Question about Epson Stylus 880 InkJet Color Printer
Printer not printing
Drivers all included on new MAC with OSX 10.5. Printer is identified in Print manager box and can be selected. Print instructions are received, spooled and 'printed' (even listed in completed jobs) according to the script but nothing happens at the printer end!
  • Anonymous Jul 22, 2008
    Nearly identical issue following Leopard upgrade, only difference being
    job listed as "completed". Updated Airport firmware. Deleted and added
    printer. Turned off printer and Airport. "Printer Sharing" turned
    on.
  • 514 Answers
Double check that USB is fully seated on both ends.
OR
make sure that (if IR remote) have the same settings and address'.
Posted on Dec 19, 2008
SOURCE:
Mc3300dn print drivers
What version of Mac OS X are you using? You can find it by choosing "About This Mac" from the Apple menu.
Dec 24, 2013 | Minolta magicolor 3300 Laser Printer
My printer is not working since you repaired my computer
FixYa does not repair computers, the members of FixYa offer advice on how to fix computer problems.
If your computer had Windows re-installed then you need to install the printer driver for you model printer before you can print anything on your printer.
Apr 17, 2011 | Computers & Internet
When there is a site I log into if on my mac OSX 10.5 4 even though a USB cord is connected and the wireless light is on when I press file on the Mac and go to print the HP J4680 does not print what is ...
1. click a text file to print
2.on the drop down menu for printer select printer (there may several listed)
3.if printer not shown then click "add printer"
4.locate your printer model and install
5. This may require you to go to the manufacturer site to download the updated drivers.
6. check the Printer installation manual for step by step instructions
Located on the CD that came with the printer.
Sep 29, 2009 | Apple MacBook Pro Laptop Computer with...
I changed my Mac OSX back to 10.3.9 after Leopard was not compatible with Photoshop 7. Had the Epson Stylus R1800 working just fine before, and I can get it to print now but I don't have any controls when...
You need to trash and re-install the drivers.
Pls follow the instructions to trash drivers on 10.3.9:
- Go to printer set-up utility or print center. Highlight the R1800 under the printer list then delete it.
- Go to library, then printers. Trash the whole epson folder.
- Empty the trash
- Restart your mac.
To re-install the drivers. Pls follow the instructions:
- Log on to support.epson.com.
- Click on printers to the left of the page. Then click on inkjet under printers. Click on the R1800 to the right of the page.
- Click on macintosh under drivers and downloads. Click on the 3rd driver down (i.e. Printer Driver v2.1aA / epson12113.dmg. Then click on download now.
- Click on No thanks i prefer not to receive this information, then click on the accept button. It should download automatically.
- Click on the mounted icon on your desktop that says epson12113.dmg then click on the visex installer. Go ahead and install the driver.
- Add the printer. make sure that your printer is on and plugged into the mac.
Go to print center or printer set-up utility. click on the printer under the printer name then click add when it allows you to.
- try to print something.
if you need more assistance. pls let me know.
Sherlyn C.
May 14, 2009 | Epson Stylus Photo R1800 InkJet Printer
Where to disable color management in printer driver dialog box
When you go to print.  In the box that say's print with printer/presets there's another that say's copies and pages, scroll down to Color Management. Then you will see a Off (No Color Adjustment). Try that and also in the same dialog box is Print Settings that's where you put your paper type selection. Hope this helps
Dec 18, 2008 | HP Photosmart D7460 Printer
Cannot print from Apple MacBook to Canon MX310
First, check your USB printer connection to your Macbook from your Pixma MX310 printer.
If the USB cable is securely seated, make sure you have installed the updated drivers for your version of Mac OS X. Here is the Link:
Canon Pixma MX 310 Drivers for Mac OS X (v10.6/10.5 and earlier).
If you have already updated your printer drivers to the most current Canon Pixma update for your version of Mac OS X, then click on the Apple menu icon, located in the upper left corner of your screen and select System Preferences.
• From System Preferences, select Print & Fax.
• Within the Print tab, make sure you can see your Canon listed in that window.
If you can, proceed to perform a test print on any document you have on your desktop or folder of choice. If this does not help, from within the Print tab, select the Canon and press the "-" Minus button and remove that printer.
• Once it is removed, now click the "+" button
and re-add your printer.
• Once it has been added, attempt to test print again.
This should help get your printer back to printing again.
Regards,
-Mactechtrainer
Dec 02, 2008 | Canon PIXMA MX310 All-In-One Printer
I need to install HP deskjet 6940 on my Powerbook G4. I am operating on MAX OSX 10.4.6
If your printer does not appear in the Printer pop-up menu, find and install the appropriate driver. Check any CD-ROM discs included with the printer, or the website of your printer's manufacturer. Only users with an administrator account can install software.
Tip: You can also open the Printer List window from Printer Center (Mac OS X 10.2.8 or earlier) or the Printer Setup Utility (Mac OS X 10.3 Panther, or later).
Check the Printer menu again after installing the software. If the printer does not appear, you may need to do this:
  1. Make sure the printer is connected to your computer, plugged in, and turned on.
  2. For Mac OS X 10.2.8 or earlier, from the Printer menu in the print dialog choose Edit Printer List. The Printer List window appears.
  3. For Mac OS X 10.3 or later, choose Show Printer List from the View menu. The Printer List window appears.
  4. Click the Add Printer button.
  5. Choose USB from the first pop-up menu.
  6. Select your printer from the list.
  7. Click Add.
  8. Close the Printer List window.
How to add a network printer (AppleTalk or LPR)
Adding an AppleTalk or LPR network printer is very similar to adding a USB printer. In Step 4 above, you would choose AppleTalk or "LPR Printers using IP" from the pop-up menu. From there, the setup differs slightly.
AppleTalk printer
  • AppleTalk must be enabled in Network preferences.
  • If your network uses AppleTalk zones, choose one from a second pop-up menu that appears.
  • Make sure to avoid potential issues with AppleTalk multi-homing.
LPR printer
  • You must enter the printer's IP address or DNS name.
  • If you're printing to a queue, deselect the checkbox for "Use Default Queue on Server", then type the queue's name. If not, leave the checkbox selected.
  • You can select your printer from the Printer Model menu or leave it at Generic. In essence, are selecting a PPD file.
Question mark appears, or trouble finding a printer?
If you can't find the printer you want to add in the list of connection methods, make sure you're choosing the right connection type for your printer. Some printers may use custom input-output modules, such as "Epson AppleTalk". You may need to select one of these custom options in order to add your printer. If there's a question mark on the printer's icon, or Print Center or Print Setup Utility lists it as unsupported, check for an updated software version at the manufacturer's website, or the Mac OS X downloads page.
Tip for software installation
Your printer may appear in the printer list before manufacturer-required software is installed. If you have such a printer, remove the printer from your printer list before installing the software. Add the printer back to the list after you've installed the software.
Printers whose drivers or PPDs are included with Mac OS X
Additional Information See these articles for lists of printer drivers and PPD files included with Mac OS X:
25587: Mac OS X 10.3: Included PPDs for PostScript Printers
25588: Mac OS X 10.3: Raster (Inkjet) Printer Drivers Included
107001: Mac OS X 10.2: Included Ink Jet Printer Drivers
107002: Mac OS X 10.2: Included PPDs and Use of PostScript Printers
106490: Mac OS X 10.1: Many Third-Party Ink Jet Printer Drivers Are Included
106516: Mac OS X 10.1: Includes PPDs for Many PostScript Printers
Jul 10, 2008 | HP Office Equipment & Supplies
Can't print to a shared HP Laser Jet 2015 printer (Mac)
On the two non working computers...uninstall the printer drivers and uninstall any info about the printer reboot.reset up each indivual (the two non working ones)computer with new drivers from web.reboot and they should work.RICHARDM69
May 02, 2008 | HP LaserJet P2015dn Printer
OSX
http://www.apple.com/support/leopard/printing/
http://support.apple.com/kb/HT1370?viewlocale=en_US
http://support.apple.com/kb/HT1791?viewlocale=en_US
Apr 29, 2008 | Dell 3010cn Laser Printer
Setting HP OfficeJet 4315 print preferences on a MAC OS X
Whenever you send a file to print from a program a small window shows up. If it shows only
Printer: Drop down menu ARROW Presets: Drop down menu Some buttons at the bottom
then click on the ARROW pointing down for more options. That will show more info, including a drop down menu that will allow you to change page settings, printing settings, etc. For example, if you want to change the printing quality, select "Paper Type/Quality" from that drop down menu and new options will show up allowing you to change the settings of the printer.
Jan 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Epson Stylus 880 InkJet Color Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
