Lose sounds to my laptop model 22070 j-max notebook made in china
Want to download softwares,themes and games in j-max china mobile
try going to drivers.softpedia.com and see if there are any updates that you would need to install for your j-max and also you might be able to find some themes and stuff on that website. another website you can check out for fun stuff is themeworld.com they have a great selection of things for your mobile or computer.
Jan 04, 2010 | Siemens M56 Earbud Hands Free Headset
Install game in j-max mobile
how can i install games in j-max mobile model f1
Apr 12, 2009 | Siemens M56 Earbud Hands Free Headset
I keep losing my connection - IBM Thinkpad t42
Are you using IBM SW or Windows to manage the wireless? Occassionally, the IBM SW has issues with certain model routers and encyrption types.
You can also try unchecking the "Allow Computer to turn this device off to save power" in the adapter properties and
Adjusting the power on the wireless device to the max. By default IBM sets it in the middle to conserve power.
Mar 03, 2009 | IBM ThinkPad T42 Notebook
Memory Size
  • 256 MB / 2 GB (max)
  • Technology DDR SDRAM - 333 MHz
you can maximize upto 2 GB....you will not loose the data..
Feb 19, 2009 | Acer Aspire 3000 Notebook
Problem with audio in ibm thinkpad t30,2366-y1b model
T30- no sound altho SOUND MAX drivers installed...
Try Control Panel, Sounds, Sounds (tab), choose a sound toward bottom of list. press the BLACK PLAY ARROW...if BLACK SQUARE appears at the arrow, your sound is installed $\& probably OK...
NOW,,,insert a musiv CD. then press the VOLUME BUTTON, (2nd one over from the THINKPAD button, & you should get sound aplenty !!
Dec 13, 2008 | IBM ThinkPad T30 2366 Notebook
Toshiba Notebook L315 Headphone Jack Problems
the sound socket on the motherboard was nearly damaged, the only way can fix it is replaced the socket on motherboard by componnet level technician, otherwise you have to use USB port to sound out...
Nov 14, 2008 | Toshiba Satellite A105 Notebook
Audio sound device
solve my c772tu sound driver problem. please send me proper audio driver.
Sep 20, 2008 | Compaq Presario 700 470024-192 Notebook
Notebook make bad sound
Hi, Based on the model of your laptop, I would suggest that you increase the memory to max about 2 X 256 (512Mb) (576 MB - 100MHz SDRAM). Your laptop came in several versions from PIII 650 to 1.0G. Running XP might barely be ok with 1G but definitely will be slow in 650. You might want to downgrade your OS to say Win2K or perhaps even a 98SE. The "bad" sound may be a result of low memory. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 13, 2007 | Compaq Armada M700 Notebook
144 people viewed this question
 Grubhead
Grubhead
