Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Kenmore 253.26442100 light is on but will not run, replaced the freezer control timer, what else?
  • lesaharris66 May 13, 2010
    ok done that still not on, although we did hear a slight hum in the compressor and then found out we have a freon leak. could that cause it not to turn on?
    President:
  • 1,218 Answers
Good day,
99% of will not run conditions are due either to the timer or the thermostat.
You've done one. Remove the tstat and jump the 2 wires going to it, to see if it starts. You'll have to make a small jumper wire from some #16 or #18 gauge wire bared on the ends.
Posted on May 13, 2010
  • John Hall May 14, 2010
    Good day,
    The humming sound from the compressor if its steady and stays on means it is running. Maybe not cooling but running. If low on freon then that item has to be addressed before anything else can.
    Just recharging does no good, since it will just leak out.
Need manuel for a Kenmore frostless quick freezer model #253.9280410
I don't have a manual but these are fairly simple. On the back inside below is a defrost heater and terminator sorta like this:themobilian_747.jpg
The cold control maintains the temp and their is a timer that either puts it in run for 10 hours or defrost for 21 minutesthemobilian_748.jpgThe compressor relay goes out on these. The defrost heater or defrost heater termination themostat can cause defrost failure if bad.Not much to these babys.
Jan 07, 2011 | Kenmore Freezer 11.6 cu. ft. Upright...
The freezer is running, and the light is all coming on but it is not freezing the contents in the freezer?
Hi and welcome to FixYa. I am Kelly
If your sure the compressor is running and it is not freezing then there has to be a system coolant leak.
Having said that there are a few things to check:
1. Is the compressor in fact running Y / N
a. Yes = coolant level problem or coolant system blockage
b. Not running = (Possibilites below)
1) PTC / Klixon Thermal overload failure
2) Run capacitor failure
3) Temp control failure
4) Automatic defrost thermostat or thermistor
5) Defrost timer or Adaptive defrost control failure (depending on model)
2. Is the compressor very hot to the touch or room temp?
a. VERY hot = unplug the unit for at least 30 minutes and then plug it back in.
b. ROOM temp = any of the above in 1b items 1) - 5)
3. Is the evaporator fan running?
a. Yes = Temp control is ok Defrost system is probably ok
b. No = same as 2b
With a model number I could pass on a few additional things to do. For the moment use the above.
Thanks for choosing FixYa,
Kelly
Oct 18, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Not working like it dead
Go to sears.com and use the parts link and enter your complete model number. it will take you to the specs. and diagram.
this problem could be one of several so i am going to list the possibilities:
freezer is stuck in defrost mode (the timer will do that so it could be the timer)
thermostat not working
as far as this these two parts control operation
i would start 1st with the t'sat. unplug then get to the t'sat take off the 2 wires and jump out those 2 wires (put the 2 wire together somehow but be careful)
make sure the wires dont touch anything (especially you when you plug in)
if the freezer kicks on replace t'stat
if it doesnt them replace timer
hope this was helpful
Mar 11, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Feezer will not stay at zero goes up to 30 I think defrost cyle not working right
Replace defrost timer in refrig cabinet. Located in the light and control area on top of refrig side. Remove cover, there will be a box with wires and a little wheel that is the timer.
Feb 22, 2010 | Kenmore Freezers
Ice under the cover
You can use a hairdryer to speed it up but you need to fix the defrost sytem.
How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 20, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer is on and just stopped working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
I have a 7 year old Kenmore Upright Refrigerator/Freezer on top. I am losing the temp in the fridge part only. The back up the freezer gets a thick layer of ice buildup and when i remove the back panel the...
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Jul 13, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer no digtal light no motor running
if it is an electronic control freezer then the electronic control sounds as though it has failed if there is no digital read out
May 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
140 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
