Question about Polaroid i534 Digital Camera
How to unlock protected card on i534 - Polaroid i534 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Polaroid Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on May 13, 2010
Testimonial: "right on the money thanks a bunch..."
Cannot get memory card out of camera?
Using a fingernail, push down on the edge of the card as if to push it further into the machine. It should pop out a little, allowing you to grasp it and pull it out.
Aug 14, 2013 | Polaroid i534 Digital Camera
Cannot load pictures to computer using usb cord for i534 polaroid camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Feb 12, 2012 | Polaroid i534 Digital Camera
Cannot unlock protected card
There should be a metal tab on the memory card.Pull out the card.The tab slides back and forth.One way is locked,the other is unlocked.Slide the tab to the other position than it is in now.You should be all set.Good luck,Greg
Oct 31, 2010 | Fujitsu Cameras
I534 camera protected card. how do i unprotect camera will not take pictures
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Aug 22, 2010 | Polaroid i534 Digital Camera
I have a i534 Polaroid digital camera and its locked on protected mode. I'm unable to take pictures and can't find my manual.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 07, 2010 | Cameras
I534 memory full, won't clear
Downloading pictures copies them from the camera to the computer, leaving them on the camera as well.
The best way to clear memory (either internal or a memory card) is to format it. Consult your manual for the procedure to format the appropriate one.
Jul 30, 2010 | Polaroid i534 Digital Camera
Format memory card on i534
Hi Mr Varshap4
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Nov 19, 2009 | Polaroid i534 Digital Camera
Camera said memory full but I have memory card
You need to format the SD card before it will be used by the camera. Formatting instructions are in the manual.
Apr 27, 2009 | Polaroid i534 Digital Camera
Need a copy of owners operator manual lost mine need a new one.
Below is the link to the manual for your camera. You can download it for future use (pdf) format.
http://www.polaroid.com/service/userguides/digital/cameras/i532_ug_en.pdf
Enjoy, and thank you for choosing Fixya!
Mar 29, 2009 | Polaroid i534 Digital Camera
Polaroid i534 Digital Camera Logo
81 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
