Question about Kallista Michael S Smith Loft One-Piece Toilet with Seat and Chrome Trim
Toiliet Drips in bowl for a while after you flush
We bought some Kallista toilets 7 years ago at a Kohler fire sale. They are beautiful, but we where told they were european style which meant they flushed differently I guess. They did say that they will drip a bit after you flush, but our one seems to be dripping a lot longer now < 30 minutes and then stops. It does not drip enough to cause it to refill, it is just annoying. I did notice that the water line mark on the tak is lower then the fill tube waterline (which I think I replaced a year or so ago) and the tank fills to the fill tube line. Could it be that I need to adjust the fill line to the tank?
  • 349 Answers
Check flapper out and adjust water level in tank to proper level. If you get level right and it still does drip it sounds like the flapper is not sealing correctly to shut off water.
Toilet flappers are not to expensive and you can touch it with your hand and if you get a black residue off on your hands that a sign it needs replacing.
Posted on May 14, 2010
Kohler 84296aa
This part is available at Home Depot hardware stores.
Oct 09, 2017 | Home
Memoirs leaking from seal between tank & bowl. Just replaced the gasket and still leaking
In 2008 I bought the Memoirs model that Lowe's was selling. I've had multiple tank/bowl gasket leak problems. When I went to get a replacement gasket this weekend, Kohler had changed the style of the tank/bowl gasket assembly in the current Memoirs model that Lowes sells. I wonder if this is because the old gasket assembly is known to be defective and prone to leaking?
When I called Kohler, it took two customer service associated, but I was granted a WHOLE NEW TOILET with the new style of tank/bowl gasket assembly. I just had to have the receipt for the (3 yrs ago) purchase. Kohler e-mailed a letter for a replacement toilet within about 15 minutes and before the end of the day, I had a whole new toilet in my bathroom.
I'm not a contractor. Just an average homeowner, so I can't say for sure that the old style (large, black, plastic rectangle on the bottom of the tank and a rather thin gasket ring) was defective or not. (At first Kohler offered only a replacement tank, but after hearing the number of times both I *and* plumbers have replaced the gasket, they did authorize the replacement of the entire toilet.)
Apr 10, 2011 | Kohler Home
I'm pretty sure i need a new flapper but can't find one specifically labeled for kallista michael Smith Town toilets when I search for parts/flappers. Can you suggest another brand toilet whose flapper...
Hello, I can assist you. The flapper part number you need for replacement is GP1078440. You can purchase this item from any of our authorized locations. To find a showroom location near you please visit www.Kallista.com or call our customer service team at 1-888-452-5547.
Oct 02, 2010 | Kallista Michael S Smith Country Mahogany...
Kohler 81100 water fills tank area and over flows
check and adjust float level or float/arm possible set to high or fill tube damaged or has debris jamming valve opening
Apr 20, 2010 | Kallista Michael S Smith Loft One-Piece...
Kallista toilet running. How to fix?
If you have lifted the float up and the water is still running then the washer has gone. As an explumber it would be easy for me to resolve, however you should get a plumber out to this one it sould not cost more then the call out charge and should take them 10-15 mins to fix the part costs 20p
Apr 19, 2010 | Kallista Michael S Smith Loft One-Piece...
Toilet takes vey long to fill the tank.
More then likely the power valve in your flush master ball valve is out.. Replace flush valve and should fix problem. Home depot sell fluid master for like 7.50
Mar 02, 2010 | Kohler - Toilet - Two-piece - Highline -...
Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Aug 16, 2009 | Kohler Toilet - One Piece with Ingenium...
Need to know which cadet to install--3 or 4
I only install Kohler commodes and have never had a problem with clogging. All of Kohler commodes have a 3.5 inch flush valve, just pick the style you want.
Jul 08, 2009 | American Standard Cadet 3 Right Height...
Can't change the toilet seat that broke on kohler rialto
If your problem is like mine your toilet seat is loose and swivels when you sit on it. If you try to tighten down the screw it won't tighten. Use instructions above to remove old hardware.
To fix with new hardware
Purchase Hilti brand 3/16" x 2-1/2" Toggler Brand Toggle Bolt (Home Depot sells the kit). Kit comes with 10. You will only need 2. My last repair lasted about 8 years (with new kit = 40 years left or the purchase of a new toilet - whichever comes first). Set comes with 3/16 flat head screws. I recommend purchasing 3/16" 2" round head screws with matching flat washers. Sink Metal Toggler into hole with toggler pointing straight up (it's attached by long plastic legs). As it goes in the hole it opens up. Pull up on the plastic pull rings as tight as you can until the toggler is tight up against the inner porcelain of the bowl (similar to tightening cable ties). Line the seat up with the holes and it's new plastic adapter (that won't slip into the hole courtesy of Hilti). Slide washer underneath round head screw but on top of toilet seat assembly and screw directly into the newly installed toggler which is sunk in bowl/abyss receptacle. Repair should take around 5 minutes.
Feb 22, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Kallista Michael S Smith Loft One-Piece Toilet with Seat and Chrome Trim Logo
314 people viewed this question
Top Kallista Home Experts
john h
Tom Chichester
Are you a Kallista Home Expert? Answer questions, earn points and help others
