Question about Nokia e65 Cellular Phone
The LCD not light fine ,ave a smoll under light...I dont know how the LCD ave failure. ....what i'm doing?
    Guru:
  • 274 Answers
Its not a lcd complaint, its a complaint from lcd light
so you need to change the lcd light ic
contact any service center to change the ic
Posted on May 13, 2010
Free tv repair advice
Hitachi 42" plasma TV all of a sudden death. Power failure, no lights on the front panels. No signs of life.Found solution through my very honest repairman called Johnny's TV Repair in Hollywood:
There is a kill switch to protect against power surges. Located under the bottom edge nest to where the cable goes in the body, all you have to do is press it back in and voila; LET THERE BE LIGHT and probably save yourself a min $200 trip to the repair shop. Of all the places my friend called non mentioned this switch so next time you have TV problem and can't fix yourself go to this guy if you're in Los Angeles. Johnny's TV 4452 Melbourne Ave Los Angeles, CA 90027 (323) 660-9900 1df09a55-a543-44e3-9508-ff918ce89dd4.jpg
May 26, 2013 | Emerson LC320EM9 32 HDTV LCD TV
I got samsung laptop R580, the screen broke because of falling so i ordered online, and replaced it with new one myself, it was working fine for two weeks but after two weeks the screen went very dim! I...
The inverter could be faulty. The inverter supplies high voltage to the CCFL lamp that provides the back light. The inverter is located at the bottom of the LCD screen between the hinges.
Sep 09, 2012 | Computers & Internet
Hi, I have a 1995 volvo 850. Its not turbo but I dont really know what other specifications you might need to know in order to help me with my problem. The lights on my dashboard, air conditioning and the...
manufactuers put fuse panels insome wierd places . you may want to look on both ends of the dash ,under the dash, in the glove box, and under the rear seat. but back to the dash lights not working, do all the exterior lights work as they should? if so you may want to check the panel light dimmer switch to make sure you have power coming through it.
Jul 28, 2011 | 1995 Volvo 850
Hi, my hp dv2000 screen is blank when I turn it on. It hums and lights up like it's supposed to, but the screen is completely blank! What do I do?
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Nov 30, 2010 | HP Pavilion dv2000t Notebook
Got 1988 buick park ave.car wouldnt start,hooked
You may have damaged the starter when the engine kicked back.
The ignition module may have been defective.....but change the crank pickup too.........more likely it is the cause of the problems.
Change the crank pickup at every tune up..........it has a high failure rate.
If your engine has 250km or 150K miles you may need a chain soon.
Oct 04, 2009 | Buick Park Avenue Cars & Trucks
I have an xbox 360 the red light is coming on do you how i could fix it.Its just one red light
this same thing happened to me, it usually means that you just ave to turn it offf un plug all wires and plug them in, some times this means your system has had a failure and needs to be sent away to microsoft to be fixed, you will know this if your system is not working to perfect standard.
Sep 14, 2009 | Microsoft Xbox 360 Console
Fuse box location on 1998 buick park ave
RIght hand side of the car behind a panel...3 clips hold it pull it off...Under the hood same side of car MASTER fuse box.....GARY KNOWS ALL ANSWERED THIS
Mar 21, 2009 | 1998 Buick Park Avenue
Buick 1990 Buick Electra/Pk Ave Replaced right 9004 head light for low beam failure but no light shines. High beam works fine. Help please. email: autosweeps@hotmail.com
ck the lamp housing for corosion inside and wire condition outside, then use a test light to ck for 12vdc, and continous ground. if ok suspect headlamp switch...etc
Mar 13, 2009 | 1990 Buick Electra
Lcd tv .red light flashes repeatedly but no picture or sound
That usually indicates power failure some where on the circuite board. If you heard a ' POP" a capacitor probably blew out.
If you knew enough to repair it your self, then you wouldnt be asking and if you dont, then you should take it in for repair by a shop, unless its a cheap t.v., in which case, buy a new one.
You would need to locate what poped and try to obtain a replacement part, then soder it onto the board after removing the bad part.
If you dont know what your doing you could shock or kill yourself, start a fire or damage the T.V. further.
The cost for repair may be as much as buying a new HDTV so be sure you know what its going to cost before dishing out cash to a repair shop.
Good luck
Feb 01, 2009 | Computers & Internet
Nokia e65 Cellular Phone Logo
187 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
