Question about IOGear GCS634U KVM Switch
IOgear KVM not working with laptop
I have an iogear usb KVM switch. I have 2 windows 7 machines. My desktop connects to the KVM fine and i can use my mouse keyboard and monitor all fine. However my laptop is all plugged into the switch but the switch does not recognize it. The laptop even installed all the drivers when i plugged in the switch but the light on the switch doesnt come on indicating that it is connected and I cant switch to my laptop. Any suggestions?
    President:
  • 2,923 Answers
First, you have to make sure that the KVM switch is directly connected to your laptop, and NOT to a docking station.
This KVM switch is designed to work with direct connections to the computers.
Second, the light indicator on the KVM switch is not an indicator for power. It's an indicator to see which port is active. If your laptop is connected to port 2, but the focus of the KVM is in port 1, then the port 1 will have a light, not the port 2.
You may also refer to the user manual of the KVM.
Thank you!
Posted on May 18, 2010
2 Suggested Answers
  • 5603 Answers
SOURCE: repeated IOGear KVM switch failures
As a wild guess, it sounds like a static discharge MIGHT be affecting the switcher causing it to crash.
Try increasing your humidity to 40% and grounding yourself before touching the keyboard... This is the season for these static electricity problems... get nipped all the time and you MAY not even feel it to be enough to zap the switch.
Posted on Jan 11, 2010
Testimonial: "Great idea, Fredy. I am having static problems all the time in my office. I will make a ground pad on my desk top. Thanks"
USB Mouse works, keyboard does not
You will need to update the drivers on the computer for the docking station. It will be the windows seven drivers or lack of them that is causing a failure to remap the usb ports that the wireless dongle is plugged into.
May 25, 2017 | IOGear GCS632U 2-port KVM Switch
I have been using my Iogear kvm switch for almost 2 years now to switch between a desktop and a laptop, both Windows XP. I unplugged the laptop in a hurry to go do a presentation, and plugged everything...
This almost sounds like the display setting on your laptop was changed to an external device. Most laptops are designed to be hooked up to an external display, such as a monitor or projector, specifically for presentations. You can alternate the display options in the following ways:
  1. Laptop display only
  2. External display only
  3. Laptop+External clone
  4. Laptop display + extended desktop on external display (dual monitor setup)
Check your laptop display settings and make sure that it's not in presentation mode (options 2-4) before connecting the KVM switch to it. It may be recognizing the KVM switch as an external display in option 4 mode.
Mar 25, 2011 | IOGear GCS634U KVM Switch
I have an IOGear GCS1734 KVM switch and two Windows based machines. I work for the gov't and we have to use a CAC Card. My keyboard has a slot/reader for my CAC card to verify my credentials. If I...
As far as mouse is concerned all you need is PRACTICE, and there may be a compatibility issue with your keyboard or the wire you are using is not fine, coz the kvm switch is definitely ok when used with 2 systems.
Oct 19, 2010 | IOGear USB gcs1734 4-port KVM Switch
My iogear KVM switch will not toggle between machines
Try following the this link and see if it helps. It helps to explain how to connect the keyboard to the KVM since the keyboard port is the only port that will recognize the port switching commands.
http://www.iogear.com/support/faq/id/318
Jul 17, 2010 | IOGear GCS632U 2-port KVM Switch
I am using a laptop desktop with the KVM GCS632U Iogear switch. Has always worked great but just started to give "input not supported". When it boots up in Windows shows on screen then shows the input...
If you are using a docking station with laptop try directly connecting the KVM cable to the laptop. Also try swapping the cables between the two computers to see if you have a problem with a bad KVM cable. If you have a bad KVM IOGear has a three year warranty on their KVMs and you should be able to contact them to get a replacement.
Jul 14, 2009 | IOGear GCS632U 2-port KVM Switch
Iogear MiniView Micro USB Plus KVM Switch (GCS632U) Problem
The GCS632U does not have any form of display emulation which may cause video problems if the boot up is not done right. What IOGear recommends is when booting up a computer the KVM should stay on that computer until it comes to a desktop. What this does is it allow the KVM to pass the EDID information from the monitor to computer and that should help.
Jul 03, 2009 | IOGear Computers & Internet
I have an iogear usb kva switch connected to two PCs (one desktop; one laptop). It used to work fine with a wireless keyboard (HP), but after I replaced it, it stopped allowing me to switch between PCs...
Hi ther. make sure that you connect them to the correct port. If using a wireless keyboard, connect the receiver to the keyboard port. check underneath for the keyboard icon. Make sure that the receiver is connected to that port.
May 09, 2009 | IOGear GCS632U 2-port KVM Switch
KVM unresponsive
Greg,
Try swapping the KVM cables from the 2008 computer into the Vista computer and see if the problem follows the 2008 computer. This KVM gets the drivers it needs from the OS and the IOGear web site does not show any support for 2008.
Jan 16, 2009 | IOGear GCS632U 2-port KVM Switch
Iogear KVM Switch Not Working at All
jerk_shop is correct, the GCS632U does get the power it needs to function from the USB ports of the computers it is attached to. Make sure the USB portion of the KVM cable is plugged directly into a computer without the use of any USB to PS/2 adapters. You will also want to make sure that at least one computer is turned in order for this KVM to function.
Dec 09, 2008 | IOGear GCS632U 2-port KVM Switch
IOGear 2-port KVM Switch (Keyboard Issue)
I have had the same problem off and on since I bought my Iogear 2-port kvm switch over a year ago. I have a DYNEX wired, multimedia, usb keyboard and a Dynex wired usb mouse. The operating system on my desktop is Windows XP, SP3 and on my laptop it's Windows XP professional.
Yesterday, my keyboard "died" on me about 8 times and each time it requires unplugging the keyboard usb cable from the switch and my laptop, rebooting, then plugging the usbs back in. Really, really frustrating and annoying. I'm not a techno guru, but I got to thinking that maybe the keyboard driver might be the culprit. I decided to go to Control Panel, clicked on Keyboard, then Hardware/Properties/Driver/Update Driver. I clicked on "update driver" and let it find one automatically. It took what seemed like a long time for it to find the driver but it found one. The device name changed to KeyMaestro P2360, the driver updated, and I noticed 2 additional files were added to the System 32 directory.
It's only been a day but so far so good. My keyboard hasn't failed yet since the keyboard driver update. I don't know if this is the solution for you or not, but it seems to be the one for me. I'll know for sure if I can through a few days without it failing again.
Dec 04, 2007 | IOGear GCS632U 2-port KVM Switch
IOGear GCS634U KVM Switch Logo
692 people viewed this question
Top IOGear Computers & Internet Experts
castletech
castletech
Jose Velazquez
Jose Velazquez
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
