Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
I believe the sensor for water level is bad. Tub fill or empty.
I believe the sensor for water level is bad. It won't fill water into tub nor when it gets to the drain cycle, will it stop. The pump just goes and goes and never stops. Took the cover off, the pump is clear and is turning with no restrictions. The impellers look good with no visible damage. The intact screens are clean and there is plenty of pressure. It has an E-13 (not E-03) during rinse cycle and will not proceed. Bosch 500 series
  • cblakney853 May 16, 2010
    Thanks Jahn, for the sound conclusion on what the problem is. It took a lot of investigation on my part and patience to read through the reams of information I provided.
    President:
  • 1,554 Answers
You are absolutely correct if the pump continues to work even when the tub is already empty. The water level sensor is stuck in the full position making the pump work continuously until the E-13 (long drain) code flashes. During the fill cycle, the washer won't fill because the control "thinks" it is still full due to the sensor being stuck in the full position.
Posted on May 16, 2010
  • 4 more comments
    Jahn, you said: The water level sensor is stuck in the full position making the pump work continuously until the E-13 (long drain) code flashes.
    Clem replies: Since I can't find any kind of diagram/parts list with descriptions and drawings I am guessing that the level sensor is actually in a rubber bulb at the bottom of the tank. One pipe goes to the drain pump and the upper pipe is what houses the water level sensor. The pinch'clamp has to be removed and then has to be pulled and cleaned or replaced; is that correct?
    Jahn,
    I removed and examined the air chamber where the water level sensor tub leads to. It is totally clean and unobstructed. Then it narrows it down the the sensor unit itself as possibly being bad. The tub is secure on both ends so there appears to be no air leak. It there a way to troubleshoot sensor or just replace it?
    OK Jahn, I have the washing machine put all back together. Started it on a Hot temperature cycle. The tumbler started tumbling but no water enter the tub. So two solenoids bad... don't think so. At 34 minutes into the cycle the drain pump kicked in... nothing to pump of course. Then the spin led popped on no the pump continued and the tumbler did not start spinning either. The sensor most likely says there is too much water to spin and keep pumping. So the water level tube goes up to a round object(White top w/red bottom) with multiple wires going to the control panel and also the water heater elements. So what do you that is bad the the water level control module or the main control module? As I have asked several times for... is there a wiring/service manual that I can download. Clem
    Am I doing something wrong that I am NOT getting any feedback or solutions?
  • Jahn27
    Jahn27 May 16, 2010
    My apologies for the delayed response due to time zone constraints. The white-top red-bottom round object with multiple wires where the water level tube leads to is the pressure sensor that houses the pressure switch. I see no other problem except the pressure sensor as the washer works fine except for the fact that water does not enter the machine and the pump continues to work. Water not entering the machine does not necessarily signifies a bad water valve solenoid as the control will pop up an error code indicating that water is not entering the machine should that be the case.
    The machine will not tumble at the start of the cycle if the water has not filled the tub and the pressure switch is not in the full position. With the pressure switch in the full position, power to other components such as the drive motor is activated allowing the washer to advance to the next step of the cycle. The symptoms clearly indicate that the pressure switch is indeed stuck in the full position. Otherwise, the washer will flash a water fill error code and/or the cycle will not advance and tumble.
  • Jahn27
    Jahn27 May 17, 2010
    One obvious sign that the pressure is stuck in the full position is the washer will almost instantly tumble upon starting as it will no longer fill due to the fact the pressure switch is stuck in the full position and the control "thinks" water is already present and filled the tub.
    Regarding the wiring diagram or service manual you are requesting, I regret to inform you that Bosch appliances are the ones with the rarest service manuals to find. I would be more than willing to lend it to you if I have one. But the principle of operation is the same with all other washers.
Why does My Samsung VRT front loader leave the soap dispenser full of water at the end of the wash cycle. I have to empty it in order to add detergent for the next wash cycle.
there are 2 components to the soap dispenser, 1 using liquid soap has a little tub that you dispense soap into and 2nd you remove the tub when using powder soap. I assume that you are talking about the little tub is filled with water. How this works is by adding water to the tub the level rises and siphoning empties the little tub. If any water remains it is due to water being added after the little tub has already emptied. That is not a big issue and will happen. Just empty the water or add some water to start the syphon process.
Oct 11, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Cabrio washer error code OL after about 10 mins.
The ol error can be caused by many problems, first let's address the over filling of the water, there is a plastic tube that runs from your control to the outer tub. This tube provides the pressure to the sensor in the control board to control the water level in the tub of the washer. If this line has a pin hole or is clogged, this could effect the water level. If your tube is ok then the control board is bad.
the ol error could be any of the following:
cloths under the tub,
bad bearings
basket hub
stater motor
rps sensor
control board
Mar 27, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
My Whirlpool washer fills up but won't stop poring into the washer. Is this something that is repairable?
Your water level switch could be defective. This switch has a plastic 1/4 hose connected from your tub to the switch. (should be easy to find.) Make sure this hose is connected to your tub and switch and the line has no holes. It is easy to test the switch by disconnecting the line from the tub and while water is flowing into your washer, Blow into the line. The pressure will stop the water flow. If not, Bad level switch.
Level switch part# W10339333
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool WTW5100SQ
IN THE WASH CYCLE THE TUB FILLS ALMOST TO THE TOP THE DRAINS. THE OL CODE THE APPEARS AT THE END OF THE CYCLE
Hi, the OL code means Overloaded..
OL flashes when the machine/motor control detects a load size that exceeds the washer's capacity.Open the door lid to clear display, remove excess laundry, then restart the cycle.
Oct 04, 2010 | Whirlpool WTW6400SW Cabrio Washer
Low Water Level in Roper washing machine
You need to check the pressure switch which is also called the water level switch. There is a small tube attached to it and it may have a blockage or a hole in it. You can find this behind the control panel to the left of the timer.
Nov 14, 2009 | Washing Machines
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
GE Dishwasher - poor cleaning
I believe there is a screen/filter on the water line before or at the water fill valve. If that gets plugged it can restrict the flow. The fill valve can also fail/get plugged and restrict the flow.
Also, dishwashers usually have a level sensor to tell when there is enough water to do the wash. It may be a float inside the tub that operates a mechanical switch or it may have a hose to a pressure sensor. Either type can get greasy/dirty/plugged and as a result cause improper water levels.
Check both the water supply filter/fill valve and the level sensor. One or both of those may be involved.
Mar 10, 2017 | Kenmore Dishwashers
Error e006 maax tub water level sensor
If you are filling the tub full enough and the pumps are still not working, the level sensor is bad and needs to be replaced. One can be ordered directly from Maax out of Canada
May 09, 2009 | Maax Calla 6042 Bathtub - 101058-000
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
152 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
