Question about Haier hwr10xc6 Air Conditioner
Air conditioner fried
My husband plugged our air conditioner in an outlet that was the wrong wattage and the unit fried. Now it won't work. Is it worth trying to get it repaired or will it be about the same price to just get a new one?
    Genius:
  • 1,400 Answers
Hello
Wrong voltage? or amperage maybe.
Have you tried it in another outlet that will work? Usaully the circut breaker will blow before the a/c is destoyed.
There may also be a reset button on the cord of the a/c.
Depending on what fried on the unit you may want to consider a new one,usually the repair cost is almost as much as a new one.
Posted on May 13, 2010
    Novelist:
  • 135 Answers
It is hard to say how bad it is, if the compressor is gone, then for sure it would be cheaper to replace the whole unit, if it just fried a switch. I take it that he plugged it into the wrong voltage, if it tried to run for a little while, it will have more damage, than if it was a flash and a popping of the breaker.
What do i have to do to plug my 110 air conditioner into where my 220 window unit
You need a step down transformer, to convert 220V to 110V. You can't just plug the 110V A/C unit in directly unless it is clearly marked as being suitable for multi-voltage supply (110V - 220V input).
Such a transformer has to be of sufficient capacity to handle the current, or wattage, that will be required. The Frigidaire unit in your question is a 3.5 kW cooling capacity, so the transformer would need to be about the same, ie for a 10A supply at least. They are quite big boxes, about $120.
http://welectronics.com/TRANSFORMERS/step-up-down.JPG
You would put this in the roof or in a cupboard.
Apr 25, 2015 | Frigidaire FAC126P1 wall/window Air...
How do you change the fuse in a window unit?
some uneit have a fuse in the electronic board, i would put a new electric plug first is it 220v or 110v go for the plug first
May 24, 2014 | LG LWHD1800R Wall/Window Air Conditioner
Not starting
Hello Pete T - From what you have described the air conditioner possibly have a defective power/control board or faulty plug. I would suggest contacting a professional to accurately diagnose and repair the unit.
Oct 02, 2012 | Frigidaire 15,100 BTU Heavy Duty Window...
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
Heat/AC unit in working order, plugged in 20Amp outlet.. no fan?
Hi1
Do you have at least 200 volts at your outlet? Check that first. You said you brought it home from work, so when you plugged it in at home did you plug it into a 120 volt recepticle?
Jan 01, 2010 | Emerson Quiet Kool 12NW46HK Air...
LG M8003L Air Conditioner does not power on
i think there may be damage to a small electrical component in the circuit board which probably fried just before breaker popped open
Aug 12, 2009 | LG M8003L Air Conditioner
Breaker switch tripped when ac compressor engaged
The power strip is rated too low for the wattage of the unit and that causes the breaker to trip. I would be better for the unit if it were plugged directly into a wall outlet, because there is less a chance of voltage drop which would burn out the unit. They will only tolerate 10% voltage drop before getting into trouble.
Jul 02, 2009 | Fedders A6P09S2A Air Conditioner
Install
Hi Denise, you and your family are doing God's work and I applaude you for it. let me help.
Most small window air conditioners are 110 volt units which means that they plug in to a regular household outlet. If the nearest outlet is further away than the cord will reach you can use an APPLIANCE GRADE extension cord, if necessary.
The other issue is to secure the unit in the window. IF it is a double hung window you can probably open the window, put the air conditioner in place and secure it with a couple of angle brackets and 2" screws.
I would bring a hammer, screw drivers, putty knife, razor blade knife and pliers just in case the window is painted shut, or there is a storm window that has to be removed.
Get back with anyother questions you may have. I want to help.
May 27, 2009 | Heating & Cooling
Haier hwr10xc6 Air Conditioner Logo
140 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
