lite.
either you have a problem with the pressure switch or your filter is very dirty or your impeller is clogged. make sure the flow is good, then check the pressure switch.
Aug 24, 2010 | Pentair Minimax NT Heater
Error code e04
If the fan was seized, it is likely bad, even if you freed it. If it doesn't sound the same, or is not as loud as it used to be, it is also most likely bad. If it doesn't move enough air to close the air pressure switch, then you will get an 04 fault, which is an air flow fault. HTH
May 23, 2010 | Pentair Minimax NT Heater
Minimax NT Heater: Heater wont light Err error code. Reset and nothin...
You should try changing out the thermistor first. That is the likely culprit. Not too bad of a repair. The main pcb could also cause this, but i would r and r the thermistor first. HTH
May 17, 2010 | Pentair Minimax NT Heater
Err light on on pentair nt minimax. pushed power button, won't go off. any suggestions?
24 v at the transformer ? if yes unplug thesmostat probe if 888 change t probe if err change t board
Sep 06, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat,
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
May 29, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat, "err" message
temp sensor get the new one with yellow wires.should do the trick.
Jan 19, 2009 | Pentair Minimax NT Heater
Pentair Minimax NT Heater Logo
328 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
