Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
Replace ao smith pump motor - Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
  • Hayward Master
  • 1,384 Answers
HAVE MOTOR CHECKED FIRST. LOOK FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY, USE YOUR ZIP CODE IN YOUR SEARCH.. HAVE HIM TEST IT FOR YOU ,SHOULD BE A FREE TEST. MOTOR MIGHT BE REBUILD-ABLE AND COST AROUND $75.00 .. IT'S THE GREEN THING TO DO AND SAVES YOU CASH !!
Posted on May 20, 2010
    Guru:
  • 351 Answers
Hi ,, the pump motor will separate from the pump housing. there are 4 to 6 bolts around the joint between the motor and the pump. You probably want to remove the pump and motor from the system and get it to a more comfortable place for working. Unscrew the bolts and the motor will come off the pump housing. Then you need to remove the pump impellar. The whole thing goes back together in the reverse steps .. If you go to a pool shop for your motor , they should have an exploded model that you can look at to see how all the parts reassemble ..
Please Vote !!
Posted on May 13, 2010
4 Suggested Answers
  • 59 Answers
SOURCE: how do i tear down impellar housing on ao smith
take the impeller housing cover off. the shaft is threaded onto the impeller. Host the shaft and unthread the impeller.David
Posted on May 25, 2009
  • 279 Answers
SOURCE: Hayward AO Smith Pump Motor is getting electricity but won't star
Is there a manual reset? Some motors have them, usually on the end away from the shaft. ...Lee
Posted on Sep 03, 2009
  • 100 Answers
SOURCE: Is it possible to replace the bearings on a AO
any good electric motor shop should be able to
Posted on Feb 14, 2010
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Instructions to replace ao Smith Centurion Switchless Motor
less hassle replace whole pump if motor overheated ruined seals and possible distortion of pump
Apr 09, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
Replace ao smith century centurion b852
take apart normally impeller screw backwards thread but impeller unscrews normally
Oct 20, 2012 | AO Smith A O Smith Motors A O Smith 3/4hp...
A O smith part 7-177896 pool pump screaming
bad motor replace whole unit if overheating ruining rest of pump
Jul 26, 2012 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
How to replac bearings in century pool & spa motor
if bearings are bad motor overheating and ruining seals replace whole unit less hassle
May 10, 2012 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
I have a Whisperflo Eplus 1.5HP pool pump. It has a A.O. Smith motor. the 50MFD 370VAC capacior is bad and needs to be replaced. Is the Capacitior a run capacitor or a start capacitor? Does it make a...
You didn't indicate exactly what AO Smith motor model you have, but most likely it's Capacitor start/run if it doesn't have a switch. The important thing is to replace with the same MFD as the old so you have the same starting characteristics. Here is a great link on AO Smith motors: http://www.discountpoolzone.com/poolmotor/pump_motor_university.pdf
Aug 13, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Need to replace back half of a.o smith pool motoer
Do you mean A.O. Smith motor? This is the back half of
the Pool Pump. A.O. Smith motors are the most common motor drive for household pumps, so I believe
that you can easily find the replacement. Just specify
the horsepower (HP) rating, voltage: 220/110, single
phase or three phase. Just send your e-mail comment
for more info. God bless you.
Oct 21, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
233 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
