Question about HP (400745-001) Sound Card
Ive no sound on my laptop its says i have 2 down load sound max but i dont no wat to do
I want to connect Max 2500 with 6 JBL Control 28 speakers 175 watts @ 8 ohms each... please suggest what will be the best connection...series or parallel
first is how u want to run the amp itself ....... the MAX2500 can run in mono (bridged) output or stereo ......... though wat u want to watch is the impedance of the load really with the bridged load being no lower than 8 ohms/1500W (there's reasons for this) and the stereo load where u can have either 4 ohms/750W or 8 ohms/500W so how do u want to run this is first the question ..... all 6 on the bridged output or 2 off each channel (though running 3 would make for complicated impedance load) ..... so u'd run 2 in parallel for a 4 ohm load with 300 watt requirement from the amp and u can drive them to 1.5 times their rated RMS figure so a nice 500 watts :)
Feb 07, 2012 | Phonic MAX 2500 Amplifier
I have a 1988 mitsubishi mighty max that Ive replaced the alternator on 4 times, Ive went through every wire on the truck looking for a short and found nothing, I was wondering if there was an external...
Get the battery checked out, even if it is new. I found out this on mine after I replaced the alternator and the battery was fully charged. After it had run a while it would not start back up, Got it tested at an interstate battery shop and they said it was borderline on the load machine, but the digital $$$ machine said replace battery. Good thing it was still under warranty , free replacement. Been driving ever since then no problems.
Jan 15, 2011 | 1988 Mitsubishi Mighty Max
Ive got a samsung laptop , i really dont know which one but i recently bought it about a week ago and now whenever in the morning i want to switch it on it just shows blue light and no matter whatever i...
this sounds more complicated than an easy solution. Do you know somebody who knows a bit about software and hardware?
If not and you bought the computer just a week ago, take it back and get a new one!
Well, this doesn't sound like a real solution, but bluescreens after one week maybe a hardware problem (maybe RAM).
Dec 28, 2010 | Samsung N150Black Matte 101" Netbook...
M9700 starts up but shuts down few minutes after vista loads
Sounds like it is a problem with the m9700 overheating. I have just repaired an m9700 with this exact issue and it was resolved by taking the CPU heatblock off, removing the dried/caked-on heat compound, and replacing it with my own (Arctic Silver 5).
Was 91c before, now down to 74c max on load (Measured with coretemp). Random crashing has stopped.
Sep 03, 2009 | Alienware PC Systems Alienware Aurora High...
Knocking noise with my kicker compvr 15"
comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
My ps3 have a little trouble loading ps3 game discs
You might need to clean your lens with a DVD lens cleaner disc.
Aug 26, 2008 | Sony Playstation 3 (PS3) Console
Amp. Audiobahn a2300hcx
If the subs are dual 4 ohm voice coils and if your amp is good down to 1 ohm, your best bet is:
  1. Connect the voice coils in parallel ("+"s together, "-"s together). This will make the impedance of each sub 2 ohms.
  2. Connect the subs in parallel.
  3. Bridge the amp to one channel.
This should max the amp out at 2400W, which means about 1200W per sub.
If your subs are single 4 ohm voice coils, do the same steps, but you'll only be able to load the amp to 2 ohms, which means about 600W per sub.
Also keep in mind that box size, type, and quality make a big difference in how subs sound.
Mar 20, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Downloading Music onto Mix Max
If the music is already on your computer, it must be in mp3 format, do the following;
1) Open Windows media Player,
2) Connect your Disney Mix Max
3)Click "sync"
4) "Drag" song to where it says "Drag items here",
5) Click "Start Sync"
Jan 10, 2008 | Disney Mix Max Digital Media Player
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
