Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
I jammed my mixer and pretty sure I snapped the nylon worm gear.
My son has already taken off the trim band and the 4 screws that hold the motor housing and lower gear case to the column! We cannot get any part of it apart to get at the gear. Does the part where you insert the beaters come apart? We are not a dummies, but for the life of us, we are not able to get at the nylon worm gear that we think is broken.! We have looked at the schematic and can see the part we probably need but can't get at it. We have cracked the motor housing trying! Regards, Teri Henry
  • Alsgamma May 14, 2010
    Still cannot figure it out from the experts advise
  • 11,896 Answers
  1. Wrap the mixer's wall plug in a plastic baggie and secure it with a rubber band. This is a safety measure to ensure that no grease gets on the plug.
  2. Step 2 Remove the drip cup. The drip cup is the silver ring that encircles the planetary housing. Use a small flat screwdriver on the top lip of the drip cup to loosen and remove it.
  3. Step 3 Lay the mixer on its side. It is a good idea to put a towel or cloth underneath the mixer.
  4. Step 4 Remove the groove pin that holds the planetary gear assembly to the center shaft. Use a 5/32-inch punch to do this. Removing the groove pin allows the planetary assembly cover to be removed.
  5. Step 5 Pry the planetary gear cover down and off the shaft using two flat screwdrivers.
  6. Step 6 Unscrew and remove the five screws on the perimeter of the gear assembly using a Phillips screw driver. These screws hold the internal gear assembly to the gear case.
  7. Step 7 Unscrew and remove the four large screws that secure the base to the top portion of the mixer. Use a large Philips screwdriver.
  8. Step 8 Remove the five screws flat head screws on the bottom cover of the gear/motor assembly to release it from the top portion of the gear case/motor housing.
  9. Step 9 Remove the attachment hub bevel gear from the gear case and motor housing. This can be done by pulling it out of the attachment hub.
  10. Step 10 Examine the attachment hub bevel gear. If the teeth are worn, the gear should be replaced.
  11. Step 11 Clean out the gear case. Remove any and all old grease from the gear case. Pack the gear case with six ounces of new grease before reassembling the mixer.
  12. Step 12 Replace the attachment hub bevel gear. First coat it with a thin film of oil. Then, push it into the attachment hub bearing from inside the gear case. It does not have a washer, so push it in as far as it can go.
  13. Step 13 Remove the three Phillips head screws and lock washers from the worm gear assembly that secure it to the detached gear case bottom cover.
  14. Step 14 Lift out the worm gear assembly.
  15. Step 15 Check the worm gear, the shaft and pinion. The shaft and pinion has 11 teeth on the K45SS; on all other models, it has 10 teeth.
  16. Step 16 Drive out the groove pin with a punch. This allows the gears to be replaced.
  17. Step 17 Reassemble the worm gear, shaft and pinion of the gear assembly, being sure to replace the fiber washers where they originally were located.
  18. Step 18 Place the worm gear assembly and bearing bracket on the gear case bottom cover, making sure the two dowels fit into base of the bearing bracket. Securely tighten the three screws that hold the bearing bracket.
  19. Step 19 Clean the gasket cover of the gear case. Replace the gasket cover by securing it over the dowel and pressing the gasket down.
  20. Step 20 Reattach the top and bottom mixer sections, being careful to line up the shaft in the upper gear housing. Do not force the pieces together; they should assemble easily.
  21. Step 21 Remove the back cover of the mixer to expose the motor. The motor has myriad parts, brushes and steps to disassembly and repair. Simply do not attempt this without the service manual unless you have the knowledge of an electrician.
Posted on May 14, 2010
    THANK YOU!!! We will try this over the weekend!
  • 360 Answers
yes, the part where the beaters is being inserted can come apart. Maybe its difficulf for your to remove because its the first time is being removed.
Take a very close look at it and study very well. The part is clipped together and you will be needing a flat screw driver to peirce through the part. You need to apply some for but not too much in other to get it off.
Take your time and be calm, you will definitely remove the part successfully.
Take care.
Posted on May 13, 2010
  • Alsgamma May 13, 2010
    So I am looking at the schematic, what is clipped and what are we piercing to get to the worm gear bracket and gear. (illus. # 27)
Kitchenaid professional 6000 My mixer has a problem and I know it's in the planetary but cannot figure out how to open it. Any help would be appreciated. John
You need to remove the trim band (one screw at the back) that exposes 4 screw heads where the top cover joins the gear case. There are 4 screws from the top that retain the planetary assembly. I can't remember if you need to remove the motor to expose all of them. The motor is no big deal to remove.
Dec 08, 2016 | KitchenAid Food Mixers
Kitchenaid frozen bearing
Hi Thaddeus, What model is it? If you have taken it apart and checked the worm gear surely you would have stumbled on the frozen bearing if one exists. When you split the gear cases you are in a position to turn everything by hand so any frozen part is going to be pretty obvious.
Cheers Ross
Apr 24, 2016 | KitchenAid Food Mixers
How to check Artisan kitchenaid worm gear
If the planetary head (which holds the beater) is not reliably turning, you can be pretty sure that the worm gear (more properly called a worm follower gear) has protected the motor from burning out by sacrificing itself. The Service Manual may downloaded from:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jun 06, 2014 | KitchenAid Food Mixers
When making bread dough the mixer dough hook jammed. now the mixer makes a terrible racket when used and will not mix heavy loads, ie dough.
In the mixer there is a worm drive gear, it is a fail safe so that you don't burn up your motor in just this insatance. the gear is nylon and when the machine is torqued too much the gear is designed to give out or strip. It is making a terrilble racket because all those chewed up teeth are now being milled and ground up while you are trying to use your mixer. STOP!!! the part costs about $8.00 USD and takes about two hours to fix. You should put a new gasget in but a lot of people dont want to spend the extra $6.00 buck because you have to buy new grease for this fix also, about $25.00 more. You must clean out all the old gear grease to make sure all the chewed up gear teeth atre out of the machine, then repair with new worm gear part and then re-pack with grease and add the new gasket and close up the machine all fixed. about 3 hours time $50.00 and a roll or two of paper towels. (The grease is real messy)
Sep 14, 2012 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid Professional HP mixer, motor stopped while making dough. I let everything cool down and with no attachments it will not turn on. As soon as you turn it on the motor gets hot but no noise or...
Open the Transmission Housing and remove the two screws holding
the Motor. Lift it off the gears and test run it by itself. The motor
should run normally at different speeds. If it does, then you can move on
to the gears. Manually turn the Worm Gear and make sure nothing got jammed.
The Bevel Gear should turn smoothly.
Jul 18, 2011 | KitchenAid KP2671 Professional 6 Series...
I have a KitchenAid Professional 600 Series 6-Quart Stand Mixer, model KP26M1XBS, which no longer works. I was mixing pretzel dough and the mixer stopped turning. I initially just thought it overheated...
Don't worry about the Worm Gear for now. You have to make sure that the Motor
is fully functional by itself: Remove the Transmission Housing Cover (4 screws) and
the two screws holding the Motor down. Lift the Motor off the Worm Gear and set it
on the side (be careful of AC voltages from the Motor and Control Assembly).
Select Stir setting and observe the motor shaft. Is the Motor running? If it is,
Select other speeds to see how the motor performs.
With the motor now fully functional, you can now check the Worm Gear Follower
for worn out/broken teeth. Remember the motor drives the Worm Gear, it then in
turn drives the Worm Gear Follower (you may have to remove the grease to see it)
The Bevel Gear sits right on top of the Follower and drives the Attachment Gear.
Jul 06, 2011 | KitchenAid Food Mixers
HOW DO YOU REMOVE THE PLANETARY ON A KITCHENAID MIXER MODEL KP26M1XGR3
Hi DAVE, Merry Christmas & Happy New Year! The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case: KP26M1, and select one of the first two files listed under Parts List (47) (The first file, KP26M1XAZ4.pdf (304.18 KB), is for a -4 series model and the second file, KP26M1XAZ5.pdf (724.41 KB) is for a -5 series with slightly different insides, so make sure you have the correct Parts List manual.) (For the purpose of this solution I will use the 5 Series Parts manual. Substitute accordingly if you have a 4 Series model.)
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts.
(1) Remove your KA Decorative Trim Band (Illus No. 3) by removing one (1) screw (Illus No. 22).
(2) Remove the four (4) head cover screws (Illus No 14) and lift of the mixer head cover (Gearcase Motor Housing top, Illus No. 1).
(3) Next, remove the two (2) screws (Illus. No. 14) securing your (Speed) Control Assembly (Ilus. No. 19) so you can move the Control Assembly out of the way. This will allow you better access to the Transmission Housing (Illus. No. 4).
(4) Remove the four (4) Transmission Housing screws (Illus. No. 14). Carefully lift the Transmission Housing off the base. The Transmission Cover Gasket (Illus. No. 6) may come off with the Hosuing or remain on the base. (Recommend reordering a new gasket if damaged)
(5) Remove all grease from inside the transmission cover and off all your gears. (This is the messy/fun part. While cleaning away the current grease, be sure to be keep and eye out for metal ‘filings’ that may be suspended in the grease.
(6) Remove the Worm Gear drive assembly (Illus. Nos. 16, 17, and 18) and set aside.
(7) Remove Retaining Clip (Illus. No. 7) from the Planetary shaft.
(8) Remove (lift up) the Bevel Gear (Illus. No. 8) from the Planetary shaft. This may require a little friendly persuasion, but it should eventually slide off the shaft exposing the Retaining Pin (Illus. No. 9).
(9) Remove the Retaining Pin. It should come out easily in either direction.
(10)You can remove the Worm Gear Follower (Illus. No. 10) but once the retaining pin is removed, you should be able to push the Planetary Assembly (Illus. No. 28) down through the Lower Center Bearing (Illus. No. 12). A few taps with a soft faced mallet may be required.
You now have access to the Planetary gear and Agitator Shaft Assembly (Illus. No. 34). Apply the same techniques to remove/replace any components from the Agitator shaft.
Assemble in reverse order above.
Continued in "Comments" - hslincoln
Dec 28, 2009 | KitchenAid K45SS Classic Stand Mixer
Taking the top off my kitchenaid mixer
Remove the back housing by removing one screw and liftingand pulling rearward.
Remove two screws holding the metalic edge trim. This uncovers the seam. Screws are on the back.
Remove four visible screws from the bottom of the head around and near the pillar.
Now gently using a screw driver, push the metallic ring on the mixing head down and off.
This uncovers five more screws about the mixing head. Remove them.
Using a very small screw driver or punch, puch the pin out of the mixing head shaft.
Remove the mixing head housing.
Lift up on the motor housing to remove it.
The motor/gear housing is the top protion of the mixer. Its loaded with grease so do this over a covered countertop or some place easy to clean. The grease won't run, but it can fall out in gobs.
Make sure all sealing surfaces are clean, especially the gasket around the gears. This will insure a good seal. No gear grease in your famous cookies!
Reinstall in reverse.
Feb 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Hobart A200 mixer motor worm gear
sometimes you read of other problems and solutions and it puts you at the edge of your seat. in this case of changing the worm gear on the A200F was cake. when you drop the lower end (3/4 acorn and jam nut), pull out yoke (speed select handle) the center transmision shaft and gears pull right out.worm gear easy to change at this point. if you can change a motor bearing, then you can do this job. Note: change seals and bearings as needed,check all gears,keys and spacers for wear and if you go the mile take gears off drive gears, these are the 2 smaller trans shafts put in lath if you have accsess to one if not roll shafts on flat surface to see that shafts have no bends in them. Also remember when you put the bottom back do not over tighten the jam nut,hold and lock acorn nut, should spin free and have about .016 to .030 movement up or down. Lay out all part on cardboard the way they came out. should go back together easy.
Harry Ooooooooooo
Jan 09, 2009 | Hobart A200 Stand Mixer
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
268 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
