Question about Acer Aspire One AOA150-1570 Notebook PC
Won't turn on. On button glows green and harddrive light flashes and goes out. On button continues to glow. If I hold the on button down 5 seconds it goes out. It was working fine, I turned it off and connected the charger. After fully charging it acted up.
    Scholar:
  • 92 Answers
*This method only applies to Aspire ONE A150 only
1) Format USB memory stick with FAT file system.
2) Download BIOS for A150
http://global-download.acer.com/GDFiles/BIOS/BIOS/BIOS_Acer_3310_A_AOA110%20&%20AOA150.zip?acerid=633850493862245097&Step1=Netbook&Step2=Aspire%20One&Step3=AOA150&OS=X01&LC=en&BC=Acer&SC=PA_7
3) Extract all files the downloaded file and place FLASHIT.EXE and BIOS file onto the memory stick
4) Rename BIOS file to ZG5IA32.FD
5) Turn netbook of, with power AND battery connected
6) Plug in memory stick with BIOS file and Flasit.exe
7) Press and hold Fn+Esc the unit will go on, hold until power LED is flashing then release keys. If it does not flash, then release and press power button once.
8) You'll notice the LED of both the usb memory stick and the power LED will flash together.
9) After a few seconds the flashing will stop and the unit will reboot or switch off completely.
^^ this is a copy paste from my own solutions
Posted on Jun 02, 2010
Testimonial: "I tried using this method but it didn't work. I guess it's off to the 'puter doctor. Thanks for the help!"
  • maurelius Jan 18, 2011
    Goodstuffman
    WORKED FOR ME!
    thanks
Hi my lj 1010 printer is not initialising at all When i trun on the printer after blinking all the lights one by one its red light keeps glowing There is no gear movement at all I have good experience in...
try to do cold reset:
  1. Turn the printer off.
  2. Press and hold down the green GO button.
  3. Turn the print on while continuing to hold down the green GO button for at least 5 seconds, but no longer than 15 seconds. During this process, the attention LED (!) turns on.
  4. Release the GO button. The printer is ready if the green ready light is steadily on.
Dec 17, 2013 | Office Equipment & Supplies
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Dryer won't light. Igniter glows, then turns off,
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 25, 2011 | Frigidaire Dryers
Message is stating: The ink absorber is almost full-Press the RESUME button to continue printing. Call service center!!.. How do I fix this problem?
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash
if that not resolve the problem
press resume button 2 minutes it will reset your cartridge, for me this can solve the problem
Mar 17, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
I have a roper gas dryer model rdg4440sq0, the igniter glows then the flame lights. Then the flame goes out and doesn't light up again. When it cools down and i restart the dryer the igniter glows and...
If when the flame goes out ...Check to see that the igniter glows...If it glows and the gas does not light then replace the valve coils...Very common problem.....The coils are to weak to hold the valve open..
Apr 20, 2010 | Dryers
The adapter to my Western Digital Book does not respond
The monitor requires a adapter with a current output of 4 amps. but the Western Digital Book adapter can only supply 2 amps (half the current required by the monitor).
This means using the WD adapter on the monitor will stress this adapter beyond its capacity and continual use of this adapter on the monitor will cause it to fail and/or switch off if it has overload protection.
If you are having problems with the 2 amp adapter on the WD Book, then the power adapter could be faulty or it maybe OK when the adapter cools down.
I suggest you get a 12 volt 4 or more amps adapter for the monitor.
You may need an adapter for the WB book too if the adapter is faulty.
Dec 06, 2009 | Western Digital My Book Essential Edition...
1997 VW JETTA DIESEL GLOW PLUGS
The glow plug relay is responsible for the duration of glow plugs, this needs to be the starting point. You should get a 12v out for so many seconds when ignition is switched on.
I have taken the cover off relays in the past, cleaned up the internals, sprayed with circuit cleaner and got plenty more years out of them, worth a try.
Nov 21, 2009 | 1997 Volkswagen Jetta
Red on print is coming out pink
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
  3. Verify that only KODAK branded ink cartridges are installed.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door, then make the same print.
If issue still continues:
  1. Verify that inkjet paper is loaded in the paper tray.
  2. Press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes green. The On/Off light continues to flash during the cleaning procedure.
  3. When the On/Off light glows a steady green, press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes, then wait for the demo sheet to print.
the printhead for your printer is in need of replacement. Contact Kodak
Best of Luck
Nov 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Not all the colors print
Best of Luck
Nov 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Poor black print quality black prints greenish grey
Best of Luck
Nov 16, 2009 | Office Equipment & Supplies
Open Questions:
See all Acer Aspire One AOA150-1570 Notebook PC Questions
Acer Aspire One AOA150-1570 Notebook PC Logo
551 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
