Question about Bosch 22 in. SKT5102 Free-Standing Dishwasher
How to install a Bosch SKT5102GB tabletop dishwasher on worktop and plumb in?
How to install a Bosch SKT5102GB tabletop dishwasher on a work top? Thanks
  • Anonymous Jan 17, 2009
    Bought SKT1502 shop solied and therfore don't have user manual - wondering whether this can go on ground or has to be at table top height for drainage.
4 Suggested Answers
  • 10865 Answers
SOURCE: Bosch dishwasher wont take in water through the cold inlet
First of all, the hot water line should be supplying the dishwasher, not the cold water line. That being said, if the machine is hooked up to cold water line, the only reason why no water is coming in would be that the valve is not open. Look under the sink to see if that is where the dishwasher line is attached to the cold supply. If not there, perhaps in the basement. Open that valve and you should have water.
Finally, if there is no water coming in and you have a lime deposit problem with your water it is possible that the line is full of lime and will have to be changed. good luck with this.
Posted on Feb 13, 2009
  • 30 Answers
SOURCE: bosch dishwasher was started when water supply was off
You could have a blockage in the pump solinoid..if there was some plumbing done in the house...you can get small pieces of copper that come from cutting the pipes stuck in side of smaller water lines such as dish washers and ice makers... its a little bit of work but you'll have to remove the dish machine and double check that the water is in deed getting to the dish machine... if it is then you'll start by checking that nothing is clogging the pump...normally the punp is located right where the water connects to the machine...good luck
Posted on Apr 05, 2010
  • 51 Answers
SOURCE: water plumb are not working. Does it worth to fix? Thanks.
IF THE WASHER IS NOT PUMPING THE WATER THROUGH YOUR DRAIN, AND YOU HEAR THE PUMP RUNNING, YOUR DRAIN LINE FROM THE WASHER TO THE SINK DRAIN IS CLOGGED. DISCONNECT HOSE FROM SINK DRAIN AND VACCUM OUT, OR RUN A WIRE OR SOMETHING SMALL BUT STIFF TO LOOSEN THE CLOGGED HOSE. NOW RUN THE WASHER AND ALLOW SOME WATER TO BUILD UP IN THE WASHER, IF WATER ALREADY EXISTS THEN TURN KNOB ON WASHER TO DRAIN. MAKE SURE YOU HEAR WATER DRAINING IN SINK AND PROBLEM SOLVED. IF THE PUMP MOTOR IS NOT TURNING AT ALL , BUT YOU CAN HEAR IT ENGAGE, THEN TURN WASHER OFF, TAKE FRONT BOTTOM PANELS OFF, LOOK FOR THE MOTOR AND TAKE YOUR HAND AND ROTATE THE MOTOR CLOCKWISE A FEW TURNS AND THEN COUNTER-CLOCKWISE A FEW TURNS, IT WILL FEEL LIKE A DISC IN THE FRONT OF THE MOTOR. IF YOU DON'T FEEL A DISC AT THE FRONT OF THE MOTOR, THEN LOOK AT THE BACK OF THE MOTOR AND YOU SHOULD SEE WHAT LOOKS LIKE SOME BLADES. NOW TAKE A SCREWDRIVER AND ROTATE IT CLOCKWISE AND THEN COUNTER-CLOCKWISE. MAKE SURE YOU GET SOME ROTATATION WITH EITHER METHOD THAT YOU HAVE TO USE. YOU WILL FILL RESISTANCE AT FIRST, BUT KEEP TRYING TO TURN THE MOTOR. AFTER GETTING IT TO MOVE, TURN THE WASHER ON NORMAL CYCLE AND ALLOW TO RUN. IT SHOULD DRAIN WITH NO PROBLEMS. REMEMBER THIS IS JUST BUILD-UP INSIDE THE WASHER AROUND THE INSIDE OF THE PUMP AREA. ALL YOU HAVE TO DO IS BREAK IT LOOSE. IT MAY SOUND LIKE A HARD TASK , BUT IT IS QUITE EASY. YES IT IS WORTH FIXING, BECAUSE IT WILL COST YOU NOTHING. IT TOOK LONGER FOR ME TO TYPE THIS THAN TO FIX YOUR PROBLEM. TO KEEP THIS PROBLEM FROM COMING BACK, OR COMING BACK MORE OFTEN, ALWAYS SCRAPE EXCESS FOOD IN TRASHCAN AND RINSE THE DISHES OFF WITH WATER BEFORE PUTTING THEM IN THE WASHER. ALSO PULL THE BOTTOM RACK OF THE WASHER ALL THE WAY OUT AND CHECK THE FILTER SCREEN TO SEE IF IT IS CLOGGED. IF IT IS UNCLOG IT . THIS TAKES APPROXIMATELY 30 TO 45 MINUTES, AND SAVES YOU $$$$.
Posted on Apr 13, 2010
AEG dishwasher integrated Model newly installed but when I lower the door to load it the dishwasher moves out from under counter and then wont close properly how do I solve this problem?
The built-in dishwashers are almost fixed by screws in top or by side. Carefully read the installation manual where it is explained in detail how to fix the dishwasher under the kitchen worktop. You also need to adjust the height by using the swivel legs that will additionally fix the dishwasher.
Dado
Jun 24, 2017 | AEG Dishwashers
Water salt and rinse buttons flashing on bosch tabletop classic xx dishwasher ?
Disconect power completely, wait 5 minutes, reconnect power. Still flashing, needs serviceman
Jan 12, 2017 | Bosch Dishwashers
Spray arm not turning on Bosch Tabletop S2R1B
The inside of the arms can get blocked, only if the water can move freely through them do they turn, cause by the water ejecting from the arms spay holes. Lift or pop the arm off its mount, its a push-click fit.
have a look inside it for debris like chicken bones and clean it out.
do the same for the socket the arm came off -check all tubes are clear.
Dec 14, 2013 | Bosch Dishwashers
I can't see how to remove the worktop of my Bosch dishwasher. I found two screws that look as if they stop it sliding forward but I still can't move it after removing them. It looks for all the...
Hi john_mchugo,
The dishwasher Worktop can be removed by first removing the 2 screws at the back of the machine. The screws are either fastened horizontally, or vertically. Once these screws are removed, the worktop slides backwards, and can be lifted up and off.
On some models there are catch tappets located on the rear right and left hand sides of the Top panel. To remove the Top panel, press up the catch tappets, push the worktop back and lift it off. If these tappets aren't pressed up, the Top won't release at all.
I hope this has helped you.
Kind Regards
* If this solution helped you, please accept it
Aug 18, 2011 | Dishwashers
Heat is escaping from my built in dishwasher ruining worktop
when the appliance was installed there should of been a metalic paper looking strip that had a sticky back this should unpeeled and be stuck to the underside of the worktop and it will deflect the heat and steam away from your worktop. Sadly this will only get worse if not fitted as everytime the appliance finishes when the door is opened the steam will billow out onto the worktop.
Hope this helps
P
Jan 12, 2011 | Whirlpool ADP 8900 Dishwasher
Hi I am looking to buy a table top dishwasher, I have no room to plumb into pipes, will I be able to connect to a mixer tap???????
a dishwaher needs hot water to work properly a mixer i believe works so you do not get burned by hot water i believe correct me if i am wrong with a normal tap all you need is a special fitting for your portable and they usually are supplied with a new one or are cheap to purchase from a plumbing supply or loewes or home depot.check with where you want to purchase washer and ask if they work with a tap mixer
Dec 14, 2009 | Dishwashers
How to adjust the legs
Remove any plinth in front of the base of the machine. In the middle of the base you should see a black screw head with arrows either side. This screw adjusts the height of the machine at the back - clockwise = up and visa versa. The two feet at the front screw in or out of the base moulding to raise or lower the machine. Check that these have not been secured by screws through the front moulding. If so, slacken or remove. NOTE: make sure if the machine is already installed that you have loosened the screws which secure the machine at the top to the underside of your worktop.
Mar 01, 2009 | Bosch 24 in. SGV53E03 Built-In Dishwasher
Steam eating my cabinet top up
You can buy a metal strip with a small angled edge to fit under the worktop above the dishwasher. I have one of these and it has protected the worktop for 10 years,
Dec 22, 2008 | Frigidaire 24 in. PLD2560LCC Energy...
Bosch aquasensor
no it should be plumbed into the hot side... it will not wash untill the water is hot enough ...
Aug 20, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 22 in. SKT5102 Free-Standing Dishwasher Logo
2,009 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
