Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Wont fill with water
Whirlpool washer..won't fill..makes a humming sound but that's all
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about no water coming into the washing machinewont fill with water - 2_bing.gif...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Posted on May 14, 2010
My washer is not filling up with water. It is making a humming sound. Please Help me!!!!!
The inlet screen could be plugged where hoses connect, or water is not turned on. Humming is the solenoid not working or trying to work. make sure water is getting too the machine and try repeated off and on cycles with dial. replace solenoid if needed.
Feb 26, 2014 | Whirlpool LSR5132PQ Top Load Washer
Fills with water and then stops makes a humming sound ,then stops all togther wont do aything spin or drain
sounds like an induction motor. start winding or start capacitor not starting to turn motor, This will make motor hum. Do not know m/c in qestion. Switch on and as soon as pos try to turn motor careful not to use hands or anything that can injure yourself with if it starts to spin.
Oct 29, 2012 | Whirlpool WTW5521S Top Load Washer
Whirlpool lsb6000pq2 washing machine won't fill with water
Humming could be a blockage on the fill solonoid valve remove water fill hose and clean the filter at the valve it pulls out or use an old toothbrush
Jun 26, 2012 | Washing Machines
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
Jun 21, 2012 | Kenmore 43142 Front Load Washer
Whirlpool dishwasher will fill with water but washer cycle wont kick in just makes a humming noise
Your pump could be jammed or plugged. Make sure the grate in the bottom of the washer is clean. If possible, pull it out and look under it to see if there is anything in the hole.
Jan 08, 2011 | Whirlpool Dishwashers
Machine fills with water, then hums.
sounds like the timer may be heating up!
Jan 01, 2010 | Whirlpool LSQ9610L Top Load Washer
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
Help
The humming noise is the fill valve...this sounds usually is overpowered by the water fill, but if its faulty it wont let the water in....Replace the fill valve
Jan 20, 2008 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
201 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
