Question about Canon imageRUNNER C3200 Copier
Wanting to connect pc to a Canon ImageRunner C3100. Anyone have any ideas on doing this?
  • 59 Answers
Hi first u have to vearfy that yours irc3100 have a network card if yes then you have to
1.download latest driver for irc3100 from canon ofical website.
2. you shud have a network cross cable to connect directly from your pc if you dont want conect directly you want to conect throug yours local network in that condation you can use normal network cable,
3. you have set IP address on yours irc3100.
4. just connect networ cable and install driver on pc.
thats it enjoy
thanks
Posted on May 13, 2010
Canon Imagerunner C3100 shows error code E00012-0001
Drum motor error
Check the connector and replace the motor
Jan 17, 2013 | Canon imageRunner C3100 Copier
Canon Ir C3100 Error 000070-0002
A E000070-0002 deals with the transfer belt. I believe it deals with the two tension arms, one may be broken...... It is not easy to get the unit out of the copier.... Good Luck
Jun 26, 2011 | Canon imageRunner C3100 Copier
Let me know how can I connect canon c3100 to my PC so that I can use it as a printer.
U can connect through a network or even as standalone printer through usb port.In network connect the machine to the network through rj 45 cable and then load the driver in the server and access it from there .
Through usb simply run the driver when it asks to connect the machine connect the usb lead and rest it will take care of.
May 23, 2011 | Canon imageRunner C3100 Copier
I want softwere of ir2020
Click here to visit Official drivers and support for Canon IR-2020 Select the Operating System you have on your PC, select language and click 'submit' to download the required drivers
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 18, 2010 | Canon imageRunner C3100 Copier
Does the Canon Imagerunner c3100 have a hard drive to store copied images?
Hello kaiserma.Yes the C3100 has a HDD.It is 20G.To locate it, remove the rear cover.In the upper right section you will see a silver aluminum box.The hard drive is located wthin it.I hope this helps. :-)
Apr 26, 2010 | Canon imageRUNNER 400S Copier
Canon imagerunner c3100n Howe do I remove
Your in the copiers IP address into your web browser and go to address book and delete address , you can also add address's here. If you do not know IP address, go to machine, touch additional functions, system settings, network settings, tcp/ip, IP and write down #.
Oct 30, 2009 | Canon imageRunner C3100 Copier
How to configure imagerunner c3100 as a printer on a network
what do you need to know?
you need to put a static IP address or set it to DHCP and load the canon print driver.
you need to create a tcp/ip port on the ip address of the copier
Aug 22, 2009 | Canon imageRunner C3100 Copier
If you open the front door,the plastic container in front is the waste toner container .Remove that bottle and dump all that toner.Make sure the neck of the container is free from toner inside and outside.And put the container back in it's place.
Mar 29, 2009 | Canon imageRunner C3100 Copier
Canon imageRUNNER C3200 Copier Logo
316 people viewed this question
old marine
old marine
