Question about Diamond Products Mk - 101 10" Tile Saw
Start capacitor keeps blowing. saw starts up
I have a MK 101 wet tile saw and having problems. Start capacitor keeps blowing. Saw starts up slow, runs for ten minutes than trips the breaker. Replaced capacitor ran for less than an hour and blew capacitor again. Any suggestions?
    Problem Solver:
  • 11 Answers
SOUNDS LIKE THE CENTRIFUGAL SWITCH IS NOT WORKING.
THE MOTOR IS STARTING ON THE START WINDING AND NOT SWITCHING TO THE RUN WINDING. THAT IS THE REASON IT IS RUNNING SLOW.
Posted on Sep 09, 2014
3 Suggested Answers
  • 57 Answers
SOURCE: I own a mk 101 tile saw. I purchased used and it
I don,t know what size the breaker is but a motor pulls upto 8 times the full load current on start up so it may not be big enough or it may be weak.
Posted on Aug 27, 2009
SOURCE: i removed the cover on my mk 101 tile saw to
OK MOST Caps aren't polarized, so can go on anyway... Check to see if there is any + or - on the Cap... NO then connect it up anyway .. if yes Phase needs to go to + Neutral needs to go to -.
Black is normally Phase, which probably goes to the motor so the other two, white & blue must be for the Cap.
But unless ya can get a schematic from manufacturer this is only an educated guess.
BE CAREFUL.
Posted on Jan 29, 2010
Cutting porcelain tile with wet saw and it breaks at the end of the cut?
Porcelain tile has to be cut painstakingly slow, especially the last inch or two to prevent the splitting problem you are having. When you are cutting tile, the sawblade rides up just a little as the tile is being fed into it. You'll notice it if you stop pushing the tile through and watch the head drop down just a bit. When you are getting to the last part of the cut, reduce the pressure you are using to push the tile into the blade so the blade can wear away the tile with little pressure and vibration as possible.
Dec 30, 2012 | Mk Diamond MK 370 TILE SAW
Superiorbilt 10" wet tile saw parts
Take a look on amazon for them, here: Amazon com wet tile saw parts. Wish you best of luck.
Thomas
Oct 04, 2012 | Mk Diamond MK - 101 Pro 24, 2hp Tile
Hello ,i was looking for a CAPACITOR for my mk 101,wet saw it is 240V,60hz so any idea please ...thanks
Go to radio shack explain to clerk what you need ,they should stock the 240v, 60 hz capacitor once obtaine you must solder the cap in good luck
Jun 15, 2011 | Diamond Products Mk - 101 10" Tile Saw
I am not sure I can be any clearer than to say the saw dooes not cut the tile square.
the problem is probably the slide cart you set tile on to push it into the blade,on the right side theres a roller you can adjust the the height of the tray,or look at the very bottom of the cutting arm,left hand side,on the outside,where its painted red, theres 2 bolts that hold the cutting arm to the frame of the saw body,try this first, i bet nuts got loose and the cutting arm dropped a tiny bit screwing everything up
Dec 28, 2010 | Mk Diamond Mk Tile Saw Mk-101 Pro24 10in
Looking for shaft lock to change the blade on MK 170 wet saw
Just use a rag and grab the blade. Unless the threads are messed up you don't have to hold the arbor still, just the blade.
Apr 27, 2010 | Mk Diamond MK - 170 Wet Cutting Tile Saw
Tile saw not cutting straight
Sometimes a blade that is set deep enough will walk in this manner, especially if it is a thin kerf blade like the MK Hotdog blade.
Also, a blade which has worn unevenly will do this too.
Jul 11, 2009 | Mk Diamond MK - 101 Pro 24, 2hp Tile
Breaker Keeps Popping
there is something wrong inside the saw.
if you are trying different amperage breakers ( trying a 15 AMP breaker and then trying a 20 AMP breaker) or if you are trying all 15 amp breakers try a 20 AMP
Jun 28, 2009 | Mk Diamond Benchtop Wet Tile Saw
No voltage at water pump plug on MK 101 off switchbox.
The Capacitor is only for starting the main motor and not the water pump. Like you said, if you connect the water pump to 110V it will run so there is a problem with how it is wired to the on/off switch. there should be a white wire (neutral) permanently connected to the pump and the on/off switch should supply power on the black wire when turned on.
Apr 05, 2009 | Diamond Products Mk - 101 10" Tile Saw
Diamond Products Mk - 101 10" Tile Saw Logo
712 people viewed this question
Top Diamond Products Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Diamond Products Saw Expert? Answer questions, earn points and help others
