Question about Refrigerators
Have a LFX25960TT L G fridge . missing ice bucket and Auger needed to deliever ice cubes to door dispenser. Can not find a parts list of what needed service supplyer thinks that ice bucket assembly may be what need but can't find a picture and will order part but if wrong i will have to keep the part. Is thier a olace on the web where cahn look at skematik of parts and confirm what is needed Paul
Hi, I have a lfx25960tt with a deep scratch door. Can I repair the door with some sort of metal scratch remover? Also do they sell just the door metal cover?
Posted on Apr 10, 2008
Out loading auger problems
if by this your saying that the ice dispenser auger has a problem ?
a few things to look at on a ice dispenser
1st remove ice bucket with auger completely out of fridge
look at back of fridge is there a build up of ice there ? if so you may have a leaking water valve for ice maker
carefully inspect the back of ice bucket to see that drive catch is not broken or missing parts
2nd verify that the door to side that contains the dispenser is all the way shut , sometimes ice build up keeps door from closing all the way to allow door switch to say ( door closed safe to dispense ice) this switch is not allways at top or bottom of door but maybe in the middle too
and last but not least , make sure all switches and childlock outs are set correct to working positions and that glass sensors detect the glass in its place
Nov 14, 2015 | Refrigerators
How can we fix our Maytag Refrigerator's ice dispenser?
Start here they have excellent manuals to get part numbers and a lot of times have videos to show you how to do your repair.
Hope this helps
Jan 19, 2015 | Maytag Matag 25.6 Cu Ft Side By Side...
No ice in the ice dispenser since yesterday
the trouble is coming from eithier the micron switch located at the backof the paddle,or the auger motor.It is the motor that rotates when you press the cube dispenser lever located at the back portion of the icebucket,it might got stucked.or its winding is open Try to hve a check ,first open the freezer door, pull out the icebucket, look fr the light switch then maintain the door open,use your right hand in pressing the switch to simulate a closed door position,next use your left hand to press the cube dispenser lever, if the auger motor rotates and you heard a humming sound, it means it is only your ice cubes that sticked together preventing the motor to rotate freely,or there is something wrong with your bucket only,if your hear humming sound only, the auger motor is stuck up, unplug the unit, removed all the screws securing the bracket,disconnect the wiring connector, pull out it out,try to thaw the froozen motor if it is still stuck,wait a longer more or try to apply wd40 oil in between the entangled rotor and core, lubricte.If you hear nothing the winding might be open or there is no supply to the motor., point of check- micron switch- check for continuity,wiring leading to it and the line goin out to cabinet/inside, check the main connector to the bucket area for corrosion or accumulated dirts, And lastly if you are not confident enough to do the job sir better to calla qualified technican to do the troubleshooting sir, safety is our first priority.
Mar 20, 2010 | AEG Santo 7085 KG Side by Side...
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Will not send ice cubes down the shoot just chopped ice and chilled water. The problem started when the freezer door was left open on the fridgeadair fridge.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Oct 14, 2009 | Refrigerators
Whirlpool side by side GD27DQXFW01; ice cubes are not dispensing
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
Oct 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker does not dispense ice through door
Remove the icebucket . Use a hairdryer directed at the forks which turn the auger to dispense ice . This will defrost the auger motor internally , May take a little while though . Close the door and press the handle for cubed ice ocassionally to tell if motor is free . Once free , reinstall the ice bucket .
Aug 08, 2009 | Refrigerators
GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Nov 21, 2008 | GE GSS25LGM Side by Side Refrigerator
Whirlpool Side by Side Refrigerator Wont dispense ice
if you lift out the ice bucket you will see the "gear" that turns the auger. The gear is metal but the part on the bucket is plastic and this can become stripped out. Also check that there is not ice frozen around the bottom of the bucket where an ice cube may have lodged the chute door partially open and melted some of the ice in the bottom creating a blockage.
Nov 06, 2008 | Whirlpool GC5SHEXNS Side by Side...
Water is going to dispenser in door but not to icemaker.
The first thing I would look at is the two solenoids on back of refrigerator. Each of the two have 2 wires. Switch the two sets of the two and then try the water dispenser. If the dispenser then don't work the ice maker should begin filling. If this happens you will need to purchase a new duel solenoid for that fridge. Hope this helps, Sea Breeze
Oct 28, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
150 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
