Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool fridge will not get cold after cleaning
I cleaned my whirlpool fridge with regular wiping using water with bleach and soap.
I opened the panel under the ice maker because the water was squirting every where and the icemaker quit working.
Could you help me diagnose the problem?
    Novelist:
  • 184 Answers
IF THIS REFRIGERATOR IS A TOP MOUNT FREEZER/REFRIGERATOR, CHECK TO BE SURE THAT THE FILL TUBE AND CUP ON THE BACK OF THE ICE MAKER ISN'T FROZEN UP. THE WATER SHOULD FLOW DOWN THE FILL TUBE, THROUGH THE CUP, AND INTO THE ICE MAKER.
I'M NOT SURE WHICH PANEL YOU REMOVED. IF IT IS THE ACCESS PANEL DOWN AT THE BOTTOM BACK OF THE REFRIGERATOR, THAT IS WHERE THE INLET WATER VALVE IS LOCATED. IF THAT IS WHERE THE WATER IS SQUIRTING FROM, CHECK THE CONNECTIONS ON THE VALVE TO BE SURE THEY ARE TIGHT. ALSO, CHECK THE PLASTIC WATER LINES ATTACHED TO THE VALVE TO BE SURE THEY AREN'T CRACKED OR BROKEN.
Posted on Apr 10, 2008
Refrigerator smells horrible , but there is NOTHING spoiled in it.
You might have something smelly in the defrost drain pan. The easiest thing to do would be to take the back off the fridge and see if the defrost drain pan smells bad...if so just clean it out with soap and hot water. don't use anything too strong smelling to clean it though, you don't want your fridge to smell like bleach or pine sol.
Good Luck!
Sep 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I get rid of a mildew odor in the Whirlpool Duet front loader?
bleach and bleach and bleach and bleach!!!!! also i notice more of a smell in washers when people only use liquid detergent and too much of it.
Tip: leave door open after every wash
clean with bleach and hot water regularly once a month
with no clothes on a normal cycle
alternate liquid detergent and powder (yes powder comes HE)
only use HE detergent
try these things and you will find your washer smelling like new again. but tthe trick is BLEACH and a lot of it. once you get a smell it takes a long time to get rid of it.
good luck and let me know if this helps
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a problem with excessive lint on our clothes after a wash with our wirlpool top loader model 6ALBR6245JQ1
Hi
To resolve this issue you'll need to clean your top load washer. Try the steps mentioned below to clean it--
Remove the dispenser and spray with white vinegar. Then spray the agitator with it too. You can pretty much wipe it right out. Vinegar dissolves softener very quickly. The dispenser just wash out with warm water after the vinegar sits on it for a minute, and you hardly have to wipe at it at all. try adding bleach to the dispenser and clean it with a small brush.
The dispenser will pull off from the agitator and you can run hot water in it from the sink. The agitator is not as easy but has a 1/2" bolt holding it to the shaft. remove the bolt and pull up. but you can clean the whole washer with a cup of bleach and that will also clean the agitator. Now run a full tub of hot water and then add a cup of bleach with no soap. After the washer has filled up, then add another gallon of hot water and that will help to rinse out the residues that cause odors. then after that dont use too much soap and you wont have residue build up. Only use the smallest amount of soap that the cup has marked in it.
After performing all these steps if you still get lint on clothes then it is due to a clogged drain pump and/or drain filter.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Sep 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Mold in door gasket between door and drum. I have washed it with bleach, will that be enough? I have also cleaned the soap dispenser and dispensing area. Is there any other place the mold could hide that I...
not really but when completed a wash cyc always leave the door open until it cools down, yes this applies e en if you wash in cold water todays modern front load washer mixes both hot/cold
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Strong mildew odor in Duet washer
are you useing he detergent? if not this is your problem the washer cannot get ride of the soap so what it does is leave a layer of film in your washer and odor causeing bacteria forms in it. There is a product called AFFRESH you can buy it at SEARS it is made specifically for this. Do you leave the door open ragularly? The reason I am asking is because your washer is like your bathroom if you do not ventilate it properly it will grow mold and it needs to be cleaned. By leaving the door closed all the time it is very easy for the bacteria to grow.
So my advice is to leave the door open, make sure you are useing the correct soap (HE) high efficiancy soap, clean the washer with no clothes hot water and bleach and use the affresh or washer magic. Since you can smell the smell you are going to have to keep cleaning it abouit 2-3 times a month till it goes away. Then once a month. This is not a machanical problem or a whirlpool problem and is very commen in ALL front loader if you do not clean it regularly.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Lint on dark clothes in my Whirlpool Cabrio washing maching
sorry there right ..your not using he or low suddsing detergent ,or your using to much..as the water pumps out of unit the sudds stick to side of tub than when rinse water comes in it washes back on your clothes...i can only give you tips and something to look for...look for water not drainning fast enough ,,cut down on detergent,,wash your dark clothes first..give your unit a bleach clean about a pint of bleach..keep me posted onthejob
Feb 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
How to clean my front load washer
there is a product out which cleans interior of wash tub called affresh which works better that bleach which could be purchased at leows or home depot for about $7 for 3 tabs follow direction on package. remember use he type soap only and you only need 1 oz of soap per load
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have the Duet, front loading washer and it now has a rotten egg smell every time you start it. Any suggestions on how to get rid of the smell?
This nasty smell is generally soap scum build-up. First thing i would do is to remove the bottom panel and clean the pump filter, (sometimes junk builds up there and stinks) if the inside of the pump is slimy, make sure your drain hose is not installed too deep, pull up the hose and see if it is wet and slimy at the end, if so, it is siphoning dirty water back into the machine after the cycle has ended. If that is the case, correct the drain hose so it is only 5-6" down the pipe, and then run a sanitary (hot) cycle, with nothing but a half gallon of bleach. Don't use that much bleach regularly though, as it can wear on hoses. After the machine is clean, make sure you leave the door open while not in use, use only HE (high efficiency) soap, and use a max of 3-4 Tablespoons. Also, to reduce odor, try sprinkling Oxi-clean powder in the door boot lining occasionally. Hope this helps..
Sep 17, 2008 | Whirlpool Washing Machines
Smelly washer
Try Putting Lemons in the washer once you done the washing gets rid of the smelly oder
Jul 19, 2008 | Whirlpool Washing Machines
Dispenser full of water
believe it or not whirlpool says that's normal its in your owners manuel under dispenser because the washer mixes the bleach soap fabric softener with water for it to dispense they say its normal for water to remain but if you want to empty it there is a tab that you can press down on in the dispenser and remove it have a bowl handy
Jan 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
227 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
