Question about Nokia 3110 Cellular Phone
I poured it a bit and since this time my mobile is turning off because the battery is for short time low
  • 269 Answers
Because you dropped it the battery life will be affected. Please check by changing the battery.
Posted on May 14, 2010
Harley engine codes
P0107 Map Sensor Open/Low
P0108 Map Sensor High
P0117 ET Sensor Low
P0118 ET Sensor High
P0112I AT Voltage Low
P0113I AT Voltage Open/High
P0120 TPS1 Range Error
P0220 TPS2 Range Error
P0122 TPS1 Low
P0123 TPS2 High/Open
P0131 Front Oxygen Sensor Low
P0132 Front Oxygen Sensor High
P0151 Rear Oxygen Sensor Low
P0152 Rear Oxygen Sensor High
P0154 Rear Oxygen Sensor Inactive.
P0222 TPS2 Low
P0223 TPS2 High/Open
P0261 Front Injector Open/Low
P0263 Rear Injector Open/Low
P0262 Front Injector High
P0264 Rear Injector High
P0373 CKP Sensor Intermittent
P0374 CKP Sensor Synch Error
P0444 Purge Solenoid Open/Low
P0445 Purge Solenoid High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0501 VSS Sensor Low
P0502 VSS Sensor High/Open
P0572 Brake Switch Low
P0577 Cruise Control Input High
P0603 ECM EEPROM Memory Error
P0605 ECM FLASH Memory Error
P06415 V+Vref 1 Out Of Range
P06515 V+Vref 2 Out Of Range
P1001 System Relay Coil Open/Low
P1002 System Relay Coil High/Shorted
P1003 System relay contacts open
P1004 System Relay Contacts Closed
P1009 Incorrect Password
P1010 Missing Password
P1270 TGS Validation Error
P1351 Front Ignition Coil Driver Open/Low
P1352 Front Ignition Coil Driver High/Shorted
P1353 Front Cylinder No Combustion
P1354 Rear Ignition Coil Driver Open/Low
P1355 Rear Ignition Coil Driver High/Shorted
P1356 Rear Cylinder No Combustion
P1357 Front Cylinder Combustion Intermittent
P1358 Rear Cylinder Combustion Intermittent
P1475 Exhaust Actuation Position Error
P1477 Exhaust Actuator Open/Low
P1478 Exhaust Actuator Shorted/High
P1501 Jiffy Stand Sensor Low
P1502 Jiffy Stand Sensor High P1510 EFI Limited
Performance Mode
P1511 EFI Power Management Mode
P1512 EFI Forced Idle Mode
P1514 Air Flow Fault
P1600 EFI Module Processor Internal Error
P2100 EFI Motor Circuit Open
P2101 EFI Motor Circuit Range Performance (Actuation
Error)
P2102 EFI Motor Circuit Low
P2103 EFI Motor Circuit High
P2105 EFI Forced engine shutdown
P2107 EFI Module Processor Internal Fault
P2119 EFI Motor Throttle Body Range Performance
P2122 TGS1 Low/Open
P2123 TGS1 High
P2127 TGS2 Low/Open
P2128 TGS2 High
P2135 TPS Correlation Error
P2138 TGS Correlation Error (Twist grip sensor)
P2176 EFI Closed Position Not Learned
U Codes
U1016 Loss of ECM ****** Data
U1064 Loss of TSM/FSFM ****** Data to ECM
U1097 Loss of Speedometer ****** Data to ECM
U1255 ****** Data Error
U1300 ****** Data Low
U1301 ****** Data High
Harley Davidson 2008 DTC Code Reading (draft)
Harley Davidson DTC Codes - Unofficial Guide Page 3
B Codes
B0563 Battery Voltage High.
B1121(TSM) Left Turn Output Fault
B1121(HFSM) Left Turn Output Open
B1122(TSM) Right Turn Output Fault
B1122(HFSM) Right Turn Output Open
B1123(HFSM) Left Turn Output Short to Ground
B1124(HFSM) Right Turn Output Short to Ground
B1125(HFSM) Left Turn Output Short to Battery
B1126(HFSM) Right Turn Output Short to Battery
B1131(HFSM) Alarm Output Low
B1132(HFSM) Alarm Output High
B1134 Starter Output High
B1135 Accelerometer Failed
B1136(HFSM) Accelerometer Tip Test Error
B1141(TSM) Ignition Switch Low/Open
B1141(HFSM) Ignition Switch Low/Open
B1142 Smart Security System Internal Fault
B1143(HFSM) Security Antenna Short to Ground
B1144(HFSM) Security Antenna Short to Battery
B1145(HFSM) Security Antenna Open
B1151 Bank Angle Sensor(BAS) Short to Ground
B1152 Bank Angle Sensor(BAS) Short to Battery
B1153 Bank Angle Sensor(BAS) High
B1154 Clutch Switch Input Short to Ground
B1155 Neutral Switch Input Short to Battery
Apr 11, 2014 | 2007 Harley Davidson FLHRC Road King...
Tip
How to maintain Battery on our mobile phone for long lasting performance?
How to maintain our mobile phone battery for long term usage?
Many phone users never knew if how long the battery will last. As long as we use it regularly for a day or two,they are satisfied indeed.
Some problems.
* Other phone users preferred to buy mid or low quality batteries cause it is affordable,but the consequences,battery easily drained and immediately turns into low battery level.this can also damage the phone when the voltage is no longer at ease and the phone comes out with a short circuit board.
* Making a call,playing games,listening to music etc. while the phone is on charging.
When we got low battery warning,suddenly we plug the charger to the phone immediately cause we're expecting incoming calls,we might lose the momentum of the game or save the game level if suddenly the phone turns off. The result, phone is getting hot and the battery is deform due to simultaneous current entering the phone.A voltage coming from the battery and a voltage coming from the charger. also may lead into a short circuit problem and affects some parts of the mobile components.
* Overnight charging or charging the phone for a long time.
This might happens when we're using the phone until we almost got asleep at night while the mobile is on charged. Exceeding the voltage requirement of a battery as well as the phone itself may lead into battery discharge,deform structure and also causes short circuit problem.
Tips
1. Buy original battery coming from an authorized retail outlets and ask for a warranty for security purpose. Look for the quality seal product to assure that you've got the right product.
2. Follow the manual on the charging procedure when you bought a new battery. Observe the initial charging time and the regular charging time.
3. Never use your phone while on charged. (if it's important, you can do it sometimes but not regularly) make sure the phone is turn off and observe the regular charging time.
Hoping that this simple guide of mine helps.... Good Day!!!
on Jun 23, 2011 | Cell Phones
Mobility scooter battery serial connection charger question
if the charger is a 12-14 v charger you would have to charge 1 of the batteries at the time. connecting both in parallel during charging would cause a short. and in series (the way you have them wired) would provide too low a voltage for the batteries (6-7v each)
if the charger is 24-28v charger you would connect to the wires going from the batteries to the controls/motors (not the connection between the batteries) this will provide each of the batteries 12-14v charge
Mar 05, 2014 | Health & Beauty
N 95 After a full recharge says battery Full in the night ,Cell phone seems switch off in Morning but try to open no results only reboot after plugging in to charger
try to change battery first.
some tips :
* proper way of charging your mobile must be turn off
* using your mobile while charging is not recommendable because this is the reason why battery is easily drain and it suddenly turns into low battery level.making a call and player music as well as video is also a factor of making the battery weak while on charge.
* might your phone end to a shorted or shortage mobile because of overcharging the phone...and for sure some of the internal components of the mobile might get damage...
please rate me if this solution helps...you can ask testimonial too... thanks
Jun 02, 2011 | Nokia N95 Cellular Phone
Nokia x3-00 . the battery keeps running out in a few hours even though i am not using it . i only have the phone 1 month
if ur nokia x3 TALK TIME is LOW , then expect short battery life.
try turn off ur graphics( wallpapers, screensavers , themes, animated) The higher ur grapixs resolution the faster ur battery waste power. use simple and not animated.
try switch to gprs rather than 3g or gsm connection. ur mobile is using also power to look for signals.
use ringtones that are common tones.. if ur tones are mp3's then it also add problem to ur battery lyf.
Aug 13, 2010 | Nokia Lands Phones
How can i solve the problem of low usage of battery packup?
Friend, since it appears that way eventhough the batt is new. As a mobile phone technician i diagnose base from my experience that the problem of your phone is not the battery but the power supply I.C. called CCONT. It is needed to be replaced or resolder especialy if it is shorted.You need mobile technicians to solve this problem. good luck
Apr 29, 2009 | Nokia N70 Cellular Phone
In my Motorola W230 mobile, the battery life is too low
Check your battery.. if it is too old then better you replace your battery and don't charge your very frequently.
Feb 06, 2009 | Motorola Mobility W230 Phone US with...
Nokia 1200 - Water - Test mode
i'm having the same problem as i type... a quick survey of forums showed that it happens most often with battery (hardware) compared to s/w problems.
next time ur fone meets water(loo) remove the batteries immediately and the screen guard asap, too. allow them to dry for some hours and u should be fine
Jun 09, 2008 | Cell Phones
My batteries always low or empty
check if our battery is inflated, if so, your phone is shorted... is your phone dropped? soaked? there are lot of reasons why the phone became shorted...
Mar 06, 2007 | Nokia 1100
Nokia 3110 Cellular Phone Logo
23 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
