Question about Kitchen Appliances - Others
Increase water pressure
I have a Franklin Electric Constant Pressure Controller Subdrive 150 Model 5870204150D. I want to increase the water pressure from the current 45psi to 55-60 psi. Can you provide instructions how to do this or send the correct manual. Thankyou for your help Brian Ross
If you go to the pressure switch inlie (shouldbe within 6 feet of well head) you will ee a rubber plug in th top of it. remove the friction plu an there is an allen bolt under it. adjust pressure with an allen wrench there.
Posted on Jul 13, 2010
Only goes up to 150psi how do you get the 175 it is marked to put out
Pressure switches are set at the factory and are marked as to the range. If your pressure switch is marked with range to 150 probably best to not try to adjust, however you could increase the pressure somewhat by turning screws under the cover (google your brand/model # of pressure switch for adjustment). If your switch is marked to 175 and the compressor runs and never reaches cut off, then problem exists within pump or there is a leak in the system. If your switch is marked to 150, my suggestion is to leave as is to increase the life of the compressor. It is never a good idea to use a tool at max setting. Try to use tools to about 75-80 % of rating /duty cycle. You practice this every day with your car/truck. Although you can travel at 100 mph you drive reserved to take care of your engine/trans. good luck
Jun 01, 2011 | Ingersoll Rand - Rand Type - 30...
How do you adjust the pressure on a watts regulator to increase the flow of water?
Turn it clockwise to increase pressure on a watt's pressure relief valve. You will have to gradually adjust and check pressure till you get it to desired pressure. You don't want to exceed safe pressure due to damaging water lines or fixtures.
Jun 14, 2010 | Watts Regulator Temperature and Pressure...
Lack of water pressure from gun
With the water faucet turned fully on and the power switch on squeeze and hold the trigger for at least 10 seconds to let the water flow push the air out and then it should start up. Also, adjust the nozzle by turning it to increase pressure.
Apr 15, 2010 | Karcher PSI Electric Pressure Washer
Would like to increase water pressure
You will need the expertise of a Plumber, this is beyond the scope of this forum.
Jan 26, 2010 | American Standard 2000.502.002 Ceramix...
How do i increase the water pressure in t boiler
you can not increase the water pressure with the water heater if your on city water you are stuck with the pressure you have if you have a well you can increase the pressure switch.
Nov 11, 2009 | Crock Pots & Slow Cookers
Sudden increase in water pressure
Replaced the pressure switch and water pressure returned to normal.
Jun 16, 2009 | Plumbing
What s de minimum working pressure for a tempra 24?
Hello. let me help you. The water pressure is what it is in the house. In other words, the tankless water heater doesn't increase the pressure of the water, it only heats the water. There is no official minimum pressure but the minimum pressure you would be happy with in any home would be 20 pounds per square inch, PSI.
Jun 05, 2009 | Stiebel Eltron TEMPRA 24 Tankless Water...
Troy bilt pressure washer
Turn Black cone shaped valve clockwise to increase pressure there will be a small +/- plus will increase and give you pressure.
TK U
Mar 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Kitchen Appliances - Others Logo
149 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
