Question about Olympus FE-280 Digital Camera
Olympus FE280 When I turn my camera on it makes some weird beeping noises. Then when I try to shoot it will not auto focus and all my pics are blurry. Also when trying to zoom in on a subject it powers off by itself.
  • 4 more comments
  • Mudhook Mar 30, 2008
    Same problem anyone know what to do?
  • Paul Hering
    Paul Hering Apr 03, 2008
    Not good news, you probably have a bad lens assembly. The microprocessor is not recieving the info on the lens position.
    It uses that info to do many things. Call for a quote. If it's more than $75.00 dollars. I would just buy another one. I have seen them online at $109.95 Hope it helps. Sumthin
  • mvswim May 20, 2008
    I have the exact same problem and when I tried "solution one" below it didn't work for me...or maybe I'm just not doing it right? Help anyone?
  • tessa and j Jun 09, 2008
    i turn on the camera and it makes a weird beeping noise and the light stays red and the pictures are blurry and then i try to focus or zoom it and it turns off autimatically.
  • Johnathan Williams Jul 09, 2008
    Can anyone else verify this solution?
    Seems like it would make things worse.
  • grammy207 Jul 27, 2008
    My problem is exactly the same. Beeps when I turn on. Will not focus and when I try to move lense wide or tight it turns off.
I just had the exact same problems today, I found this post by searching the Internet for solutions. =) By fiddling around I found a solution that worked for me. If you hold the lens once they're "down" as they are spazzing out, gently but firmly keep your grip so that the lens is flat against the rest of the camera as it tries to expand forward. Keep holding and wait until the camera turns off by itself. Then turn it back on, and voila! It worked for me, the blurriness was gone and I could zoom again like normal.
Posted on May 12, 2008
Thank you very much,
though I need to do it for serveral times.
It is now working fine
Posted on Jul 25, 2008
My Olympus e 510 is one year old. worked fine, but now is taking blurry pics. I tried all focus setting, including manual setting, auto-focus and even tried a different lens, still takes blurry pics. It...
I have the same problem and I strong suspect the circuit board is going bad. No matter what lens I use, distance from subject, etc. makes any difference. Unfortunately, the fix is about $200.00 - and having to invest $200.00 per year to keep it going is not a viable option for anyone.
Jan 23, 2011 | Olympus EVOLT E-510 Body Only Digital...
Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Jul 13, 2009 | Olympus FE-230 Digital Camera
Pictures are blurry.
Try pressing the shutter button half way to let it focus before you shoot. You also may want to make sure the camera is in auto mode and not set to any particular setting.
May 09, 2009 | Nikon COOLPIX S60 Digital Camera
Blurred images on the lcd screen and pics come out blurry
number 1,make sure you have lithium batteries,energizer prefered.2 put it on auto focus.3dont be too close on the object your trying to photograph,and 4 do not zoom in too close on object either.this should solve your problem,good luck,hope i helped
Apr 30, 2009 | Samsung S860 Digital Camera
Olympus fe-230
lens appears to be off track and needs repair
Oct 06, 2008 | Olympus FE-230 Digital Camera
Olympus FE-280 not working properly
the lens could be the problem.. probably need to send to repair before the warranty runs out
Aug 28, 2008 | Olympus FE-280 Digital Camera
Autofocus...images often blurry
upper right of camera back side is bracket with 3 dots [---], press and change to center point for accurate focus ... also in tripod shooting, you can set a delay (timer) for 2 seconds to make sure that the camera is still while shooting
Aug 19, 2008 | Olympus EVOLT E-500 Digital Camera
Pics are blurry
Have you changed the settings in the camera? When are you getting this problem? Is it when you try to shoot in low light?Does it appear like the pictures are shaken or is it out of focus? If they are shaken, use a higher ISO to shoot. If it appears out of focus, first check the lens for some smears. Clean the lens with a clean dry cotton cloth.
Check if there is fungus on the lens (this appears like spider's web or crack marks). If there is fungus, or you are still getting pctures blurred, take it to an authorized service center.
May 07, 2008 | Olympus Camedia C-2020 Zoom Digital Camera
Camera malfunction
mine is doing exactly the same arrrrrrrraaaaaahhhhh
Apr 25, 2008 | Olympus SP-350 Digital Camera
Casio Exilim EX-Z60 Start up and screen problem
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them.
Dec 15, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Olympus FE-280 Digital Camera Logo
483 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
