Question about Swintec 7040 Typewriter
My typewriter is not printing what I type. Could there be a code that I am not aware of to release this. Is it the actual wheel ?
  • Swintec Master
  • 3,594 Answers
I believe there is a slide switch on the L. side of the keyboard labeled 15, 12, 10 and PS. it may be in PS, put it in 10 or 12 if it isn't in PS slide it up 7 down a few times they do get dirty.
DickyO
Posted on May 13, 2010
How can we change the qwerty keyboard into azerty one many thanks for your support
HOLD DOWN THE CODE KEY, PRESS AND RELEASE THE "L" KEY TYPE 251, RELEASE THE CODE KEY. You will probably need a matching print wheel.
DickyO
May 12, 2011 | IBM Wheelwriter 30 Typewriter
When you type, each character you strike actually types another letter.
first try turn typewriter off, (button on left panel toward the back), then turn it back on, and while hold down the CODE button, press RESET key, the whole print head will move and reset
if that doesn't work, power off again, open the cover, release the lever to the Daisy Wheel, and inspect that Daisy Wheel - mine has a bent forward letter, and another letter was kinda stuck to the side of another letter... I gently fix both letters, put the Daisy Wheel back in, firmly lock it in place with the lever, close the cover... and voila, it works like a charm.
While you have it open you might want to dust (use the cleaning spray can duster)... You wouldn't believe what I found in my typewriter... Good luck!
If that doesn't work, I would replace the Daisy Wheel.
gkt
Jan 12, 2011 | Brother GX-6750 Typewriter
TYPING II IN PLACE OF LETTERS
the mark you are seeing is the print hammer hitting the paper. remove the ribbon. corr. tape & print wheel. turn on the typewriter. close cover let it home it's self. open cover put in print wheel. close cover let it nome. put in ribbon close cover. try typing if marks are still ther. you will need a new print wheel. if working then put in corr. tape or if you are better at spelling then me you will not need it
Jan 21, 2009 | Smith Corona Wordsmith 200 Typewriter
Want Typewriter Look For Novel... But Still Use My computer
There were many typewriters made that could be used as a printer using a generic daisy wheel printer driver. Most of the IBM Wheelwriter with printer option or you may be able to find a daisy wheel mprinter on ebay.DickyO
Dec 06, 2008 | Lexmark Wheelwriter 1000 Typewriter
Lexmark 1500 typeover
There are a few possibilities, first check to see if it is in the language mode, light on the rt. side code "L" will get you out of it. If that is OK the keyboard may be selecting the wrong keyboard. Press and hold code key, press and release the "L" key, type 001, release the code key. If this solves the problem. check the keyboard connectors. If they seem to be fully plugged in you will need a keyboard.
DickyO
Sep 29, 2008 | Lexmark Wheelwriter 1500 Typewriter
Brother ML100 Typewriter:All of the sudden, it just won't type. It seems the 'hammer' doesn't hit the daisywheel. We've replaced the daisywheel, corrective tape, ribbon and still it goes through the...
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Nov 14, 2007 | Office Equipment & Supplies
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Types wrong Characters
Does it always type the same wrong letter ie a always prints u or w ? if so the print wheel drive gear is out of position. if not and it get random letters some thing may be interfering with the wheel rotation.
Jul 04, 2007 | Smith Corona Wordsmith 200 Typewriter
DAISY WHEEL
typing "code" and "reset" sets it right to type
Mar 20, 2007 | Brother SX-4000 Typewriter
Swintec 7040 Typewriter Logo
78 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
