Question about Samsung DV218AEW Electric Dryer
Motor hums does not turn. dv210 new from lowes
  • Samsung Master
  • 43,501 Answers
There can be many reasons why your dryermotor hums does not turn. dv210 new from lowes - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turningmotor hums does not turn. dv210 new from lowes - 2_bing.gif
Dryer2_binmotor hums does not turn. dv210 new from lowes - 2_bing.gifss= Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 14, 2010
Why don't fan blades rotate?
Sadly Hunter doesn't want people dismantling their stuff and replacing broken or burnt out pieces. They'd rather you buy a new one. If the motor has burned out which is possible a solution depending on how handy you are is simply hunt down a similar replacement and reconnect it.
Make sure the new motor has the exact same leads and connectors as the old one had as some Hunter fans have more than two leads. The model I have has four leads: a black, a white, a green and a red as my model has integrated lighting controls by passed by the motor.
I bought a simple blower motor with the same rating only two wires and with a bit of solder and wire I hooked up the motor and lights separately. The new motor is much faster than the older one so I had to add a tiny 1-way 500 watt dimmer switch to manually turn down the speed.
Aug 30, 2015 | Hunter Dryers
Dryer motor hums but does not turn when start button is pushed
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 24, 2011 | Maytag MDG6000 Dryer
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
Jan 18, 2011 | Kenmore Dryers
We just purchased a new Samsung Dryer model #DV218AEB/XAA the lights will come on but when you attempt to start the dryer there is a hum, the dryer does not spin, then the hum goes away after a few...
Could be a couple things causing this problem. If you can turn the durm by hand without much resistance then the belt may be too loose. This could be because the spring on the tension pully came off or the belt streached. The humming you hear is the motor spinning. If you cannot turn the drum by hand then something could be stuck between the drum and the frame of the dryer.
I would also check that the dryer is wired correctly, because low voltage could be causing the motor to hum but not turn.
Dec 23, 2009 | Samsung DV218AEW Electric Dryer
Duo-therm mod # 57915 not cooling fan?????
need to get at the capacitor for the fan. Try spinning blower when it hums. If it runs then the cap is bad if not the motor.
Aug 13, 2009 | Dometic Rooftop RV Air Conditioner
Pump hums and doesn't want to start at low speed but when turned to high starts right up then can turn down to low speed no problem.
The start capacitor is bad. Take the motor to a local small motor repair facility and they can sell you a new one for about $10.
May 06, 2009 | Emerson Pool & Spa
Motor hums after unit turned off
probably just a transformer vibrating
May 03, 2009 | Panasonic CW-1406BU Air Conditioner
Bought the display unit and water will not work.
hi there the low humming noise that you are getting sounds like the fill valve, this could be due to you perhaps not turning the water back on after fitting the new dishwasher or the fill hose being kinked when the dishwasher was put back ,hope this is of some help to you.
Dec 02, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Emerson quiet cool
a real hummer. humm can be the sound of a short.but it sounds since u did only turn the fan on it hummed ...fanns are blower motors in acs the motor I bet ate it and needs a new one no way of fixing the motor but most are easy and cheap to replace...go or call an ac applance man ...see if he got a good used one for you or go the manufacture take model make serial no. sometimes u can spin the fan while on and it takes off again...this is dangerous so use a plastic long something but will dy again after u turn it off. good luck. CrazyLarry
Jun 30, 2007 | Emerson Quiet Kool 10MW42K Air Conditioner
Samsung DV218AEW Electric Dryer Logo
386 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
