Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
My aqualink shows the pool pump turned on but the pump is not on or running
  • 22 Answers
Its probably the contactor located in the high voltage section of the main control unit. if you remove the cover plates you can see the small wires come thru the smaller section where the ecectronic and low voltage parts are housed then you will see a bunch of clear blocks that have red and black wires that run all over it looks scary. if you look closer there are small wing nuts that hold the square boxes against the wall of the box inside those boxes are contactors it is common that they get stuck in the open or shut position. alot of the time you can tap the box with a blunt end of a screw driver and that will disloge it. you may have to tap each one as you use the side control buttons to turn on and off each function as it is kinda hard to tell which one goes where but you should eventually be able to get it to snap on be careful this is a 220 volt section. if the problem continues sometimes there are one or two extra contactors that are not used and you can swap one out for the one that is malfunctioning and it will save you from buying a new contactor
Posted on May 14, 2010
  • aenchbachert Nov 08, 2010
    I hope this does not apply to you but repeat it around if you will--- Jandy just gave me a web site: bpelectronics.com they advertise repairing jandy boards for $100
Want to program my pool but my aqua link 8265 PDA does not show the "PROGRAM" menu, as per the instructions..
your aqualink has a one touch chip in it you have to program with the hard wired controller if you dont have one you need to upgrade the chip to a PDA chip to program with the hand held
Sep 18, 2014 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Indicates "waiting" and will not show menu
try turning off rs system turn off pda turn rs system back on then turn on pda reboot
Oct 03, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy filter and pump with a aqualink. Pump
Once you turn it off their will be a heater override that will keep the pump running for five minutes so the heater can cool down. Be sure that you give it that time.
Feb 09, 2010 | Jandy AQUALINK RS TELELINK KIT
My spa will not heat. The heater shows that it's working but it will not heat the water.
When you say that the heater shows that it is working is it the heater that shows this or the Aqualink. If it is the aqualink it could be a temp sensor, probally the water sensor that is in a pipe comeing from the pump. But the first thing Iwant to think of is your temp is set on the Aqualink but the temp is not turned up on the heater. If your heater is not compatiable with the link you need to keep the thermostat at max and set to pool or spa to have it work. If it is compatiable it could be in the wireing between the two or you just may need to be sure the Aqualink is set to read and override the heater. Your menu can walk you through this or your book on the unit. Let me know how you do and we can check for further problems in your heater. If so let me know brand and model of same. Good luck.
Oct 24, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Spa does not turn off.
There SHOULD be a valve that you can close to disable the spa.
Sep 27, 2009 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
271 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
