Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Freeezer is icing up and not freezing foods - Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
  • 1,284 Answers
Hi, if the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
Take care
Posted on May 13, 2010
Fridge freezing up
Set your Ref/Freezer per the following:
Refrigerators:
36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
You have to wait about 4 hours for everything to stabilize. If you are still having ice forming inside the freeezer then the rubber seal around the door is probably the problem. If they have a split, tear or crack, etc. it will let warm moist house air into the freezer and turn to ice as it cools. If this happens in the refrigerator it'll turn to water and collect in the bottom of the frig. New seals can cost around $60 per door.
If you pack too much food in the unit it may also cause freezing because the air needs to move around in there and food shouldn't block the vents in the back walls of the unit.
Hopefully this helps..
Nov 23, 2012 | Spartan Showcase Self Service Cigarette...
My refrigerator and freezer temps are set on 3. I have slowly reduced the temp due to both compartments due to being too cold. Vegetables in the bins are not lasting because of cold temps and the...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Mar 21, 2011 | Refrigerators
The freeezer on my GE refregigetor eeds de-icing
YOUR HEATER,DEFROST THERMOSTAT,TIMER IS OUT. YOU NEED TO HAVE A TECH LOOK AT IT. THIS PROBLEM WILL NOT GA AWAY. SORRY NO QUICK FIX
Mar 16, 2010 | Refrigerators
GE Monogram freezer will not stay cold enough
This sounds like you freeezer is not defrosting properly causing foods not to freeze rapidly and possibly causing the fresh food section to remain warmer than normal. I think it would be a good idea to unplug and remove the rear panel in the back of your frezzer to examine just what is going on. Hopefully the defrost element part number WR51X322 is not defective. We also will need to inspect the mother control board below your refrigerator and in-closed in a case that covers the board. All defrost is done by this board part number WR55X10560 Look for burn marks and signs of heat damage. If found the board will need replaced. You also can contact me at appliancepartsse@yahoo.com and the parts can be found at these links. Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
May 29, 2009 | Amana ABB1927DE Bottom Freezer...
Unit is running but not cooling/freezing food or making ice
is your compessor running are you seeing eany ice build up in the freezer
Apr 06, 2009 | GE Refrigerators
Admiral Refrigerator/Freeezer not cooling-food is melting
Most likely nthe refrigerator has a defrost timer. Need to find it and turn the timer clockwise slowly until you hear a click and refrigerator goes into defrost. If that happens you need to change the timer. It also could be an element is bad also. Let me know, Thanks, Sea Breeze
Mar 20, 2009 | Refrigerators
Fridge running warm
one thing to check for if you whant the freezer to colder the fresh food compartment will not go down i temperature because you stre blocking the air floe lower the freeezer control knob thanks from gilles
Feb 21, 2009 | GE GSS20IEP Side by Side Refrigerator
GE Side by Side
hi thanks for the question look at the small tube that goes into the ice maker they freeze up and not letting the water go into the ice maker thanks please accept with a positive feed back thanks the appliance doc
Sep 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag model RTC17A
how is freeezer side doing? Do u have any frost build up in freezer back wall and is you fan in freezer blowing?
Aug 31, 2007 | Maytag MSD2756GES Side by Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
150 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
