Question about Microsoft Windows XP Professional
I am getting a error when trying to print from a remote connection from XP Pro to Server2008 the error reads... Windows presdentation Foundation Terminal Server Print W has encountered a problem and needs to close. It is a XP SP3 pc that has just been rebuilt and all Windows updates have been installed. It is a HP Laser Jet 4200 PCL printer using PCL6 drivers. It worked fine on this same machine prior to it crashing and needing rebuilt.
  • 590 Answers
The problem of your may be caused due to driver conflict or due to NOD32 antivirus (if in case you are using).
To resolve your issue, please try the following steps one by one and check if your problem got solved in any of the steps below:
1. If in case you are using NOD32 antivirus, disable /switch off the network drives scanning option in your antivirus control panel.
2. If your are not using NOD32 AV, then download a hotfix from microsoft from the below link, install it and try printing again
http://thehotfixshare.net/board/index.php?autocom=downloads&showfile=9930
3. If still your problem , persists then copy TsWpfWrp.exe file from any of the windows vista machine and replace the file to the windows xp machine.
Now try printing again.
I hope this is helpful in solving your problem.
Please provide your comments and concerns in following the above steps, if any.
Thanks
Posted on May 13, 2010
  • 5 more comments
  • Hi,
    Please take a look at the below link where lot of people discussed about the solution to your problem.
    http://social.technet.microsoft.com/Foru...
    Thanks
  • Brian Meloy
    Brian Meloy May 13, 2010
    I tried both of these solutions. I now get an error that simply says"Some unexpected have happened to software you recently used. You were not asked to send these error reports at the time they occured.
  • Hi,
    Thanks for trying out the steps.
    Please try un-installing the printer driver and install it again using the driver cd which came along with your printer. I would recommend you to download the latest version of driver for your device from hp website and install the same. Before that ensure that the hotfix which I have provided is installed.
    Thanks
  • Brian Meloy
    I am doing that right now. I will let you know how I make out. It is an old laser printer so the original disc driver is pcl 5. So not sure if that will fix it since the driver has been updated several times over the years, but I am trying it anyway...
  • please use the below link to download latest drivers.
    http://h20000.www2.hp.com/bizsupport/Tec...
    While installing in win server 2003 machine, right click the setup.exe (installer in cd or in folder(if downloaded)), select "Windows xp" in the compatibility Tab and try installing the driver.
    I hope this might help you.
    Thanks
  • If still nothing works out, then you can try the HP Universal Print Driver which solves problem for lot of printers.
    Download and install the HP Universal Print Driver from below link and install.
    Thanks
  • Brian Meloy
    None of these things are working. I noticed on my 2008 server .net framework is 2.0 is the only version available in my Features are when I try to add features under Server Manager. In my installed program folder I have .net framework 3.5 sp1. Also when I check my "services" file it only shows .net framewors 2.0 and it is not running. Also with 2008 server i notice during a remote connection in the printer properties under advanced Server 2008 is using Terminal Service Easy Print. I expected to see the driver for the printer. It will not allow me to choose the printers driver. I researched this and it says that .net framework 3.0 or better must be installed and running in order for Terminal Service Easy Print to function. Any of this make sense. I have worked with Server 2000, 2003 and never ran into this. This is not a problem with my vista machine.And I have 47 other XP machines on the network that have no problem. Just one machine with SP3
Tip
How to check the activation of windows...
step 1: Go to Start -> Run and Type oobe/msoobe /a c9f481a.jpg Step 2: Done!You will get a window with a message "windows is already activated.Click OK to exit" 7dbf6b0.jpg
on Feb 12, 2010 | Computers & Internet
Tip
How to check the version of windows...
step 1: Go to start-> run and type winver
step 2: Done! you will get a window like this.There you can see all the details!
Hi there. I have an on-going issue with this printer. I'm using Windows XP, sp2 on a Mac Pro. While printing I get these error messages on a regular basis: Error: undefined Offending Command: (what...
sounds like it's trying to send pcl code to the printer and can't read it, need make and model of printer
and what is the print file your trying to send, does it only happen on this type of print file?
Apr 27, 2011 | Office Equipment & Supplies
During the installation of Nitro PDF pro I have the error 2753
For OS -> Vista or Win 7, try these steps.
Start ' CMD ' Right Click and Run as administrator ' regsvr32 vbscript.dll
and, reinstall your Nitro PDF pro Installer.
Windows XP Users -> Read this link @ http://www.ehow.com/how_5047270_fix-internal-error.html
If you still get the error 2753, try using another Nitro PDF pro installer. Corrupted files from the installers can also cause these errors.
Hope it helps.
Apr 07, 2011 | Nitro PDF Software PrimoPDF
Tip
step 2: Done! you will get a window like this.There you can see all the details! 1b3f0b2.jpg Soluzia.net
on Jan 19, 2010 | Microsoft Windows XP Professional With...
Print Job enter's queue, but doesn't actually print.
hi thanks for using fixya!
Do you have 32bit or 64bit system?
Mar 24, 2009 | HP LaserJet 4250n Printer
Landtech dos for windows - new systems (XP) need to windows
you can get a hub for the lpt and usb try www.tigerdirect.com
Jan 25, 2009 | Intuit QuickBooks Pro 2008: Windows
Aardvark Direct Pro Q10 wont intall with windows xp
I NEED A AARDVARK, DIRECT PRO Q10 INTERFACE (CONNECTOR) HOST TO BUY. CAN YOU HELP ME FIND ONE?
THANK YOU,
BRIAN MCBEAN
Feb 17, 2008 | Aardvark Direct Pro Q10 (bundle) External...
Printer Error
check all drivers first........
if it dont work............try to print any matter........
if it work then main matter u r trying to print may be in not a printer supported format
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 25, 2007 | Computers & Internet
Microsoft Windows XP Professional Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
