Question about Traxxas T Maxx 3.3 Monster Truck
I JUST GOT MY NEW TMAXX 3.3 4907 AND READ ALL MANUAL AND ALL THAT, BUT I CAN'T START THE ENGINE LOOKS LIKE THE PISTON GETS STUCK. IS THERE ANYTHING I CAN DO TO FIX THIS
  • toshey Aug 09, 2010
    Sounds like engine is on the compression stroke and you need that. How are you starting engine?
  • 88 Answers
If the engine is new and you have not been able to get it to start it is just the "pinch" of the engine. You can heat the engine up with a heat gun or hair dryer and that will cause the metal to expand and make it easier for the motor to turn over. You can also add an extra washer to the glow plug to reduce the compression of the engine. This will also make it easier for the motor to turn over. Just remember to remove the extra washer after you run a couple of break in tanks of fuel.
Posted on Oct 02, 2010
Wont start why?
Small engines on leaf blowers and string trimmers are fuel mixture sensitive. Too much oil in the fuel causes carbon buildup within the cylinder and will cause the piston ring to become stuck within its groove. A stuck piston ring means poor compression and compression is part of the formula for successful ignition...fuel/air and spark are the others. I tore my unit down and checked EVERYTHING...I read a blurb somewhere about carbon buildup on larger engines so pulled the muffler off my blower and could see the piston ring and scoring...I picked at the ring which should be somewhat springy....push down on it and it should push back. Pulled the cylinder off and found the ring firmly stuck...tried to gently pry it free but....snap! Unit is trash as parts are not worth it. This blower ran fine the last time I used it...go to start it for another use and no start. Why? When engine was running the ring became stuck but the rapid engine rpm's kept it running....shut it off and try to restart later and no go because of low compression. Anyone who has a sudden small engine starting problem should ckeck this.
Jun 15, 2013 | Garden
Spark plug and ignition coil problems.... plugged cat?
romove poping plug start engine if thier is major air pressure coming outyou have ahole in your piston replace piston overhaule kitand new piston possible thred damage on head,replace cat,and get a dog:) good luck.
Feb 22, 2013 | 1998 Ford Expedition
Weed eater fb25 won't start
This blower is fuel sensitive! Gas and oil mixture has to be correct. Too much oil will cause carbon buildup in the cylinder. In my case my blower would not start after several uses this season. I checked EVERYTHING....spark, fuel delivery, air filter.....then checked the flywheel which has no separate key....the key is cast into the flywheel. Read somewhere about the carbon buildup so took the cylinder off and viola! The piston ring was firmly stuck in the piston groove plus the cylinder was carbon scored. I tried to gently pry the piston ring free but it was so firmly stuck, it broke. Not worth fixing. Take the muffler off and you will be able to see the piston ring....use a small pick or something to see if the ring is free. If not, proceed to tear down or throw out. I was able to see scoring on the piston and determine my ring was stuck this way. Remember the elements needed for successful ignition...fuel/air...spark....compression. Stuck ring = low compression. The last time you ran the blower the ring became stuck...the engine continued to run because of the engine rpm's but when you try to start at low RPM's, no luck.
Jan 18, 2012 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Can't get it started after new spark plug (gets spark), new gas, good compression tried starting fluid. Whats the problem?
Quick way to check condition of the engine is to remove the muffler. Also make sure that the spark arrest screen is clean. With muffler off, examine the condition of the piston and cylinder. If the piston looks burned and cylinder is scratched, saw will be hard to start. The cylinder and piston should look very smooth. Secondary test to verify condition of engine is to spray plenty of wd40 in cylinder and around piston, then pull the starter slowly. If you see lots of bubbles as you pull, indicates compression is leaking and will be hard to start. If cylinder/piston are in good condition, use new spark plug and retest.
Oct 18, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
2008 vx110 waverunner... friend ran into shallow water (sand) where he said he got stuck (sand bar) light came on (probably overheat) and engine stopped... engine will crank but wont start..what to check?...
The damage that can result from overheating an engine would be piston seizure. Without the cooling water circulating around the outsides of the cylinders to dissipate the heat from combustion, the piston temperature rises higher and higher. As the piston(s) get hotter, they expand. Being aluminum, they expand more than the liner of the cylinder does, and eventually expand to a size bigger than the cylinder. That is when the seizure happens.
At this point, you need to do a compression test on all 4 cylinders. You should have at least 150 psi on each cylinder. Anything lower than that is indicative of a problem.
Jul 13, 2009 | Yamaha 12V Air Pump
About Husqvarna CR250 2004
yes every motor is way bigger then the cylinder mainly because of all the components that the motor has inside of it. the cylinder only gets the piston and rings sliding through it so it doesnt have to be big or anything, manufacturers probably think that this way will save way more money and weight.
Jun 04, 2009 | 2004 Husqvarna CR 250
Accelerator stuck open
This has happened to me before, and i know just what the problem is. Under the fuel tank, the throttle cable goes into a plastic cable housing, and sometimes the cable guard gets stuck out of the housing, causing the throttle to be constantly open. Just take off the tank, follow your throttle cable to find where it's stuck and release it.
May 21, 2009 | 2003 Hyosung RX 125
Traxxas T Maxx 3.3 Monster Truck Logo
311 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
