Question about Dell Inspiron 6400 Notebook
My laptop monitor goes dark
I have a Dell Inspiron 6400 laptop with Windows 7. Lately, I'll be working and the screen just goes dark, as if the system went into hybernation. My external monitor continues to work however. If I let it sit for a while, both monitors go dark and then if I move the mouse, I get both monitors back again, but not for long. HELP
    Sergeant:
  • 356 Answers
Hi there! Try this trick...
You can adjust the screen brightness within BIOS set up...
It works with Dell!!!
^_^
Posted on Jun 03, 2010
Dell Inspiron 6400 doesn't boot past dell splash
The hard drive has failed, or windows 7 is not compatable with the laptop. Try installing vista, if this works! there is a problem with windows 7, no change! have the hardware checked for possible replacement.
Jul 01, 2012 | Dell Inspiron 6400 Notebook
I HAVE INSPIRON 6400 LAPTOP. ON SWITCHING ON SCREEN SHOWS BLUE & ORANGE WORDING OF DELL LOGO AND THEN GOES BLANK. IT WORKS WHEN USING AN EXTERNAL MONITOR.
Run the LCD BIST Test
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=04&l=en&s=bsd&dn=1092705
If it passes, replace the motherboard, fails replace the LCD
May 17, 2010 | Dell Inspiron 6400 Notebook
Laptop to TV Connection
Check if you are sending the signal to the external monitor. On my laptop with Windows 7, I can right click on an open section of the desktop and choose Graphics Properties. In this window, I can choose to send the display to the laptop's internal monitor, the external monitor or both.
Pressing Crtl-Alt-F1 will force the video onto the external monitor on the fly (Crtl-Alt-F3 goes back to the laptop's screen).
When I have added a second monitor to a desktop, I needed to reboot and allow new hardware to be found before the related Screen Resolution (right click on the desktop again) let me find the second monitor and choose if this was a duplicate or extended screen.
I hope this helps.
Mar 08, 2010 | Dell Inspiron 6400 Notebook
Monitor does not work, computer starts up, dell prompts load, windows prompts load then screen goes black. i can hear everything loading but no display.
connect an external monitor on your machine and check if display is ok on the external monitor. if yes, try to re-install your video driver and check if display is ok on your laptop.
if both doesnt have display (external monitor and laptop's display) i suspected your lcd display is faulty.
Jun 30, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 display goes off < 1 min after switch on time
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
The buzzing sound is most likely the inverter problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 26, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron password fault
Hi my inspiron 6400 cannot boot up after trying several time .I press switch on, then after 3 second it goes off again.Battery fully charge.
1)battery new
2)rep used mother board
3)rep touch pad
4)rep keyboard
I hope anyone that know this fault .Kindly help me with the issue.
Mar 08, 2009 | Dell Inspiron 6400 Notebook
The monitor in my computer turns dark when i turn the laptop on
That sounds like you have something loose ..
Here is an on-line service manual for that
I would look specifically @ the LCD/monitor lead and its connections
Jan 01, 2009 | Dell Inspiron 6400 Notebook
Laptop goes dark
You can refer to this document for display assembly. It looks like the display is going bad. By checking the seating of the display cable, you're isolating the fact that the cable is connected.
http://support.dell.com/support/edocs/systems/ins6400/en/sm/display.htm#wp1022270
Hope this helps :) Kindly leave a rating. Thanks..
Nov 27, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
355 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
