Question about Sony BRAVIA KDL-52W3000 52 in. LCD Television
TV shuts off
Fan keeps shutting off which cause the tv to go off
  • 59 Answers
SOURCE: TV cuts on and off by itself
how often does this happen ? is it tripping random
look at the power supply panel for dry joints especially around the transformers etc
Posted on Sep 03, 2009
  • 115 Answers
SOURCE: TV comes on and then shuts off,and a small red l keeps flashing.
If its flashing red repeating groups of three then the lamp door is not detected .
If its flashing in groups of four then a fan is not starting.Look in the vent in the back and spray some canned air into then big fan on the left(looking at it from the back) .That fan may be failing and has gotten to a place where it can't quite start again and just moving it a little with some air will make it work for a while.
If its not one of those two things let me know.
Posted on Oct 22, 2009
techman007
  • 1112 Answers
SOURCE: Sony Trinitron Wega TV keeps shutting off and red
There are two Ic's that need replacing on the Deflection Board (D) board.. These regulate power for the High Voltage and Chopper PWM circuits. The IC location on the board are IC6501 and IC8002
Posted on Nov 19, 2009
ladywinn
  • 5138 Answers
SOURCE: When I turn it on the green light keeps on
Replace your Lamp.
Posted on Dec 03, 2009
gjahn
  • 110 Answers
SOURCE: TV wont stay on. Links light keeps blinking then tv shuts off
First try to reset the lamp timer. You can find the directions in your manual. If it fixes your issue you should replace the lamp as soon as possible.
Posted on Jan 16, 2010
Sanyo tv troubleshooting
If the DLP fan is not running the TV will shut off to keep the lamp from burning up. Replace the fan first...
Also - What was your TV brand and model?
May 24, 2013 | Televison & Video
DLP keeps shutting off
Check Lamp Fan or Fans and it could be that the Lamp is going out.
Oct 01, 2012 | Zenith Z52SZ80 TV
2007 Panasonic 50in Plasma shuts off after being on 30 min sleep timer off, is the problem the cooling fans out/ over heating
Yes, cooling fan could be a problem. Just see whether it goes off during before shut off. If yes, the TV might need service. To know whether the fan goes off first or the TV, stick one side of any thin vibrating membrane such as a silver paper (like the one you see in cigarette packets) on the fan outlet, without blocking it, so that you can see whether it stops before the TV shuts down. Alternatively you can hand an inflated balloon which keeps flying off from the area of the fan and shall stop when the fan stops. I suggest this, in order to save your time looking at the rear all the time until the TV stops. Even then, one is likely to overlook whether the fan stops or TV stops first.
Aug 29, 2012 | Panasonic Televison & Video
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
The fan on my emerson microwave model#mwg9115sl stopped working and now it shuts off by itself is there a way to fix it or someone who i can take it to?
The fan primary function is to keep the magnetron cool while it runs, if the fan stops the thermal fuse senses an increase in temparture causing the oven to shut down. I suggest a tv technician or appliance repair man because there is dangerous high voltage present that can cause serious injury or death.
Jan 15, 2011 | Emerson Microwave Ovens
Oct 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Same problem - tv shuts down
Sounds like you've got a problem alright, It's definitely heat related. I would suggest unplugging it and having it looked at by a professional.
I am an electronics tech and can tell you that you should not try to fix it yourself. There are voltages inside that tv that can literally throw you across a room and kill you instantly,
Also, I advise leaving it unplugged until it is looked at, A short can cause a fire.
Sep 30, 2009 | Sony KV-36XBR400 36" TV
Samsung tv is shutting off all the time.
Do you have enough air flow to cool it?
It may be overheating....add a fan blowing into it and see if that keeps it on.If it does put a strong small computer fan in somewhere to keep it cool.
Aug 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Tv shuts itself off
Look for the computer processor inside the TV. It needs to be cleaned. A can of compressed air will work. The processor is overheating and causing the tv to shut off. Look for the small fan that is supposed to keep the processor cool then remove the dust.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Sony BRAVIA KDL-52W3000 52 in. LCD Television Logo
645 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
