After looking in the manual, I read that It takes as input the COUNT of successes in each sample (x1 and x2) and the COUNT of observations in each sample (n1 and n2). Thus your values of x1 and x2 must be integers (whole numbers).. Besides I duplicated your example taking x1=21, n1=43, x2=18, and n2=38 and I did not get the domain error. I was able to draw the graph also. You might want to check your values.
Data Recovery is computer optimization program that displays fake critical security
errors and reports registry, hard drive problems that do not even exist. You can remove this by going in SAFE MODE.
Restart your computer and as soon as your computer turns on hit the F8 key (repeatedly) until a screen comes up
Choose Start computer in SAFE MODE with network support
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
there is only 2 things that can make a trans slip.. low on fluid, which i asume is now at the correct level.. or a blown clutch pack inside the trans itself. which will require the trans to come out to be overhauled,, sorry
Your laptop hard drive is probably damaged from the fall. The reason why diagnostic test after memory fails is that it’s trying to load from the “Diagnostic Partition” which is located on your hard disk drive. You could try to remove and reseat the hard disk drive and see if that works, otherwise you’ll have to take the drive to a local computer repair shop to see if they can retrieve any data. Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience. Thank You.
Have you authorized the player? if not, or youre not sure, go here: http://www.docs.sony.com/release/Authorizing_flyer.pdf
Theres also this documentation which notes your "no data" symptom - http://www.docs.sony.com/release/NWE405-407rev_note.pdf
You will get a "no data" if you tried to format the player through windows explorer instead of through the player, and formatting it again, this time throught the menu in the player should fix this.
Also there appears to be a transfer limit on the sonic stage software. something around 65,000, but who knows, maybe you managed to get there...
Good luck
Could you tell us which error you get? That would help us help you.
