Question about Garland H286 Gas Kitchen Range
Where can i get parts for a garland starfire gas oven
Oven thermostatic us
Our oven pilot light will not stay on - we have to relight all the time. We have had the thermocouples replaced already and it is only two years old. The seller will no longer work on it for us. Says it is our fault in that we MUST be doing something wrong.
Posted on Jul 30, 2010
Grill burners not working correctly. There are 3 burners under our grill. the left one has pilot light on but wont light burner middle and left burners will only work if turned clear up to high
Not familiar with these models, but it sounds to me like it could be a gas pressure problem...? Is there a regulator - sometimes they fail. Are any other appliances hooked into the same gas line? If so, how well are they functioning?
Jan 19, 2014 | Garland/Us Range Gfe60-4g36rr Gfe Starfire...
I have a Garland stove series #G286, the oven won't stay lit.
it sounds like a venting problem, the oven heats up and it not venting,it will put the pilot out.
Aug 27, 2009 | Garland H286 Gas Kitchen Range
How do you pass a plumbing inspections with a 1956 Garland H283 ?
There may be multiple issues here.
Question: Is this being installed in a residence?
If so, I can see why an inspector might have a problem with that. Commercial cooking appliances, *especially* really old ones have next to NO safety devices on them. There might in fact be NO safeties on this thing at all. This means that if stiff breeze blows out the pilot light, it will keep letting gas into the room until something blows up.
This is much less of a concern in a commercial setting where: a) there's always going to be lots of ventilation and b) the gas supply is more than likely going to be interlocked with a fire suppression system.
If he's asking for documentation, it could also be because he's looking to make sure that the gas line & venting are sized correctly. If you're running natural gas, then 1/2" black iron should be sufficient for the gas supply if you're within 50 FT. of the meter, but it also depends on what else you've got tied in. Bumping the gas line size to 3/4" is what I'd probably do anyways
Without more info, there's little else to be said except that arguing with inspectors is like arguing with cats, but less rewarding. :)
Here are *some* SPECS anyways:
24,000 BTU natural gas StarFire burners or 20,000 BTU propane gas StarFire burners. 30,000 BTU race track even heat oven burner
Cheers.
Apr 24, 2009 | Garland H283 Gas Kitchen Range
Garland H283 gas range. Right oven wont come on.
I just read this here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=13&newsdesk_id=117
that explained how to test if the problem is the thermostat. It said to watch the pilot as you open the thermostat to turn on the oven. If the thermostat is ok the pilot should get bigger, if the pilot does not change when turning on the thermostat, then the thermostat is bad.
Mar 04, 2009 | Garland H283 Gas Kitchen Range
I have a Garland Stove and Oven. The oven is not working right.
Hi there, most of the newer unit parts are available still, but not seeing it makes it hard to guarantee. I would advise calling a Factory Authorized Servicer in your area, having a problem with gas entering the oven, and not igniting is a serious problem, and it sounds like the pilot is lit in the oven, but could be malfunctioning.
Here is the telephone for Garland: Tel: 1.800.424.2411.
They can recommend someone in your area, or check your local phone book, for Restaurant repair companies, and contact them.
Hope that helps, and thank you.
Feb 04, 2009 | Garland H283 Gas Kitchen Range
Garland oven does not work
Hi, it is hard to tell for sure, but it sounds like your safety device, the component that keeps the pilot lit, may have failed, allowing gas to the pilot, but not letting gas through to the burner. See your manual on/off valve lets gas to the thermostat, then through the thermostat down to the safety, because you wouldn't want gas to get past there if there is no pilot, and now that part is stuck open, but the rest of the part is not engaged to open and let gas continue to the burner. There is an easy way to tell, under the bottom panel, is a part with a red button ( the safety ) and connected to it is a copper looking tube, or the thermocouple, it can be disconnected by unscrewing it from the safety with a wrench, if the pilot goes out, your safety is mostly working, if not, it is bad, and needs replacement. Let me know, hope that help, and thank you.
Jan 05, 2009 | Garland H283 Gas Kitchen Range
Finding parts for Garland R30 stove
this is almost impossible to do and you will be changing the nsf rating if you have a fire no coverage
Nov 22, 2008 | Garland H283 Gas Kitchen Range
Garland H286 Gas Kitchen Range Logo
231 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
