Question about Frigidaire Freezers
I have an upright freezer which does not drain properly. Water accumulates in the bottom and freezes. The ice will get so high it affects the sliding basket. I have cleaned the drain line by defrosting and blowing it out with compressed air. There are no kinks in the line. What is causing the line to not drain?
    President:
  • 1,218 Answers
Good day,
Long winded if your ready.
Frigidaire along with Whirlpool use the shortest defrost cycle on the market. 20 and 21 minutes. Pathetically short.
1. One method is to remove the main heater, and using a piece of #14 solid copper wire, wrap one end very tightly about 6 turns around the heater with the leftover long enough to stick well into the drain hole. Reinsert the heater feeding the copper end into the drain hole. It's a fit and trial method and should extend at least 2" into the drain hole. This will transfer heat directly from the heater to the copper wire and aid in keeping the drain from freezing shut.
2. Changing the timer. If your machine uses a standard 4 prong timer, see if you can buy an Amana or Maytag timer. Their defrost cycles run between 30 and 35 minutes. Huge difference, but you'll need a real savvy counter man at the parts house to get you set up. I do this all the time.
3. Defrost thermostat. This is the small round disk clipped to the top of the coil. Looks like this.
You won't be able to buy it as a Frigidaire part. GE makes it as a kit with all the accessories to install. The part number is WR50X45, WR50X50 ect. The last 2 numbers are the temperature. You want to bump it up at least 5 degrees. The temp is stamped on your old tstat.
For example, if your's is a 50 degree tstat replace it with a WR50X55.
You can choose to do one or all of the above as you see fit, however, In some cases where the water has overflowed and gotten behind the aluminum plate that serves as the drain pan and backing plate, it can saturate the styrofoam and causing it to draw the heat away and nullifying all your work.
If you feel that might be the case, you must unplug the machine and air dry it for at least 2 days. I know, but haste makes waste when dealing with refrigeration equipment.
Good luck my friend. Your not alone with this problem.
Posted on May 13, 2010
Our Whirlpool upright freezer has a sheet of ice in bottom at drain--why?
Melt it again, and check it runs down the small drain hole, If not, clear the hole with a drinking straw. If it keeps freexing up, you may need an auxiliary heater added to the drain hole.
May 24, 2014 | Freezers
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
My upright freezer has a small amount of water inside that freezes, creating an ice slide in bottom.
look at the bottom of your freezer, you will find a small hole or opening, it is a drain exit point of your defrosted water, try to clean it, maybe there is a small object bocking up the way or the hose all away down
Nov 06, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Frost free freezer with ice in the bottom and water dipping off bottom door hinge
Frost Free Freezer have an automatic defrost, which is essentially a heating element which melts any ice. If your door seals are in poor condition or something is preventing the door from sealing the ambient air may be melting the ice more than the drain can accommodate. Check the drain in the bottom of the freezer. Humidity can also cause more water to accumulate, especially if the door seals are not sealing.
Jul 10, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Ice is forming at the bottom of the freezer and freezing the bottom draw shut. it doesn't appear to be leaking and the door shuts properly. it's supposed to be a frost free freezer....
Causes:
High humidity in the immediate area causing condensation to freeze at the door opening
A frozen defrost drain line not allowing water to drain off when the unit is in defrost
A bad door gasket causing an air leak
Some freezers have a heated perimeter to reduce condensation. If the stop working, moisture can accumulate arounf the door perimeter and freeze.
Leaving the door open too long or something obstructing the door
Mar 28, 2009 | Freezers
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not keeping items completly frozen
thius suggests the defrost system not working and the defrost drain blocked. take off the back panel inside the freezer, melt off excessive ice and free the drain at the bottom with hot water and patience
Apr 30, 2007 | Frigidaire 13.7 cu. ft. / 388 liter...
You should check the drain hose inside underneath the freezer.This is done at the back down below. Mine was looped too high and water could not get out. I took the loop off that was holding the hose and now water can drain away without freezing. You can pour warm water down the drain hole to melt the ice in the tube if you remove the grate covering it inside the freezer. I have read that several Kenmore upright freezer
owners have the same problem. I was astonished that this was the problem and I had put up with it for too long, defrosting the freezer every 2-3 months!.Give it a try!
Nov 27, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
197 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
