Question about Dayton Electric Heater
Horizontal electric hot water tank installtion
Can a conventioanl electric hot water tank be installed horizontally?
If yes, what extra steps need to be taken?
We are renovating a bathroom that has the hot water tank in it and would like to re-install the tank horizontally in the crawl space below the bathroom.
Thanks for your help
  • Willow_AK May 27, 2008
    Yes, I do have a need for a horizontal hot water tank, but GAS.
    I have also heard this style referred to as a "Pancake style," which uused to be used approx 30 yrs ago.
    Where can I get one?? Thank you in AK.
    Sniper:
  • 68 Answers
Water heaters are designed to be installed upright. The dip tube allows for cold water to be distributed to the bottom of the tank, and to be heated as it rises. Installed horizontally would defeat the purpose of the dip tube, it would heat the volume of water in the tank, but almost immediately the water would get cold.
The tankless water heater is the best for your situation. You only mentioned electric, so I assume that is your only option. There are several options in an electric tankless. You need to decide what gpm (gallons per minute) you need for your situation.
If it is an option, the gas tankless water heater has a better gpm rate options, but you have to take into consideration the issue of venting.
Both options, are a lot smaller than that of a conventional water heater.
Please rate this solution
Posted on Jul 29, 2008
Newark make horizontal hot water tanks of all sizes.
Posted on Jul 12, 2008
  • 109 Answers
Hello; no, unfortunately conventional elec. water heaters are only designed to operate in the upright position. one alternative is an electric tankless model. but beware there are a few things to explore about them before making the decision.
Posted on Mar 30, 2008
SOURCE:
How to turn on water heater
This might not be much help, without more details, but there should be a valve inside the water heater panel (outside) you can open. Open the valve at the main propane tank also.
Make sure the water tank is FULL before you fire it up. There should be a switch inside the coach somewhere to turn it on.
If it doesn't ignite immediately, you probably have air in the lines. Light the stove and let it burn for a minute, then try the hot water tank again. Might take a few tries to get it fired up.
Apr 28, 2015 | Forest River 2011 Rockwood Signature Ultra...
What are the steps to replace the fuel pump on a chevy trailblazer 2002
This is what it looks like and it is located in the gas tank:
First, you'll need to use up as much fuel as possibly, if not, you'll have to drain the tank. Next:
  1. Drain the fuel tank.
  2. Support the fuel tank.
    1. Remove or disconnect the following:
    2. Negative battery cable
    • Filler neck from the tank
    • Shield from tank and tank straps
    • Fuel lines and vapor hose from pump
    • Electrical connection from fuel pump
    • Fuel tank
    • Fuel pump/sending unit assembly by turning the locking ring (located on top of the fuel tank) counterclockwise using a spanner wrench
    • Fuel pump from the fuel lever sending device
  • NOTE
    The fuel pump strainer must be in a horizontal position when the fuel sender is installed in the tank. When installing the sender assembly, make sure that the fuel pump strainer does not block full travel of the float arm.
    To install:
    1. Install or connect the following:
      • Fuel pump in tank with new seal around opening
      NOTE
      • Tank and connect fuel lines and vapor hose
      • Tank to the frame. Torque the fasteners to 33 ft. lbs. (45 Nm).
      • Shield
      • Fuel filler neck and clamp
      • Negative battery cable
    2. Refill the tank.
    3. Run the engine and check for leaks.
    // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 33; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]>
    Jul 08, 2011 | 2002 Chevrolet TrailBlazer
    It is leaking out of the top. not out of the hot or cold valves but out of a nut by the cold side.
    Your tank is rusted out and needs to be replaced.
    Link below is a troubleshoot for leaking water heater.
    http://waterheatertimer.org/Leaking-water-heater.html
    Protect yourself first:
    If your tank is rusted, there is danger of rupture.
    My friend welded his leaking tank, but he assumes the risk.
    Ruptured tank can cause massive damage and water runs until it is shut off.
    Hot water tank is under pressure because hot water expands and pushes against tank wall.
    Turn off water to tank.
    Turn off power supply:
    Electric: turn off circuit breaker.
    Gas: rotate knob to pilot so pilot stays lit but burner will not fire. To turn back on, rotate knob to ON.
    Open hot side bathtub valve and relieve pressure on tank.
    You can limp by with rusted tank by turning water heater on when hot water is needed.
    Shower uses 5-9 gallons hot water
    Bath uses 12-15 gallon hot water
    Ordinary gas heater makes 41 gallons hot water per hour
    Ordinary electric heater makes 20 gallons hot water per hour.
    I buy water heaters at Lowes, Home Depot, Ace.
    Look for scratch and dent models.
    Buy drip pan for water heater.
    Wrap electric heater totally with insulation except TP valve.
    Buy new flexible connectors for water lines.
    Offer 15% less than marked price on tank, because the store makes money on additional items.
    > Most people can install their own electric heater since you just connect water pipes and electric wire, and it's done. Read link below since there are tips that help you buy and install electric.
    > Generally people are nervous about installing gas water heater, so step-by-step instructions are shown on link below. Remember gas line is under less pressure than water line, so if you can install a water pipe, you can install gas line to water heater with crescent wrench, and soapy water to check for leaks.
    How to install gas water heater:
    http://waterheatertimer.org/How-to-install-gas-water-heater.html
    Add a comment for more free help.
    Also take advantage of fixya phone service.
    For a price, fixya expert speaks with you over phone while you work on water heater, or any do-it-yourself project.
    Jan 13, 2011 | Water Heaters
    Rheem water heater model #82V661 serial # RH0106D11663 leaking water at lower panel. Water is coming from above wiring and control panel. Is this fixable or need to be replaced? Mfg date is 01/2006
    You have 240volt electric water heater
    Check both elements for leaking.
    Check top of tank for leaking pipes.
    If water heater is leaking from side of tank, then tank is rusted out and could rupture.
    This tank must be replaced.
    http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
    My friend welded his tank to get more life out of tank, but he assumed the risk.
    Hot water heaters are under pressure from heated water which expands.
    If tank ruptures, water will flood out of tank and water will run until shut-off is turned OFF.
    This causes major damage inside home.
    Protect yourself first, and then let's talk more.
    1) Turn off water at shut off located on cold water line above tank.
    2) Turn off power to water heater:
    Gas heater, rotate valve to 'pilot' so pilot is lit but burner does not turn ON.
    Electric heater, turn off circuit breaker.
    3) Open tub spout on hot side and let run a bit to relieve pressure.
    4) Now your property is safe.
    You can limp along with failed heater if leak is slow.
    Turn heater ON when you need hot water.
    Typical Gas heater makes 41 gallons hot water per hour.
    Typical Electric heater makes 21 gallons hot water.
    Shower uses 5-9 gallons hot water, bath uses 12-14 gallons hot water.
    http://waterheatertimer.org/images/Water-heater-reference-guide-2.jpg
    If you are going to install heater yourself:
    Look at label on side of old tank to identify size and particulars.
    I buy ordinary heaters from Lowes and Home Depot and always buy scratch-n-dent models when possible, because superficial damage to outer tank does not lower lifespan of heaters I have installed.
    Buy same size heater if it worked fine before.
    Buy new flexible water connectors.
    Set water heater in drip pan.
    Offer 10% less than price shown. Make them deal with you. Shop Ace hardware, Lowes, Home Depot. Kick the tires since you have a bit of time.
    I know you have electric heater, but many folks read these answers, so I include info on gas too.
    #1 rule) tankless heaters are a rich-man's toy, because tankless will never pay you back, and will become major money pit if you encounter 1 repair. Electric tankless heaters require larger electric service box. Gas tankless require larger gas line (larger gas line, more gas consumption, bigger bill unless you cut consumption)
    2) How to install gas heater:
    http://waterheatertimer.org/How-to-replace-gas-water-heater.html
    3) How to install electric heater:
    Read link above because many of same steps apply to electric.
    The difference with electric, is turn off power, disconnect wires, and reconnect wires exactly like before. Set electric heater directly on insulated surface like dense blue styrafoam. Cut styrafoam in circle so it fits inside dip pan. Wrap entire electric heater with insulation blanket, except don't cover TP valve.
    4) Connect bare copper jumper wire between hot and cold pipes to prevent stray current corrosion which will shorten life of tank. Make sure cold water line is grounded.
    Also read:
    http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
    Add a comment for more free assistance.
    For a price, fixya expert speaks to you via phone about any do-it-yourself problem.
    Jan 07, 2011 | Rheem Water Heaters
    Seems as though there is a whole in the tank causing wter to spew out, The whole is yhe top of the tank and appears to be very small, can this be patched or soldered?
    If water heater has a hole, then water heater is rusted out and must be replaced.
    Immediate problem is ruptured tank.
    Water heaters are under pressure, and rusted water heaters rupture and water runs until water is shut off.
    I buy ordinary heaters from Lowes and Home Depot and always look at scratch-n-dent models.
    #1 rule) tankless heaters are a rich-man's toy, because tankless will never pay you back, and will become major money pit with 1 repair.
    The difference with electric, is turn off power, disconnect wires, and reconnect wires exactly like before. Set electric heater directly on insulated surface like dense blue styrafoam. Cut styrafoam in a circle so it fits inside dip pan.
    Also read:
    Jan 01, 2011 | Water Heaters
    I have a humming and knocking that is happening in my pipes. It seems to be related to my hot water heater. I have unplugged the heater and that helps most of it, but there are still times during the day...
    Knocking water pipes are caused by air trapped in the pipe. If the pipe only went uphill and horizontal, the air releases out of the faucet and doesn't cause a problem. But if the pipe takes a turn back down, there is an opportunity for the air to remain trapped. Try this ---. Turn on all of your hot water faucets full blast at the same time. Start with the highest faucet farthest from the hot water tank and work your way back to the one closest to the hot water tank. Count to ten, then close them in reverse order. If that doesn't clear the air, then look for a place where the pipe travels horizontally then back down. If such a place is accessible, and if the pipe is copper, buy a self-piercing tap of the type that are used to supply water to an ice maker. Install it and let some water out and hopefully some air out. If you also attach a section of clear hose you and you open the valve very slowly, you will be able to see the air bubbles in the hose. I use just such a setup on my hot-water heating system and it works like a champ. Good luck!
    Nov 26, 2010 | Water Heaters
    INSTALLING A ELECTRIC WATER HEATER. NEED TO INSTALL A 240 VOLT FROM BOX TO WATER HEATER DIRECT.
    As long as the hot water tank is no more than fifty feet from the panel, you will need 10/3 with ground wire, wire staples and a 30 amp double pole breaker. Be sure to purchase enough wire with about 4 feet extra to allow for connections.
    Be sure to fill the water tank before turning on the power. To be sure it is full, run water through the nearby faucets, turning on the hot water faucets or both to be safe. If you fire up an empty hot water tank you will destroy the heating elements almost instantly.
    Jul 10, 2009 | Generac 100 Amp 120/240-Volt Transfer...
    Which flyback should I get and from where?
    You will need the 259296 Flyback and the Horizontal output (HOT) is a 2SC5588 You can get both parts at the following link and they provide free step by step instructions on how to do the repair. Heres the link
    http://servicemanuals.vstore.ca/
    Apr 22, 2009 | Televison & Video
    Brown horizontal lines sporadically appearing on monitor
    I had the same problem. I fixed it completely today. The horizontal lines disappeared. IT IS DEFINETLY THE DEVICE DRIVER. I confirmed my monitor model tyope (dell M783s) and downloaded the specific driver for this monitor.
    I had to do these exact steps or did not work.
    1) with the problem screen, disabled the display adapter under the Hardware/Device Manager settings.
    2) Restart the PC
    3) Boot will come up with brown lines still but the screen will low resolution of 600x800.
    4) Then I installed the correct device display monitor driver onto the pc. ( you may need to scan for new hardware, then choose the directory with the new hard drive.)
    If you need step by step... just reply back.
    Dec 02, 2007 | Dell M781S Monitor
    Dayton Electric Heater Logo
    722 people viewed this question
    Top Dayton Heating & Cooling Experts
    Paul Carew
    Paul
    Paul
    Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
